dogsbark(at)comcast.net Guest
Posted: Mon Jan 28, 2008 10:05 pm Post subject: O-540 C4B5 |
Looks like I may have found a sweet deal on an engine for my 10. It is a rebuilt Lycoming O-540 C4B5. Will add injection system.
After searching the archives it appears this is a good fit for the ten with the following considerations:
1. Engine mounting ears are too large.
2. Oil filler neck options may be different than D4A5.
3. "the work of getting the baffles fit around the case is a fair bit more on the C4B5 (in my experience) than the D4A5",
Jesse Saint.
4. No clearance between the pan and engine mount.
Can anyone elaborate on these points and/or other things to look for?
Your help is appreciated!
Sean Blair
#40225
dav1111(at)erfwireless.ne Guest
Posted: Tue Jan 29, 2008 3:51 am Post subject: O-540 C4B5 |
I installed an IO-540C4B5 on my RV-10. I did have to change out the ears but the oil sump had plenty of clearance with the engine mount.
I installed engine baffles but after a hot Texas summer I am in the process of converting them to a James Aircraft plenum. I wish I had gone with the James Aircraft plenum and cowl from the beginning as it appears that the install of the plenum from scratch would have been easier than the Van's baffle system and would have given me much better cooling with less drag.
I am going with the James Aircraft plenum and cowl on the RV-7 I am in the process of building as well.
Russ Daves
N710RV - RV-10 190+ hours
N65RV- RV-6A Sold
N742PZ - RV-8 Co-Builder
N____RV - RV-7, Waiting on QB Fuselage
Posted: Tue Jan 29, 2008 6:23 am Post subject: O-540 C4B5 |
Well, it looks like you might have your baffles issue solved. Russ,
you want to sell your baffles?
We didn't have any issue with clearance on the engine mount. I get
the impression that Van's has changed the cross-bar to allow for more
clearance, but I don't know for sure.
Just make sure you know all of the details and price out any changes
before you buy. I know of at least 2 cases where the engine ended up
costing as much or almost as much as a new experimental by the time
everything was "fixed up". IMHO, the only way to get ahead with a
used engine, unless you build it up or overhaul it yourself (and think
through the resale value in this case) is to get an engine that is
running and runnable for at least a couple of years of use.
I am sure there are exceptions to this.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 29, 2008, at 12:47 AM, dogsbark(at)comcast.net wrote:
Jesse Saint.
Sean Blair
#40225
tomflysalot
Posted: Tue Jan 29, 2008 2:56 pm Post subject: O-540 C4B5 |
The only C4B5 is injected (it is an IO-540-C4B5, normally out of an Aztec). It can be modified to fit an RV-10. I sold one last month for that very purpose. The C4B5 is rated at 250 HP (at)2575 RPM. Since it is basically the same engine, the D4 series is rated 260 HP (at) 2700 RPM.
Tom Lawson
970-420-1798
acs(at)acspropeller.com.a Guest
Posted: Tue Jan 29, 2008 3:39 pm Post subject: O-540 C4B5 |
Sean, check the governor mounting studs if you're using the Vans supplied MT
Governor. There are two lengths and C4B5 may have the shorter stud that will
need replacement to get enough "nut" on the studs for Safety.
Ears were good.
Mount clearance 3/8"
John 40315
Posted: Tue Jan 29, 2008 9:41 pm Post subject: O-540 C4B5 |
Thanks everyone for your input!
If this motor checks out, the other items you all mentioned seem do-able.
You've been a lot of help.
Sean Blair
#40225
http://websites.expercraft.com/seanb
ddnebert
Posted: Fri Feb 01, 2008 5:33 am Post subject: Re: O-540 C4B5 |
I see many more C4B5-type engines listed than the D-series engines. Are the 700+ of us -10 builders keeping the demand high, or is the D-series just less common?
_________________ RV-10 Builder #40546
Tail mostly done, wings complete, end of SB fuse, working on doors and fiberglass |
tomflysalot
Posted: Fri Feb 01, 2008 7:56 am Post subject: O-540 C4B5 |
A very probable reason for the abundance of the C4B5 is shear numbers.
The most built aircraft with this engine is the Aztec. There are over
2400 Aztecs registered (and they each have two engines).
The D4A5 was in the Comanche 260. There are only 700 of them registered.
Hmmm.
I try to get the best ones, overhaul them, and recertify them, and sell
them. Either makes a good choice.
Tom
970-420-1798
61brv10
Posted: Sun Feb 10, 2008 5:03 am Post subject: Re: O-540 C4B5 |
Where can the mount ears be found? Thanks in advance.
coop85(at)cableone.net Guest
Posted: Tue Feb 12, 2008 3:53 pm Post subject: O-540 C4B5 |
If I remember correctly, I got some mounting ears for the IO-540C4B5 on my
Skybolt from Atlanta Air Salvage.
Marcus
40286
ddnebert
Posted: Tue Feb 12, 2008 7:29 pm Post subject: Re: O-540 C4B5 |
I looked at the engine spec sheet from Lycoming and it shows the weights and dimensions, HP, RPM, TBO for the various IO-540 models. It appears that the O-540-A and -B models are nearly exactly the same dimensions as the -D and -C models, and about 10 pounds lighter (minus FI system?). It also appears that this model (-B4B5 and -B1B5) is autogas STC-d.
Would this be a viable/easy alternative for the RV-10, dimension and accessory-wise?
pilotdds(at)aol.com Guest
Posted: Wed Feb 13, 2008 6:56 am Post subject: O-540 C4B5 |
I used the B4B5 and used autofuel mix with good results.I did overhaul the engine and raised the compression to 9:1 so no more autofuel.It is a good fit and I found no particular problems.
728DD 180 hours
