		Ed Anderson
				 Posted: Fri Jan 25, 2008 1:39 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				I recently went through three years of fight with the tax  man due to a quirk of Zip code zoning and the FAA (apparently in complying with  the demand of states who want to tax your airplane) that some of you may want to  know about.
  The adjacent county has a large city with the typical  heavy tax burden on its citizens - three years ago I started receiving  a tax notice for some unspecified personal  property  that supposedly resided in their county.
  It took me two years to discover that the personal  properly they were trying to tax was indeed my aircraft.  Despite   correspondence with the tax authorities to the effect that I was not/had never  been a resident and did not/never had any personal property in their  county.  The harassment persisted.  I then went to the on-line  aircraft registration data and sure enough - the FAA had put my aircraft in  their county!!!
  To make a long, long story shorter, it turns out that even  thought there was no place on the FAA aircraft registration form for county, the  FAA decided to added it to your registration record based on your postal zip  code.  Now, normally that probably works OK, but in my case, and I suspect  others out there it turns out my postal zip code is for a town in the adjacent  county - yep,  the high tax zone.  They scanned the FAA registration  rolls for their county and got a hit on me.
  I finally got the FAA to change my aircraft registration  county to the correct county, but am still being pestered by the tax  authorities.  If this does not change by next tax year, I am  considering a harassment lawsuit against the tax authority - Yes, its  changed in the FAA records, but it is probably forever embedded in this  county's tax computer {:<(.
  So the message is -  check your aircraft registration  data on file at the FAA  http://registry.faa.gov/aircraftinquiry/NNum_inquiry.asp
  to make certain the information reflects the correct  county (or any other pertinent information)  for your aircraft (this  assumes you want it to reflect the correct information  {:>))
  FWIW   Do Not Archive
  Ed
  Ed Anderson
 Rv-6A N494BW Rotary Powered
 Matthews,  NC
 eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)
 http://www.andersonee.com
 http://members.cox.net/rogersda/rotary/configs.htm#N494BW
 http://www.dmack.net/mazda/index.html
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
		NationAir
  Joined: 14 Nov 2007 Posts: 6 Location: Chesterfield, MO
				 Posted: Fri Jan 25, 2008 2:15 pm    Post subject: Re: The FAA, County of Regsistration,Zip Code and Taxes |
				Ed -
 Excellent point.  The FAA updates there records much faster now and it is very important to check to see they get it right.  This includes your airman record.  About 2 years ago they started "red flagging" registrations that were not completed properly.  If a registration is incomplete or has an error they will attach a warning on it.  I think (not confirmed) they require any inconsistencies to be cleared up or you could face a violation - not sure how severe, but possible.
 While we are on the topic of registrations, everyone should also remember the name and address on your registration should match your insurance policy.  It makes it that much easier in the event of a claim or loss.
 $0.02 from the insurance guy.
  _________________ David McCoy
Branch Manager
Light Aircraft Division
NationAir Aviation Insurance
www.nationair.com |
		n616tb(at)btsapps.com Guest
				 Posted: Fri Jan 25, 2008 2:36 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				Hi Ed,
 I just checked mine and sure enough they have the wrong county on mine as well.  My address is actually the neighbor town where the post office is, but I actually live in a different town and county.
 What did you have to do to cause the FAA to correct the record?
 From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Anderson
  Sent: Friday, January 25, 2008 3:36 PM
  To: RV-List
  Subject: The FAA, County of Regsistration,Zip Code and Taxes
 FWIW   Do Not Archive
 Ed
 Ed Anderson
  Matthews, NC
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV-List  | 	  0123456789
		rv7(at)b4.ca Guest
				 Posted: Fri Jan 25, 2008 2:44 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				On 14:32 2008-01-25 "Tim Bryan" <n616tb(at)btsapps.com> wrote:
  	  | Quote: | 	 		   I just checked mine and sure enough they have the wrong county on
 Make sure the correct one has a lower tax rate before you switch...
 -Rob
		Ed Anderson
				 Posted: Fri Jan 25, 2008 5:12 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				Tim, someplace on the FAA cite there is an e mail form to  contact the airman's registration branch.  However, here is the e mail  address from which I was contacted by the FAA and told they had corrected the  error.  You might try it or search their site - I can't seem to locate the  e mail form on a quick look.
  9-AMC-AFS750-Aircraft/AMC/FAA(at)FAA ([email]9-AMC-AFS750-Aircraft/AMC/FAA(at)FAA[/email])
  Ed
  [quote]   ---
Matthews, NC
		Ed Anderson
				 Posted: Fri Jan 25, 2008 5:15 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				-List message posted by: "Rob Prior" <rv7(at)b4.ca>
  -Rob
   A good point Rob, had not the county I resided in with my aircraft not had
 a much lower tax rate - I, urhmm... might not been as vigorous in having the
 record corrected {:>).  But, ultimately, you could have two tax authorities
 after your $$$.  In several local counties, the local government has sent
 forms to each airport manager requiring them to list all aircraft that
 reside on the airport.  My airport manager recently received such a form and
 apparently feels legally bound to comply with it.
 Ed
Matthews, NC
				 Posted: Fri Jan 25, 2008 8:23 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				On a similar note... several years back I started receiving property tax
 notices for a plane I had tied down at our local airport. You know the
 typical row of bug smashers left exposed to the elements. It turns out
 that every year between 12/15 and 12/31 a tax assessor drives the
 airport writing down all tail numbers. I am sure they connect the dots
 as to the owners and schedule a property tax bill.
 A year later I sold that plane and purchased a big hangar that now has 3
 of my 5 planes (don't ask...) I have never received a tax bill for these
 aircraft simply because my N Numbers are out of sight.
 Basically all the small, relatively inexpensive aircraft owners are
 being taxed while all the expensive iron sitting in their comfy, clean
 hangars get a free ride.
 Obviously some of the hangar owners are paying the proper aircraft taxes
 but who knows.
 We need a radically simplified tax system.
 Robin
 Panel almost here!
		Bob Perkinson
  Joined: 10 Jan 2006 Posts: 51 Location: Hendersonville, Tennessee
				 Posted: Fri Jan 25, 2008 10:50 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				How about No Tax, at all.  We now pay tax upon tax,  tax on the fuel we burn, tax on the truck the delivers the fuel, tax on the fuel that the trucked used to bring the fuel,  tax on the tires that the truck that delivered the fuel. the refinery that produced the fuel is taxed, along with the men and equipment that is used to make the fuel.  Taxed on the raw fuel so as to be able to bring it into the country. not to mention all the other taxes that are applied to some of the avionics,  some where their prob is a break down of how much tax and the percentages played would the value be.
 Bob perkinson
 -------------- Original message ----------------------
  but who knows.
  Robin
  Panel almost here!
		mbick(at)carolina.rr.com Guest
				 Posted: Sat Jan 26, 2008 6:37 am    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				> -Rob
       Ed
      I know the evil airport  manager Ed refers to ..   Yes sadly I am legally bound to report it or the  airport is responsible for the taxes plus 250 fine for each occurrence. I Like  Ed for he is a very likable person but I don't like him so much so that I want  to pay his taxes for him.
        When I received  notice I was at first dumbfounded then I was PISSED. I thought why is it I have  to do the county's dirty work? I called a lawyer and I contacted a federal  authority for surely this insanity could not be true. They both said yes and  pointed to the NC statue (G.S.105-316 subsection a 3) and the fact that it has  been upheld since the 50’s. Like boat storage owners and mobile home parks, the  county doesn't want you to hide your assets and wants their money. The Irony in  this, you realize a Private Airport Owner has to collect information for and pay  taxes that will not be providing any assistance to the private owner and to be  used to compete against them making all but impossible to run a private/public  airport unless they have owned the land for years. But that is a whole other  thread and I am sure Private Airport owners are not alone.
     I went on to contact the county tax manager explaining to  her that there was no need for me to supply that, for the information was  already there and she told me: "I don't have access to that". I explained to her  everyone has access to that. The FAA puts the information (albeit sometimes  incorrect) up on their web site for everyone to query.  She said that is  not the way they do it and to send in the hand written form they sent to me.
     I hated doing so for I caught a lot of grief from a few  for asking for it, some flat out refused to do so. I can't blame them for it is  really none of my business but the government makes me do so. So Ed I apologize  for that.
    Mike
		Bob Collins
  Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
				 Posted: Sat Jan 26, 2008 6:45 am    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				Easily arranged. All you have to do is decide what services you personally
 receive that you're willing to give up and start making calls. Folks usually
 want to take away something others are getting, but it'd be more effective
 if folks organize to give back benefits they receive.
 Do not archive.
 Bob perkinson
  tax notices for a plane I had tied down at our local airport. You know
  the typical row of bug smashers left exposed to the elements. It turns
  out that every year between 12/15 and 12/31 a tax assessor drives the
  3 of my 5 planes (don't ask...) I have never received a tax bill for
  these aircraft simply because my N Numbers are out of sight.
  taxes but who knows.
  Robin
  Panel almost here!
  _________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
		Ed Anderson
				 Posted: Sat Jan 26, 2008 7:27 am    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				No Problem, Mike.
  If I did refer to the "Evil" airport manager it was an  unintentionally slip {:>) - actually, our airport manage is not a bad guy -  even if he wouldn't pay my taxes.
  Ed
  [quote]   ---
Matthews, NC
		n343fd(at)yahoo.com Guest
				 Posted: Sun Jan 27, 2008 7:37 pm    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				"wants their money"
 I would it is not there money it is YOURS and they TAKE/steal it!
 Mike Divan
 N64GH - RV6,flying
 SLOW 7 Builder
 EAA - 577486
 FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
		Bob Collins
				 Posted: Mon Jan 28, 2008 6:05 am    Post subject: The FAA, County of Regsistration,Zip Code and Taxes |
				// I would  it is not there money it is YOURS and they TAKE/steal it!
  // FREEDOM IS NOT FREE -  THANK THE AMERICAN SOLDIER FOR YOURS!
  Couldn't ignore the  irony (g)
  do not  arcxhive
St. Paul, Minn.
