		| Author | Message |
		| Fergus Kyle
				|  Posted: Thu Jan 24, 2008 10:37 am    Post subject: Engine Bay wiring |   |
				| Cheers,
To save complexity (?), I bought 6 x #22 cable to satisfy the number
 of sensor needs from the engine to the instrum panel and proceeded to hook
 up the requisite items.
 A flash from the ether told me that perhaps the cable would not
 survive the heat experienced in various upper reaches of the engine bay -
 which, if memory serves (heh,heh) ranges up to about 200deg Fahrenheit I
 hope on a long taxying-in.
 If any one has corrections to the above I'd appreciate it.
 I then searched the cable and found "60C" which I think means its
 max temp parameter, so I put a sample in the toaster-oven and set 100degC.
 Ten minutes later, I vented the kitchen to the -10degC outdoors, set
 the oven fan to max and in about 30 minutes had hidden the smoke from my
 shortly-returning spouse - and then extricated the tiny black worm from the
 pie pan [I intend to replace].
 The kitchen was warm before she came in.
 I can find a replacement for the cable which says "90C". Can I use
 this for the Europa purpose outlined above? I can't find the FAA criteria
 under the usual terms.
 Your good offices in this touchy matter are greatfully accepted.
 Happy landings,
 Ferg (smoky)
		| Back to top |  |
		| Gilles.Thesee(at)ac-greno Guest
				|  Posted: Thu Jan 24, 2008 10:55 am    Post subject: Engine Bay wiring |   |
				| Fergus Kyle a écrit :
  	  | Quote: |  	  | I can find a replacement for the cable which says "90C".
 Ferg,
 If you happen to use a 914 engine, remember that *much* heat is
 generated under the cowl.
 Even with a correctlly cowled non-turbo engine, temperatures well in
 excess of 100 C can be reached at some places. By "correctly cowled "I
 mean "tightly cowled", as should be any slick aircraft engine.
 I personnally would not use anything but Tefzel in the engine bay. Max
 temperature is 150 C. As the different sensors are in different places,
 no problem with neatly bundling up the individual wires from the engine
 up to the firewall. Do not use ordinary Ti-wraps, though.
 Best regards,
 Gilles Thesee
 http://contrails.free.fr
		| Back to top |  |
		| rampil
				|  Posted: Thu Jan 24, 2008 11:00 am    Post subject: Re: Engine Bay wiring |   |
				| Hi Ferg,
 This is what they make Tefzel and its more recent cousins for.
 A great place for aerospace wire is http://www.skycraftsurplus.com/
 A great place to visit!!  Their website does not display wire well,
 but they have loads of stock, nearly anything you might require,
 and ... at 5-10 cents on the dollar retail!
 Ira N224XS
		| Back to top |  |
		| josok-e(at)ukolo.fi Guest
				|  Posted: Thu Jan 24, 2008 12:51 pm    Post subject: Engine Bay wiring |   |
				| Hi Ferg,
 Out of interest i added a temp sensor in the cable form on top of the engine. This is a 914 with shroud. All gillls closed. Normally this sensor indicates about 40 C max, during taxi as well as flight. Only after the engine has been shut down, the temperature goes higher. Opening the inspection covers helps. Next thing to try in Summer is to cover the standard eyes in front of the cowling. They would make nice places for lights. Second thought is, that i would never accept anything but aircraft grade wiring, not even in other places as under the cowling.
 Jos
 Visit -  www.EuropaOwners.org
		| Back to top |  |
		| europa flugzeug fabrik
				|  Posted: Thu Jan 24, 2008 7:01 pm    Post subject: Re: Engine Bay wiring |   |
				| Ferg, why y'all usin' #22 wire in a vibrating environment?  Without special care in terminating the wires, they can eventually fracture.  I don't think I've seen a production A/C with #22.  They use #20 for small currents, no matter how small.
 Fred F.
		| Back to top |  |
				|  Posted: Fri Jan 25, 2008 3:58 am    Post subject: Engine Bay wiring |   |
				| Hi Fred,
 Would it not be a good idea to -always- take special care at the termination points? A good rule is, that if the copper can move at it's attachment point it needs reinforcement, whatever gauge.
 Jos
		| Back to top |  |
		| rampil
				|  Posted: Fri Jan 25, 2008 5:53 am    Post subject: Re: Engine Bay wiring |   |
				| Hi Fred F,
 Ferg originally said he was using 6 conductor cable.  That would mitigate
 the vibration flexing from your otherwise very good point.
 Ira N224XS
		| Back to top |  |
		| hdwysong(at)gmail.com Guest
				|  Posted: Fri Jan 25, 2008 9:51 am    Post subject: Engine Bay wiring |   |
				|  	  | Quote: |  	  | Ferg, why y'all usin' #22 wire in a vibrating environment?  Without special care in terminating the wires, they can eventually fracture.  I don't think I've
 small.
 Ferg almost burns his house down by cooking wire in a toaster oven and you want him to start worrying about wire gauge!?
 Seriously, a long glance behind any modern panel (especially those with glass) will reveal a host of 22 AWG wires or smaller.  There is absolutely no written/unwritten rule about using a minimum of 20 AWG.
 The panacea here is good workmanship (e.g. - proper strain relief, proper support at regular intervals, proper service loops, etc.), NOT bigger wires.  Proper workmanship also includes selecting wire rated for the environment, so stick with the Tefzel, Ferg!
 See chapter 11 of AC 43.13 for suggestions on the rest  (free PDF available here:  http://tinyurl.com/ynopgy).
 D
		| Back to top |  |
				|  Posted: Fri Jan 25, 2008 2:47 pm    Post subject: Re: Engine Bay wiring |   |
				|  	  | rampil wrote: |  	  | Ferg originally said he was using 6 conductor cable.  That would mitigate the vibration flexing from your otherwise very good point. |
 Yes, but I'm picturing the connections to the individual engine sensors.  #22 behind the panel inside the plane is OK, if the wire ends at the instrument connectors are properly dressed and/or secured.
 Fred F.
		| Back to top |  |
