control stick assembly
rnewman(at)tcwtech.com
PostPosted: Thu Jan 24, 2008 6:06 pm    Post subject: control stick assembly Reply with quote
I'm about to insert the wd-0012 control sticks into the wd-0011 stick mounts and the instructions basically say "put it in as far as it will go" The engineer in me says "what the heck does that mean?" The stick mount has a weld joining two tubes, Have you all worked to get the control stick to go in beyond the weld? Have any of you cut the end of the control stick at an angle to allow the stick to bottom out inside the wd-0011 stick mount? Also were your stick mounts suffiecently out of round so that it was a real battle to get the stick to go into the mount. ( i've already deburred and removed some of the weld slag and now am about to deal with the out of round condition)
Thoughts and comments needed.
Best regards,
Bob Newman
TCW Technologies
bob.kaufmann(at)cox.net
PostPosted: Thu Jan 24, 2008 6:38 pm    Post subject: control stick assembly Reply with quote
I found that a bigger hammer worked quite well.
Bob K
Really, I milled the stick out to fit because I’ve got this amazing neighbor, or he milled it to fit.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob-tcw
Sent: Thursday, January 24, 2008 5:58 PM
Subject: control stick assembly
Best regards,
Bob Newman
TCW Technologies
Tim Olson
PostPosted: Thu Jan 24, 2008 7:03 pm    Post subject: control stick assembly Reply with quote
Mine weren't super out of round, but I do think I did some generous
rotational sanding around the tube to make sure it slid in, and
I sure don't want to take them out again.
Best regards,
Bob Newman
TCW Technologies
