drfred(at)suddenlinkmail. Guest
Posted: Mon Jan 28, 2008 1:22 pm Post subject: Fiberglass class |
Patrick:
Any photos of cool mods would be appreciated.
Speaking of wheel pants. My friend who has a RV 10 here in Paris was
out at a grass strip this weekend. He had a loose right wheel pant from
the bolt holding the hexagonal support breaking. Fortunately, No major
damage done and we took the wheel pants off before anything was
seriously damaged. He's now getting one of the upgraded axle supports
made. Only 56 hrs on the hobbs. He's probably had the airplane for 20
hrs. Lives on a grass strip also.
Dr. Fred
Fitting the cowl this week.
http://picasaweb.google.com/drfredparis/DrFredRv10Picasa
Tim Olson
Posted: Mon Jan 28, 2008 2:38 pm Post subject: Fiberglass class |
For the newbies in the group, here's what part Fred is talking
about:
http://www.myrv10.com/N104CD/upgrades/20070118/index.html
Fred Williams, M.D. wrote:
<drfred(at)suddenlinkmail.com>
Patrick:
Dr. Fred
Lew Gallagher
Posted: Mon Jan 28, 2008 5:08 pm Post subject: Re: Fiberglass class |
Thanks, Tim. I knew I'd seen it somewhere!
Later, - Lew
Do not archive.
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Lew Gallagher
Posted: Mon Jan 28, 2008 5:17 pm Post subject: Re: Fiberglass class |
Oh, by the way, we put the calipers on yesterday and it occurred to me that normally the bleed screw would be on the top to get the air out. Is it done this way to keep the brake line from being damaged on grass strips if it were on the bottom?
And where did I see the exact height of the installed canopy with wheels on? We'll soon be wondering about clearing the garage door!
Later, - Lew
Posted: Mon Jan 28, 2008 6:38 pm Post subject: Fiberglass class |
Lew,
The bleeders go on the bottom of the caliper, you need to relocate one of them...check the plans...it's in there.
Rick S.
40185
Posted: Mon Jan 28, 2008 6:49 pm Post subject: Fiberglass class |
Lew Gallagher wrote:
Well, it does work on your car!!!
| Quote: | Is it done this way to keep the brake line from being damaged on grass strips if it were on the bottom?
Not really. Aircraft brake systems are usually bled from the bottom up
and the bleed fitting is where the fluid goes in. This doesn't mean
that bleeding from the top down isn't effective ..... it's just easier
to bleed up.
Linn
| Quote: | And where did I see the exact height of the installed canopy with wheels on? We'll soon be wondering about clearing the garage door!
Hmmm. Ya got me on that one!!!!
Linn
Lew Gallagher
Posted: Mon Jan 28, 2008 7:54 pm Post subject: Re: Fiberglass class |
Thanks for the replies, Guys. I tried to reply through email so as not to clutter up the forum, but the email wouldn't go through.
We already put the bleeders on the bottom as instructed, just seemed backwards to me.
Linn, you fill the system from the bottom up? ... really? Sounds messy and impractical. I've bled cars from the top down for the past 40 yrs. -- first plane, so clue me in!
Use a hand pump, put a hose on the nipple and force fluid all the way up through the pedal cylinders to the reservoir? But then the nipple has to be loose to allow fluid in? One side then the other? And I must admit I haven't read ahead to see if it's covered in a later section -- just got the calipers on and had to call it a night.
Puzzled, - Lew
Tim Olson
Posted: Mon Jan 28, 2008 8:17 pm Post subject: Fiberglass class |
I don't see it in the directions, but yes, fill a pump type oil can up
with brake fluid, and put a hose between it and the bleeder. Open the
bleeder and pump the fluid UP through the system until it fills the
master cylinder. you may have to remove some from the master cylinder
to make room for more, so you can pump enough until all the bubbles
are out. It works, and works well. Yes, definitely different than
doing cars.
<lewgall(at)charter.net>
backwards to me.
Puzzled, - Lew
-------- non-pilot crazy about building Landing gear installed, we're
mobile!
http://forums.matronics.com/viewtopic.php?p=160998#160998
Posted: Mon Jan 28, 2008 9:48 pm Post subject: Fiberglass class |
Yup!
| Quote: | ... really? Sounds messy and impractical.
And, it is.
| Quote: | I've bled cars from the top down for the past 40 yrs. -- first plane, so clue me in!
I did the same on cars..... a few years longer. I don't know why
airplanes have to be different. It's just the way I was taught.
| Quote: | Use a hand pump, put a hose on the nipple and force fluid all the way up through the pedal cylinders to the reservoir?
Yes. ACS sells a rather pricey coupling to make things easier:
http://www.aircraftspruce.com/catalog/lgpages/brake_bledders.php
I've used one (borrowed) and it sure makes it easier. Used a plain
garden sprayer that it was attached to. Only caveat is that the fluid
attacked the rubber in the sprayer.
I've also used a large plastic syringe with better success than the hand
pump (read squeeze type oil can) because your hand gets really tired
really quickly!
| Quote: | But then the nipple has to be loose to allow fluid in?
Yes.
| Quote: | One side then the other?
Yes.
| Quote: | And I must admit I haven't read ahead to see if it's covered in a later section
I haven't either. I kinda doubt it's there, but will be pleasantly
surprised if it is.
| Quote: | -- just got the calipers on and had to call it a night.
Wish I was that far along!!!
Don't lose sleep over it.
| Quote: | Puzzled, - Lew
Hate to tell ya this Lew, but the puzzlement is just starting. Don't
fret the small stuff (this one is) and keep plodding on.
Linn
Posted: Mon Jan 28, 2008 9:52 pm Post subject: Fiberglass class |
snip
I hit the send button early .....
Another thought is that you really can replace the nipple with something
else to make filling easier. Just be quick swapping the nipple back in.
Linn
eagerlee
Posted: Tue Jan 29, 2008 1:31 pm Post subject: Fiberglass class |
I'm sure Tim meant to say "aviation hydraulic fluid" rather than "Brake Fluid".
PH
Tim Olson
Posted: Tue Jan 29, 2008 3:44 pm Post subject: Fiberglass class |
Geez, I thought we were supposed to use red kool-aid, so that's
what I used. Isn't that it?
Good catch...yep, whatever you do, DO NOT use automotive brake
fluid....use aircraft stuff. And, rather than start another long
debate about synthetic ATF vs. standard aircraft hydraulic vs. the
newer better stuff.....perhaps just dig around on the net for
that, because there really is no conclusive answer like
"you MUST use this...". For me, I have the standard aircraft
hydraulic fluid for now. Time will tell.
eagerlee wrote:
| Quote: | I'm sure Tim meant to say "aviation hydraulic fluid" rather than "Brake
Fluid".
PH
Lew Gallagher
Posted: Wed Jan 30, 2008 5:03 am Post subject: "Brake Fluid" |
"Brake Fluid" seems to be blasphemy.
OK, I can do that. But you know I'm not that easy ... Why?
Flammability? Corrosive? Altitude issues? Not pretty enough?
Keep it simple -- I don't need molecular analysis, or a discussion of whether synthetics are really synthetics or not. Brand names?
Later, - Lew
| Tim Olson wrote: | Geez, I thought we were supposed to use red kool-aid, so that's
Fluid".
PH
