				 Posted: Wed Jan 23, 2008 2:20 pm    Post subject: Firestar project |
				On the Firestar project I recently started, yesterday I ordered a couple of tires from Aircraft Spruce. You guys were right- excellent service. I also called Aitcraft Tech and talked to both Jim and Dondi- again excellent. I took some scrap wood and built a boom support so I could work on the tailwheel. Too cold for more. Today I put the wings on, and tried to weigh it. I don't trust the bathroom scale anymore- re-weigh everything, and kept getting different results. I had to stop and take the wings off when the wind picked up, but it might be 15 pounds heavy. Or it's the scale. I was having trouble with the door catch, but my Dremel smoothed off a bumpy weld on the catch, and I polished the rotary arm. I still have to clamp the window frame it's mounted on- it slides back and forth. Epoxy, maybe, or a pop rivet. I tried to start it, and the primer would not pump up, and I was afraid to blow a gas line. The filter looks to have crud in it, and I was looking  at the Mikuni pump. It tilts to the front. Is there any possibility that it could have water in that corner and froze? The temp only went up to about 34 today.
                                              Bill (old Firestar)
		JetPilot
				 Posted: Wed Jan 23, 2008 3:11 pm    Post subject: Re: Firestar project |
				Personally I would not worry about 15 pounds overweight.  An early firestar makes a very passable ultralight.   Trying to pass off a 2 seat MK III as an ultralight probably wont work, but if its just 15 pounds only an anal SOB would care either way.
 Your best option is to N Number you plane.  I just heard through the grapevine that if you are an EAA member, and you send in all your paperwork, that the FAA is giving extensions to get the inspection done.  But you MUST have your paperwork in by Jan 31.   Dont take this as gospel, but I just heard this today...  Call the EAA before doing anything and confirm it with them.
 If for some reason you just can not get an N number, I would not worry about 15 pounds.   There will always be some idiot that will tell you to throw your plane away, or take weight off the structure, etc etc but I never listen to anal idiots.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Wed Jan 23, 2008 3:50 pm    Post subject: Firestar project |
 Mike B:
 If the aircraft weighs more than 254 lbs, it is an airplane.
 If the aircraft weighs 269 lbs and is not registered maybe you can explain
 away those 15 lbs to the first FAA type that ramp checks you.  Yes, ramp
 checks are real, even back in prehistoric times of the 1980's.
 I don't consider myself an anal idiot, however, I would not recommend to
 anyone to fly a fat ultralight because if is not an ultralight but an
 unregistered airplane.
 What do you think about those 1g glides to touch down with a few 90 and 180
 deg turns thrown in there for good measure?  Like I said, I would never have
 believed it if I had not done it.
  _________________ John Hauck
Titus, Alabama |
		JetPilot
				 Posted: Wed Jan 23, 2008 4:36 pm    Post subject: Re: Firestar project |
				Hi John,
 I think you are one lucky dog because you got to go flying your Kolb today and the rest of us did'nt !!!    I plan on practicing engine out turns some more as soon as I get a chance...
 Did you notice what your altitude loss was in the 180 degree turn back to the field ?
 Mike
		The BaronVonEvil
  Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
				 Posted: Wed Jan 23, 2008 4:40 pm    Post subject: Re: Firestar project |
				Hi Bill,
 Please take the time to review the requirements for Ultralights in the FAR's Part 103.
 This will help you decide weather or not you can operate under those rules or if you need to get registered as a experimental light sport or amateur built experimental.
 Sometimes those real anal guys are with the FAA.  Most of the FAA guys are there to help you but they are only human and can have a bad day like any of us.
 The FAA has the authority to levy fines and can impose other penalties including confinement etc.
 Please make sure you are okay with the "Rules" so that you can avoid any hiccups that life can throw at you.
 Good Luck with your Project and Welcome to the Kolb List.
 Best Regards
 Carlos G
				 Posted: Wed Jan 23, 2008 4:55 pm    Post subject: Firestar project |
 the field ?
 Mike B:
 Nope.  Wasn't concerned with altitude loss, but making my touch down point
 on the grass.  Worked every time.
 I'll have to watch the VSI next time and see if there is much difference
 between 1g glide straight and 1g glide in 90 and 180 deg turns.
Titus, Alabama |
		Ralph B
  Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
				 Posted: Wed Jan 23, 2008 4:59 pm    Post subject: Re: Firestar project |
				I registered my Original Firestar at 319 lbs. After I built it, it was about 290 lbs. I switched to a 447 Rotax engine, added streamlined struts, bigger wheels, lexan gap seal, and a nice cushion seat. All of this adds weight. I wanted to have the capability to fly cross country, so I carry an extra 6 gallons. Under 103, I couldn't add anything or carry more fuel. Now I can.
  _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
				 Posted: Thu Jan 24, 2008 4:19 am    Post subject: Firestar project |
				Thanks for the advice on the FAA extension, but I'm going for 103 legal, even if I have to fill the wings and tires with helium. I've had it for a week, and I finally got around to sitting in it. Strange thing is that it fits me perfectly. The previous owner was about 5" taller than me, and I have no idea where his knees were.
     After I tried weighing it, I started cleaning and throwing out unnecessary junk. Radio brackets, mouse nests in the cables, and who knows what else. Couldn't weigh them- no scale small enough.
     Weather permitting, engine work today. The local snowmobile dealer says they might have the carb mounting rubber and filter. If not, order and wait. also a gas filter and plugs.
     Question: On the "B" gear box there are two holes- one each side and about 3/4 of the way up. Are they supposed to be open, or plugged?
                                                   Bill
				 Posted: Thu Jan 24, 2008 4:40 am    Post subject: Firestar project |
				Bill S:
  Go here to get, at no charge, all the manuals for  your engine.
  http://www.kodiakbs.com/tiintro.htm
  Not saying you can't do it, but I know of no one  that has come close to legal ultralight weight for a Firestar.
  [quote]      Question: On the "B" gear box there    are two holes- one each side and about 3/4 of the way up. Are they supposed to    be open, or plugged?
                                                      Bill
Titus, Alabama |
		Richard Pike
				 Posted: Thu Jan 24, 2008 5:26 am    Post subject: Firestar project |
				Open. Saves weight.
 Richard Pike
 MKIII N420P (420ldPoops)
 william sullivan wrote:
  	  | Quote: | 	 		    <snip>
                                                 Bill
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		DAquaNut(at)aol.com Guest
				 Posted: Thu Jan 24, 2008 6:59 pm    Post subject: Firestar project |
				Bill,
    You can save 2 lbs. or more going with 4" Azusa wheels ,but the  ground handling wont be as forgiving.
                Ed    D.
 Who's never won?  Biggest Grammy Award surprises of all time on AOL Music.
				 Posted: Fri Jan 25, 2008 4:48 am    Post subject: Firestar project |
				Thanks for the info, guys. I checked my fuel system, and everything was okay. Tried to start it- no good. had to get help, and put an in-line spark checker at the plug- no spark. I found a funny switch under the seat cushion, right near the BRS handle. It was wired to the kill switch. There was a very small (1/4") red hard dot in the center, and it wouldn't move. Took it apart- It was a push kill switch, and the rubber in the center had jammed the push button down. Took it out and threw away. Engine started first pull, and more weight gone. Even new, I would have had to take a pen or something to use it. I don't know what someone was thinking.
                               Bill
		JetPilot
				 Posted: Mon Jan 28, 2008 12:31 am    Post subject: Re: Firestar project |
				I would not worry a bit about 15 pounds extra on an ultralight.   Sure, there well be many that say "  Its not legal " , or " The law is the law "....  etc. etc.   But you will see those same people going slightly over the speed limit and not thinking twice about it.
 15 pounds is inconsequential given a 254 pound limit.  I say only an anal idiot would worry about 15 pounds, lets put this into perspective.  Its only 6 % over the limit.
 If you were driving 58 MPH in a 55 MPH Zone, which is 6 % over the limit, and someone complained that you were speeding, what would you say ???   If you given a ticket for doing 58 MPH in a 55 zone, I guarantee that you would be telling everyone you knew what BS it was to get a ticket for just 3 MPH over...   Just about as stupid as worrying about 15 pounds, or 6 % extra on an ultralight no ?
 As far as safety, you are far more likely to hurt someone else by doing 58 MPH in a 55 Zone in your car than you ever would be to hurt anyone or anything by having 15 extra pounds on an ultralight.   So its nothing short of hypocritical for people say " The law is the law ",  unless they never break the speed limit by more than 3 MPH, there is far more danger in that.
 People tend to get super anal when it comes to aviation, and yes they are idiots.  In reality if you are the type that is super paranoid, super legal, and worried about causing an accident, NEVER go more than 3 MPH over the limit, because this is something that is far more likely to hurt yourself and others than having 15 extra pounds on your Firestar.
 Anyone on this list that never drives 3 MPH over the limit ?  I didn't think so...
 Mike
		Steve Boetto
				 Posted: Mon Jan 28, 2008 4:35 am    Post subject: Firestar project |
				In a message dated 1/28/2008 3:34:46 A.M. Eastern Standard Time,  orcabonita(at)hotmail.com writes:
   	  | Quote: | 	 		  | I say    only an anal idiot would worry about 15 pounds | 	   I think you are missing the point here Mike, To me, it is not a matter of  right or wrong, but rather a challenge. I enjoy the challenge of putting  somethng together that performs well and meets the guidelines of a category.  Sometimes the FAA gives you limits and sometimes nature or physics  does.   Now if the category is poorly defined or has loopholes then I  have no problem exploiting them.
  Now is almost 254# like almost not pregnant?  The tires almost needed  to be replaced / I almost replaced them
  I hope to have Firefly on Floats #2  less than 338# done for SnF 08,  Hope to see you there,
  Anal and not so bright in Florida,
  Steve  B
 Firefly 007/Floats
 do not  archive
 Start the year off right.  Easy ways to stay in shape in the new year.
		captainron1(at)cox.net Guest
				 Posted: Mon Jan 28, 2008 10:04 am    Post subject: Firestar project |
				Wait a minute the speed limit is the minimum you can go, not the maximum.
 Ron (Arizona)
 Mike
 http://forums.matronics.com/viewtopic.php?p=160801#160801
 kugelair.com
		R. Hankins
  Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
				 Posted: Mon Jan 28, 2008 10:27 am    Post subject: Re: Firestar project |
				I flew my overweight, overspeed, over fuel capacity KXP as an ultralight since 1999.  I stayed to the spirit of the law; no brakes, no electric start, empty weight of 292# with a 503.  I stayed out of trouble, gave way to GA aircraft in the pattern etc.  If not for the sport pilot rule change shining the spotlight on all of us, I probably would still be flying that way.
 Over time, I made many small changes.  I added side doors, a little carpeting, extended range tanks, radio and GPS mounts and battery, new wheels, tires, and brakes.  Gradually, I moved further and further away from being an ultralight. When sport pilot came out, I decided to take the opportunity to legitimize my unregistered aircraft and quit looking over my shoulder.
 It is a personal decision that you must make for yourself.  If you are only going to fly around the local patch and nearby non-controlled fields, you will PROBABLY never get checked.  If you ever want to take your plane to a fly-in or have a cross-country adventure, your odds of getting caught go up.  Just don't kid yourself that you are an ultralight.  If you are overweight, or have a top speed over the limit, or a stall speed above the limit, you are flying an unregistered aircraft.  It is kind of like driving around without a drivers license.  Unless you get pulled over, or have an accident, everyone just assumes you are legal, but it gets tiring keeping one eye glued to the rear-view mirror.
  _________________ Roger in Oregon
1992 KXP 503 - N1782C |
				 Posted: Mon Jan 28, 2008 11:21 am    Post subject: Firestar project |
 idiot would worry about 15 pounds>>
 I am all for pushing the limits a bit but  if the law says `that is the
 limit` then that is it.
 I am sure it must be something similar in the US but here in the |UK the
 whole point of a weight limit is not that it is dangerous to exceed the
 limit ot that it will make your flying less safe it is the simple fact that
 above a certain weight the plane is no longer classed as an ultralight and
 must then conform to the same rules as GA..
 That automatically means that you are no longer entitled to the breaks in
 the  maintenance schedules which are enjoyed by the ultralight category. You
 will have to pay a `certified` mechanic to carry out anything but the
 smallest job on the plane
 The flying medical which for an ulralight pilot here is signed off by your
 local doctor for about £20 will revert to a full light aircraft category
 medical by an `approved` doctor and will be around £180/£200. . Most
 important of all is the fact that your insurance will be invalid. Of course
 if you are the type who habitually drives a car without insurance then there
 is no point in talking and you should be locked up for the general good of
 society.
 The comparison to breaking the speed limit is puerile. Your car license and
 insurance will not become invalid if you go over 30 mph.
 The rules and regs governing ultralights have been hard fought for here in
 the UK and probably in the USA too. Because ultralight pilots generally have
 stuck to the rules and been professional in their conduct they are now
 welcomed by nearly all airfields, big and small. That was not the case a few
 years ago when we were looked on as hairy arsed. bikers of the sky.
 If the weight limit is too low, and as our planes have become more
 sophisticated, acquired bigger engines, electronics etc., that may well be
 so then get the legislation changed, as we have here, not just pretend it
 doesn`t exist. The FAA isnt going to go away but they could ground everyone
 with a stroke of the pen.
 Life is not a box of chocolates. It is more like a jar of jalapenos.
 Something you eat today may come back and roast your bum tomorrow.
 Cheers
 Pat
		JetPilot
				 Posted: Mon Jan 28, 2008 12:02 pm    Post subject: Re: Firestar project |
				 	  | pj.ladd(at)btinternet.com wrote: |
 Pat |
 Well, if the law says 55, then thats it.  Better not drive at 58 MPH, and if due to advances in cars, the 55 limit needs to be changed, then legislation should be introduced, don't pretend it does not exist.  Sound familiar ???
 You are much more likely to do harm to property and life by speeding than by being 15 pounds overweight in with your ultralight.   As for image, no one will ever know if your ultralight is 15 pounds overweight or not, its far easier for others to see you speeding.
 When you get the emotion of aviation out of the picture and apply the same standard to every day life, its just plain stupid and hypocritical to worry about 15 pounds overweight in an ultralight and then drive 3 MPH over the speed limit or more on a regular basis and think its OK.
 You seem to have some issues with being consistent, and even more importantly, you are unable to recognize which is more important and more likely to result in damage to property and others, which is the basis for ALL these rules we live by.
 Mike
		Possums
				 Posted: Mon Jan 28, 2008 12:23 pm    Post subject: Firestar project |
				At 07:27 AM 1/28/2008, you wrote:
  The thing is that after Jan 31, your fat ultralight will stand out a lot
  more that it use to "without N-numbers". Use to be hardly anyone had them,
  even the two seaters. Now - you will be a lot more conspicuous out there on the
  tarmac.
  _________________ Possum |
		Richard Pike
				 Posted: Mon Jan 28, 2008 12:55 pm    Post subject: Firestar project |
				Consistent? It appears to me that your talking points are mixing apples
 with oranges with bananas.
 I seriously doubt that any of us care whether any of the rest of us are
 actually Part 103 legal or not, the issue is what happens if you get
 ramp checked by FSDO and you are not Part 103 legal. The FSDO guy is not
 going to be interested in your likelihood of doing greater damage to
 life and property because you are 15 pounds overweight, his job is to
 enforce the law as written, so IMO, your comparison to driving 15 over
 the speed limit is irrelevant to the issue.
 As far as being hypocritical to drive slightly over the speed limit as
 opposed to being slightly overweight, I could care less if you drive the
 speed limit or not. Because in the real world that I live in, the rules
 are written not so much to keep us safe, but to quiet the squeaking
 wheels. In Sullivan county where I live, the county commissioners
 determine the speed limits, and any yahoo who lives on a county road and
 gets a burr under his seat because somebody drives down "his road"
 faster than he likes, can write his commissioner a letter and get the
 speed limit lowered to 25 mph. Consequently I live in a county with lots
 of 45 mph capable roads posted at 25. Do I think the people who drive 40
 are hypocrites? No, only the idiot who wrote the letter to his
 commissioner who drives 40. Do I think the speed limit rules are written
 to keep us safe? Maybe in your world, around here they are written to
 pacify Uncle Fester. (And no, I'm not ranting because I got busted <grin>)
 Do I think folks ought to push the limits on Part 103 regs? Only if they
 are willing to have a deep wallet if The Man catches them out. In which
 case, fly it however fat, fast, or far you want, I could care less if
 your "ultralight" is part 103 legal or not.
 Which is the impression I got of what the other listers were saying: As
 long as you're willing to pay the piper, you can dance any way you like.
 If not, then get legal. And that's not hypocrisy, that's reality.
 Richard Pike
 JetPilot wrote:
 > Pat
  Mike
  http://forums.matronics.com/viewtopic.php?p=160887#160887
Kingsport, TN 3TN0
