Firestar project
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Ralph B
PostPosted: Tue Jan 29, 2008 10:38 am    Post subject: Re: Firestar project Reply with quote
Even if the ultralight is 15 lbs overweight and you seem happy flying on 5 gallons of fuel, more power to you. As for me, I like the idea of being able to carry the extra 6 gallons so I can go places. Can't do that in a legal ultralight or one that's already 15 lbs overweight, unless you've got your fuel stops very carefully planned. Therein lies the difference between a legal machine and an illegal one.
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
JetPilot
PostPosted: Tue Jan 29, 2008 10:47 am    Post subject: Re: Firestar project Reply with quote
Range has nothing to do with the subject we are talking about. If you read my first post on this subject, I said that having an N number would be the best way to do it, but this is NOT a discussion on if William should N Number his plane or not. This is TWICE in a row that you have obviously not read, and been unable to follow the very simple idea of this whole thread. Why would anyone listen to a guy that cant grasp a simple concept, and posts answers that do not apply to the subject at hand ?
Mike
Kolb MK-III Xtra, 912-S
rowedenny(at)windstream.n
PostPosted: Tue Jan 29, 2008 11:11 am    Post subject: Firestar project Reply with quote
All,
I am impressed that this particular Firestar is so close (15lbs) to the UL limit of 254. I say go for it, put in a five gallon tank and take out everything you can and see if you can get it legal, maybe lighter wheels, brakes? and tires are in order. Other than fuel and weight, all Firestars should be Part 103 legal so give it a good effort and see if you can get it legal.
Denny Rowe, 475 pound Mk 3, N616DR
PostPosted: Tue Jan 29, 2008 11:27 am    Post subject: Firestar project Reply with quote
Denny:
I think the problem is the FS is way too fast and will not fit the matrix to make it a legal UL even if it only weighs 254 or less, and has 5 gal fuel capacity.
The FF barely makes it, and only because of the matrix. Main reason the FF has two lift struts per wing panel, to increase the drag component.
[quote] I say go for it, put in a five gallon tank and take out everything you can and see if you can get it legal,
PostPosted: Tue Jan 29, 2008 11:42 am    Post subject: Firestar project Reply with quote
Mike
"NO FEAR" - If you have no fear you did not go as fast as you
could have !!!
Mike,
It makes me very nervous that someone of your disposition is flying jets.
Range has everything to do with the legal, illegal debate and this Firestar
project.
Now lets see if you can grasp a simple concept.
Denny
PostPosted: Tue Jan 29, 2008 11:48 am    Post subject: Firestar project Reply with quote
John H,
If the Firefly with its short wing fits the 103 matrix, I would think a
light Firestar with 6 more feet of wing and a 447 or 377 would fit. Surely
that much more wing has more drag than an extra 4 foot long wing strut they
add to make the Fly compliant?
Someone want to do the math for this one?
Denny
jindoguy(at)gmail.com
PostPosted: Tue Jan 29, 2008 12:06 pm    Post subject: Firestar project Reply with quote
What about going the other way round and shorten the Firestar's wing to Firefly dimensions? You might have to resort to.........VG's (oh dear lord, to think what his might bring to the discussion Smile ) to get the 24 knot CAS requirement, but you would sure be losing weight.
Just a PBI, no real thought or math calc's put into it.
Rick
On Jan 29, 2008 1:47 PM, Denny Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
[quote]--> Kolb-List message posted by: "Denny Rowe" <rowedenny(at)windstream.net (rowedenny(at)windstream.net)>
John H,
PostPosted: Tue Jan 29, 2008 12:18 pm    Post subject: Firestar project Reply with quote
[quote] -----Other than fuel and weight, all Firestars should be Part 103 legal so give it a good effort and see if you can get it legal.
Whoops,
I should have wrote all 377 and 447 powerd Firestars in the above, obviously a 503 powered Firestar would not make compliance.Denny
jbhart(at)onlyinternet.ne
PostPosted: Tue Jan 29, 2008 1:01 pm    Post subject: Firestar project Reply with quote
At 02:47 PM 1/29/08 -0500, you wrote:
John H,
Denny,
If Bill is serious about this, he can change to a 28 hp engine and save at least 40 pounds. With an engine change the wing loading will be less than the FireFly, so it will have no problems meeting stall speed requirements. If Bill's Firestar has a 447 mounted and he changes engines, he will be giving up enough hp so that he can fly with reduced drag and not exceed the max speed requirement.
To run the numbers, all one has to do it to follow:
http://www.thirdshift.com/jack/firefly/fireflylegal.html
Taken from that page:
40 hp max, the FireFly total drag factor must exceed 12.4
38 hp max, the FireFly total drag factor must exceed 11.8
28 hp max, the FireFly total drag factor must exceed 8.7
To get Bill's Firestar to comply with upper speed limit one would have to knock off 3.7 drag units from my FireFly.
Drag Unit Reduction from FireFly
Single strut per wing => 0.8
Go to full enclosure => 2.0
Larger wing drag =>-0.25
Fair landing gear legs => 0.4
Total Reduction 2.95
This would give total drag factor of 8.6 which is very close to 8.7. Bill may have to leave fairings off the landing gear legs. According to this his Firestar should top out at 55 knots. I have found this graph to be conservative, so I expect it would do better than this.
Jack B. Hart FF004
Winchester, IN
JetPilot
PostPosted: Tue Jan 29, 2008 1:07 pm    Post subject: Re: Firestar project Reply with quote
[quote="jindoguy(at)gmail.com"]
Rick
Rick
That is the worst idea I have heard to date, why would you shorten the wings, and make the airplane more dangerous by increasing wing loading and stall speed ? Now you have an airplane that is easier to stall, and impossible to slow down as much as before in a forced landing. So you are suggesting that Bill go to many hours of work to make a more dangerous airplane, in order to lighten it a couple percent, or lighten Only a total fool would do something like that. I have seen pure stupidity on this list before, but this is one of the worse suggestions I have seen to date.
I can just see Rick and Richard in a position of authority. " Sir, your plastic fuel tank has bulged and it now holds 5.25 gallons, and 5 gallons is the limit, so I am going to have to violate you.. " Or sir, you were doing 58 MPH in a 55 MPH zone, so I am going to write you a citation...
To anyone reading this thread now or in the future, don't make your plane more dangerous, or make it handle worse, or harder to fly than it needs to be. This is a prime example of people that can read a rule, but can not use good judgment and will sacrifice safety in pursuit of chasing an arbitrary number by a couple percent. We have to much of this kind of stupidity and poor judgment in the world as it is.
Mike
JetPilot
PostPosted: Tue Jan 29, 2008 1:21 pm    Post subject: Re: Firestar project Reply with quote
jbhart(at)onlyinternet.ne wrote:
Denny,
Jack B. Hart FF004
Winchester, IN
Since when do they go test fly ultralights while doing ramp checks to see what the max speed of the ultralights are ? Your suggestion is nothing short of irresponsible. Most people must be reading this and laughing at you, they just aren't as willing to pout out your bad suggestion in public suggestion as I am. Having more power = more options available when things go bad, which means more safety. Steeper climb = More altitude and more options if the engine quits at the end of the runway.
Only an anal retentive person without a ounce of good sense would suggest putting to small an engine on a firefly to chase a couple percentage points in numbers. This would make the plane underpowered, very substandard in climb, and more dangerous than it needs to be just to slow it down a little.
Mike
Richard Pike
PostPosted: Tue Jan 29, 2008 1:21 pm    Post subject: Firestar project Reply with quote
I have a very good friend who has the amazing ability to misunderstand
and misconstrue anything said to him. Are you a relative of his?
Richard Pike
MKIII N420P (420ldPoops)
JetPilot wrote:
<snip> Of course, Richard Pike will probably want to take the gas out of your new tank, and if it is a pint over 5 gallons, tell you to change it as you are still illegal hahaha.
Mike
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
russ(at)rkiphoto.com
PostPosted: Tue Jan 29, 2008 1:41 pm    Post subject: Firestar project Reply with quote
Mike
Rick's not the only one, by far, who's sick your pontificating.
Lighten up! We read the list to learn something useful, not to get
an earful of your personal opinions-- e.g, the Gospel according to
Mike --
On Jan 29, 2008, at 1:31 PM, JetPilot wrote:
jindoguy(at)gmail.com wrote:
> Mike, If you can't quit this diatribe, could you at least relabel
> it as "BS rant about nothing" or something similar. Some of us
> would like to hear about Bill's Firestar and not your philosophy.
> Rick
> do not archive
Well rick, for claiming not to like this subject and not wanting it
on the list, you have taken every opportunity to join in. So
according to you, its OK for you and people that share your opinion
to post and continue this subject ( Richard Pike ), but not others..
Looks like you are one of those " Do as I say , not as I do people
". Very lame.
Mike
&quot;NO FEAR&quot; - If you have no fear you did not go as fast
as you could have !!!
http://forums.matronics.com/viewtopic.php?p=161123#161123
1planeguy(at)kilocharlie.
PostPosted: Tue Jan 29, 2008 1:43 pm    Post subject: Firestar project Reply with quote
Mike
<snip>
With fear of stepping into someone else's fight...so all these Firefly's
with the shorter wings are BAD? Seems that a little higher wing loading
is a good, shall I say GREAT thing sometimes...like when there is a
little turbulence and/or thermal activity...by your reasoning we should
all be flying gliders...so they would have good engine out
characteristics Wink That is a great characteristic, just not the only
one to consider in these great big balls of compromise that we call
airplanes...(or "vehicles" for you Part 103 folks...Wink
Jeremy "clip-wing Firestar/Slingshot wannabe" Casey
http://www.kilocharlie.us/superfly.htm
Richard Pike
PostPosted: Tue Jan 29, 2008 1:57 pm    Post subject: Firestar project Reply with quote
Ok, I give up. I tried my best to explain the difference between dealing
with the law and the consequences of breaking it and my indifference to
what any of you choose to do about it, and that has been (deliberately?)
misconstrued.
I tried to point out (tongue in cheek) that I deal with idiot 25 mph
speed limits on 45 mph roads as I think best, am willing to take the
responsibility of getting busted for doing so, and even posted a picture
of my crotch rocket, and that has been (deliberately?) misconstrued.
Proverbs 26: 4 tells us "Do not answer a fool according to his folly,
lest you also be like him. " The next verse, Proverbs 26:5 says "Answer
a fool according to his folly, lest he be wise in his own eyes."
Guys, I am done with trying to fulfill verse 5, and I leave it to you to
figure out how best to deal with verse 4.
The MKIII is coming into the garage tomorrow, some more mods to the
fuselage area, try to improve the airflow around the fuselage upper
rear, just ahead of the radiator, add a taper at the back end of the
fuselage, see if cleaning up that little flat area about 10" ahead of
the prop arc will do anything. Fix a glitch in the radio, different
intercom, etc.
Also bought myself a Hall wind meter, will be pulling off the VG's,
attaching the Hall to a lift strut, getting it pointed straight into the
relative wind at stall, and shooting some videos through stall to see
what this MKIII actually stalls at, power on and off, with and without
flaps, and satisfy myself as to just what she does. Then put the vg's
back on and do it all again. If I come up with anything worth sharing, I
might check back in this summer.
It's been a great ride, fair skies and tailwinds to you all,
Richard Pike
Rick
> [b]
Rick
Mike
&quot;NO FEAR&quot; - If you have no fear you did not go as fast as you could have !!!
http://forums.matronics.com/viewtopic.php?p=161173#161173
Richard Pike
Kingsport, TN 3TN0
a58r(at)verizon.net
PostPosted: Tue Jan 29, 2008 2:13 pm    Post subject: Firestar project Reply with quote
Geez Louise, this here FarStar thread has become a hawser around our lower alimentary outlet! Let's an- ull all this, before we say  more nasty things. Don't have to kiss and make up,  just kinda let the thread, already unravelled, part, as we say in the Senior Service.
regards,
Bob N.    FireFly 070 Old Kolb,  mostly legal 'cept fer the two holes fer mah size 9.5 EEEEEE foot brakes to stick out.
PostPosted: Tue Jan 29, 2008 2:25 pm    Post subject: Firestar project Reply with quote
Denny,
it will have no problems meeting stall speed requirements. >
Jack H
Jack,
I would think that a Firestar that is this close to 254 pounds would already
have a slower stall speed and lighter wing loading than a Firefly with its
much smaller wing area.
I doubt the engine size would need to be reduced to achieve legal UL speed
limits on paper as long as the few pounds could be removed elswhere.
Sincerely,
Denny
Michael Sharp
PostPosted: Tue Jan 29, 2008 2:27 pm    Post subject: Firestar project Reply with quote
Gents,
If in outlook you will right click on his message.
Select Junk email
Then select add sender to blocked senders list
All of the list DH's Crap will go where it belongs..
In the junk mail folder.
I'm sure other email programs have similar options..
Mike
The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike
PostPosted: Tue Jan 29, 2008 2:48 pm    Post subject: Firestar project Reply with quote
Mike
Mike,
This has been a discussion about what can be done to make a Firestar a legal
ultralight vehicle. As my right, I have posted my opinion and you have
posted your opinion of my opinion, which is your right. I believe Bill is
capable of deciding for him self as to what he wants to do with my post.
You do not understand. I don't care if people laugh at me or not. I have
more faith in numbers than suppositions. The numbers, based on existing
wing and power loading, say that a Firestar can fly very safely with only 28
hp.
Your incessant claim of a requirement for power tends to lead me to believe
you use it as a crutch for your lack of adequate piloting skills or your
discomfort in flying in very very light aircraft. I find your heaviness, to
use one of your terms, "anal". Please lighten up, drink a beer with a
friend, find some companionship, or find medical help.
Just for your info, I have a 27hp MZ34 sitting on the table in my shop.
Today I finished the computations to see how the cg change in mounting it.
Even with a bulk head mount off the back, the cg moved forward and just one
inch. I believe it will cut close to 50 pounds off the FireFly. I will add
some weight back with a full enclosure so I can do more winter flying. If
and when it gets done, the FireFly will remain a true ultralight vehicle. It
will continue to be as safe as the person who flys it.
In answer to your question, during a ramp check a pilot of an ultralight
vehicle has to prove that the unregistered aircraft he is flying is an
ultralight vehicle. The FAA has deemed that a properly filled out AC 103-7
Appendix 1, 2, 3 & 4 is sufficient proof.
Once again, Mike have a nice day and fly safe.
Jack B. Hart FF004
Winchester, IN
Possums
PostPosted: Tue Jan 29, 2008 4:20 pm    Post subject: Firestar project Reply with quote
At 03:20 PM 1/28/2008, you wrote:
At 07:27 AM 1/28/2008, you wrote:
In a message dated 1/28/2008 3:34:46 A.M. Eastern Standard Time, orcabonita(at)hotmail.com writes: I say only an anal idiot would worry about 15 pounds
The thing is that after Jan 31, your fat ultralight will stand out a lot
more that it use to "without N-numbers". Use to be hardly anyone had them,
even the two seaters. Now - you will be a lot more conspicuous out there on the
tarmac.
Let me reply to my own post - That is, if you are 15 pounds overweight and don't have
N-numbers, you are going to "stand out" in the crowd now - more that before, and if
you don't have N-numbers you are more likely to be ramped checked after Jan 31st.
Not that the 15lbs is any worse than we've all been doing for the past 20 years, but
when we all were doing it and nobody had N-numbers - you were a lot less likely
to be questioned. [quote][b]
Possum
Page 3 of 6
