Firestar project
Goto page Previous  1, 2, 3, 4, 5, 6  Next
beauford173(at)verizon.ne
PostPosted: Tue Jan 29, 2008 4:56 pm    Post subject: Firestar project Reply with quote
..so there...!
Seafoam anyone...?
beauford...
do not archive...
WhiskeyVictor36(at)aol.co
PostPosted: Tue Jan 29, 2008 8:06 pm    Post subject: Firestar project Reply with quote
In a message dated 1/29/2008 8:08:22 A.M. Eastern Standard Time, williamtsullivan(at)att.net writes:
One thing no one mentioned regarding weight- I am about 170 dressed, and my wife is about 50 pounds heavier. I would think the powers that be would be more interested in whether the gross weight is being exceeded instead of a couple of pounds over. Luckily, the Firestar is capable of the difference.
HI BILL SULLIVAN,
Does the above comment indicate that you might take your wife along as a passenger??? Or were you just talking about the difference in weight if she were to pilot it?
I had previously answered your original thread directly to you, but I'll post this one for all to read.
Just for every one's information:
On June 30, 1989 I purchased a FireStar kit from old Kolb. The specification list that came with the advertising brochure states the following:
Wing Span 27' 8"
Wing Area 149 sq ft
Length 20' 3"
Length folded 21' 3"
Height 5' 8" (same folded)
Width (folded) 66"
Load factor 4+, 2-
Reduction unit Rotax integral gearbox with vibration damper
Propeller 66 X 28
Fuel Capacity 5 gal
Rate of climb 1,000 FPM
Weight 264 lbs *
Engine Rotax 377
Take off distance 100 ft (grass)
Top speed 63 MPH (Partial enclosure)
*Needs parachute to be legal ultralight.
My kit came with the main landing gear legs only 1" in dia., where they went into the airframe. The axle holder was a light weight welded piece using small plastic wheels with no brakes. The windshield was a short one, about 1/3 coverage, and the center section cover was fabric, with a zipper to secure the two halves.
Bill Varnes
Original Kolb FireStar
Kit price on 6/30/89 $5695 included engine!!!
Audubon NJ
Start the year off right. Easy ways to stay in shape in the new year.
DAquaNut(at)aol.com
PostPosted: Tue Jan 29, 2008 8:39 pm    Post subject: Firestar project Reply with quote
In a message dated 1/29/2008 4:49:55 P.M. Central Standard Time, jbhart(at)onlyinternet.net writes:
Just for your info, I have a 27hp MZ34 sitting on the table in my shop.
Today I finished the computations to see how the cg change in mounting it.
Even with a bulk head mount off the back, the cg moved forward and just one
inch. I believe it will cut close to 50 pounds off the FireFly. I will add
some weight back with a full enclosure so I can do more winter flying. If
and when it gets done, the FireFly will remain a true ultralight vehicle. It
will continue to be as safe as the person who flys it.
In answer to your question, during a ramp check a pilot of an ultralight
vehicle has to prove that the unregistered aircraft he is flying is an
ultralight vehicle. The FAA has deemed that a properly filled out AC 103-7
Appendix 1, 2, 3 & 4 is sufficient proof.
Once again, Mike have a nice day and fly safe.
Jack B. Hart FF004
Winchester, IN
Jack,
Now is as good a time as ever to thank you for taking the time to document and share your experiments and findings to the list, as I know it takes of your time. I for one have benefited from your documentations. I too want to find a lighter alternative to the rotax. I have pondered the 1/2 VW ,but need to know more about it. I have also looked at the MZ 34. You are NOT the only one on this list that wants to be legal. I for one am not laughing at you. I commend you for the way you handle things in a civil manner ! Please keep us posted on the MZ 34 project! Reducing the FF weight by 50 lbs would reduce stall speed by a good bit.
I hope the weather cooperates so everyone can go fly. That should help everyone to be a little kinder to each other!
Ed   FF 62 Do Not Archive !
captainron1(at)cox.net
PostPosted: Tue Jan 29, 2008 9:04 pm    Post subject: Firestar project Reply with quote
Folks
I have been reading this thread for a while and its quite entertaining, I am not getting irate at anyone or anything, what for.
But, and this is very important to at least settle one aspect of this Mmmm lively discussion. First there is that purported threat that the Gestapo will bust you because your Airplane / Ultralight is obese.
So I am going to address just the legality of the subject.
First how will they tell if your craft is obese?
They can't unless you tell them or let them. You need to understand that your craft is your private property and they have no right to weigh it without your permission. So if your craft is obese do not talk about its weight or allow anyone to weigh it in their presence, same is with the fuel tank. In America we have rights, in AmeriKa we don't. I suggest that we all remember in which America we want to live and in which America we do live. If its me I would simply fly off in my obese ultralight and leave them behind. If you do have an obese craft your worst enemy is what you say, so say nothing and tell them to get away from your private property, and they *will*. As for the advisability of having an obese craft I leave that up to each of us. Its better to be inside the rules just so we can feel good. But I would not be worried that they are going to weigh my airplane without my permission, they can't they have no right at all, and in fact its against the law for anyone to mess with your private property. You can call the cops on them if they bug you too much, which they won't if you tell them to leave you alone. They are trained to know the law, and they are also trained at how to elicit information from you by talking to you, so don't talk...
Ron (Arizona)
pj.ladd(at)btinternet.com
PostPosted: Wed Jan 30, 2008 3:46 am    Post subject: Firestar project Reply with quote
I would think the powers that be would be more interested in whether the gross weight is being exceeded instead of a couple of pounds over. >>
They are in the UK, which is why the limiting weight for an ultralight here is the MTOW. For calculation purposes there is a standard weight for the pilot and passenger.
Cheers
Pat
Dana
PostPosted: Wed Jan 30, 2008 3:49 am    Post subject: Firestar project Reply with quote
They can't unless you tell them or let them. You need to understand that your craft is your private property and they have no right to weigh it without your permission...
I wish it were so:
§ 103.3 Inspection requirements.
(a) Any person operating an ultralight vehicle under this part shall, upon request, allow the Administrator, or his designee, to inspect the vehicle to determine the applicability of this part.
(b) The pilot or operator of an ultralight vehicle must, upon request of the Administrator, furnish satisfactory evidence that the vehicle is subject only to the provisions of this part.
-Dana
A rolling stone .... kills worms [quote][b]
PostPosted: Wed Jan 30, 2008 4:12 am    Post subject: Firestar project Reply with quote
The FAA set some max and stall speed limits >>
Really? You have max speed limits?. Here we have many ultralight types with
top speeds over a 100mph. One making 130 I believe. Stall speed is the main
performance regulator, 35.
Cheers
Pat
Dana
PostPosted: Wed Jan 30, 2008 4:35 am    Post subject: Firestar project Reply with quote
with top speeds over a 100mph. One making 130 I believe. Stall speed is
the main performance regulator, 35.
Pat, for "true" ultralights the maxes are 24 knots stall and 55 knots level
flight at WOT... but the Part 103 regulations are so loose (including no
license or registration) that there are many advantages to this category,
IF you can meet the 254 lb empty weight limit. For "Light-Sport Aircraft"
(comparable to your microlight category) it's 1320 lbs empty, 45 knot stall
and 120 knot max.
-Dana
For every new foolproof invention there is a new and improved fool.
PostPosted: Wed Jan 30, 2008 5:05 am    Post subject: Firestar project Reply with quote
Everybody keep talking- I'm learning! Thanks for all the information.
My wife would be flying alone. It is only a single seat. This is an old Firestar, and I still haven't found a serial number. I suspect it is an early one. The landing gear legs measure 1" where they go into the socket. It has a two blade 66" Warp Drive prop, no brakes, full enclosure, minimal instrumentation, a BRS, full size wings, and 15-6.00x6 tires with tubes on tubeless aluminum rims. No flaps or flaperons. Fiberglass tailwheel strut with about a 4" plastic wheel. Ten gallon tank. The tank is going to be switched out to 5 gallon, and that should save a pound or so. Someone said the original had Azusa nylon wheels with 4" tires. Does anyone know the weight savings by switching?
Keep in mind that this is my first aircraft project, and I find it an intellectual challenge to trim weight, as well as a lot of fun. I need all the advice you can give me. I do not have the current knowledge or experience to work the numbers.
I didn't mention a couple of things. It came through with 2 sets of struts- one set of round aluminum that I believe are original; and a second set that are streamlined steel(?) that are twice as heavy, but I didn't stick a magnet to yet. I'm using the round ones for the weight.
Extra speed does not matter. Range does not matter- only local flying is anticipated, an hour or so at a time. Safety in handling is a priority- our first ultralight.
Another question- The wings have three holes at the front attachment point for changing the angle, and the former owner recommended the middle hole. Any opinions?
Another thing to keep in mind is that I am not an engineer. My background is more of welding and fabricating with heavy steel. That is why I'm having fun with all this, and my back hasn't hurt doing it. Love the Kolb, even without getting it off the ground!
Bill Sullivan
antique Firestar
PostPosted: Wed Jan 30, 2008 6:21 am    Post subject: Firestar project Reply with quote
Bill S:
What is your aviation background, i.e., flying experience?
I know you said you planned only to fly locally for an hour at a time. I said the same thing before I flew my first Kolb 24 years ago. That lasted two weeks and I had begun my cross country career.
Another thing to remember. Take a look around and see how many folks are flying with Azusa nylon wheels. Probably not more than a couple out of the thousands that have been sent out with kits over the many years Kolb has been producing kits. There is a reason for that. They are built light and weak. Brakes, I flew without them for several years. Even did a flight from Alabama to New York State and back without them. However, it was a pain in the ass and brakes, later on, made my aircraft much, much safer.
Guess it all depends on what you want. If you are like most of us, you will want to improve your airplane and not degrade it attempting to reduce weight.
As far as meeting the FAR 103 requirement of 254 lbs, that one is going to be extremely tough to make with a Firestar. You can go to a smaller, lighter engine. The FS was designed to fly on 35 hp. It will probably fly on half that. I think you will be degrading performance and the fun of flying a sporty airplane.
Good luck,
[quote] Another thing to keep in mind is that I am not an engineer. My background is more of welding and fabricating with heavy steel. That is why I'm having fun with all this, and my back hasn't hurt doing it. Love the Kolb, even without getting it off the ground!
      Bill Sullivan
PostPosted: Wed Jan 30, 2008 6:49 pm    Post subject: Firestar project Reply with quote
Progress- I took off the tailwheel bracket in order to change the wheel and straighten the clevis glued to the fiberglass strut. The clevis had been glued on twisted, and the tail wheel was badly worn on one side. I heated the clevis to soften the glue, and it went bang and gave a small jet of flame. Luckily, I was wearing glasses and was off to one side. I twisted it gently and let it cool down. Worked great. The tailwheel axle was held in by two aluminum rivets. It was also rusted in place. I turned down and cut a 7/16" clevis pin into a bushing driver, heated the axle brackets, and it slid out. Cleaned it up with a Dremel. Travis at Kolb has it in stock. I have to repair the tubing where the steering cables attach. They were almost worn through. Lots of detail work on something this old. I also have to cut off the aluminum sleeve that holds one wheel on, with a cotter pin through it. Siezed up on the steel axle. Travis is sending some tube stock. Tip on jacking: This plane has tubular axles. Stick a lon 5/8" bolt in the back of the axle, and use an old Chevy truck jack. This is the jack with an internal screw, and has a drop-down hook plate. Works great. Only problem was that the ice was slowly melting. and the jack was sinking. I am jealous of all you indoor plane fixers.
Bill Sullivan
DAquaNut(at)aol.com
PostPosted: Wed Jan 30, 2008 7:50 pm    Post subject: Firestar project Reply with quote
In a message dated 1/30/2008 7:05:46 A.M. Central Standard Time, williamtsullivan(at)att.net writes:
Someone said the original had Azusa nylon wheels with 4" tires. Does anyone know the weight savings by switching?   Bill,
You should save a minimum of 2 lbs going to 4" Azusa from 6 " Azusa. Very likely More especially if your 6" wheels are of the aluminum variety. Personally ,even though I have the 4 " wheels, the 6'' wheels are my preference as far as handling goes.
Ed   FF62
PostPosted: Thu Jan 31, 2008 3:23 am    Post subject: Firestar project Reply with quote
For "Light-Sport Aircraft" (comparable to your microlight category) it's
1320 lbs empty>>
Hi Dana,
I think our new sub 115Kg category will closely approximate your ultralight.
Not completely uncontrolled but much more so than our usual
`microlight`spec.
Our `microlights` are still well below the Sports category weight. My Xtra
has to be below 950lbs MTOW.
Fascinating how different countries have dealt with this problem. Some have
specified empty weight some MTOW some countries do not allow flight above a
certain height some do not allow it below a certain height. Switzerland
allowed no microlights at all until last year. Spain had no legal
microlights a few years ago but there were plenty flying. The legal spec was
so tight that no one could possible fly. Apparently all applications to fly
microlights finished up on the desk of a guy in the Spanish equivalant of
the FAA and he was a microlight pilot himself. He just `lost` them.
Apparently in Australia until a short time ago there were many pilots with
no pilots licence because they lived on large homesteads and and learned to
fly in the same way that they learned to drive a car. Their Dad taught them.
They were never `official` beacause they flew on and over their own land and
never landed at a `proper` airfield. However when they began to fly from
their own homesteads to the neighbours, and then on to the next one, and the
next, in increasing numbers the authorities lowered the boom on them. Good
while it lasted though.
No more posts from me for a couple of weeks as I am off to supposedly
`sunny` Tenerife in the morning. In fact Tenerife has rain and high winds
forecast for at least the next few days. Warm though, in the 70`s so that
will be OK
Cheers everybody
Pat
PostPosted: Thu Jan 31, 2008 5:46 am    Post subject: Firestar project Reply with quote
Pat, thanks for the information on the latest developments over there. I am new to this, so the term "ultralight" means something different to all of us. Keep the info coming.
As far as the three mounting hole at the front of the wings, they appear to have a lot of stock around them. They are tarped in the back yard, and when the weather is good I will get some measurements. Too windy yesterday. They appear to be well made and cared for, and I don't know why they were for sale- no damage except for 4 small (under 2") holes in the ailerons from shipping damage. They are 5 rib. Some stray weight can be taken off them, like an antenna mount, and something that I think is a fancy tie-down attachment. Paint and fabric is very nice. The Millers are sending a patch kit.
By the way- I weighed it with wood strips on the rudder and elevator, and an unknown weight of gas in it, maybe 4-5 gallons. Also, the wind was blowing. And the scale read differently every time I bounced it. I just wanted a rough idea how much to trim. Now I'm waiting for weather or parts.
Bill Sullivan
lucien
PostPosted: Thu Jan 31, 2008 7:10 am    Post subject: Re: Firestar project Reply with quote
My .02...
My personal preference nowadays is to be legal and that's always what I suggest to others. OTOH, I try not to be anal retentive about the R&R's especially if they keep me completely grounded with a perfectly good flying machine.
I like many of us flew illegally for a long time - I don't regret it because I feel that I used my best judgment and flew only good equipment. But these days I simply prefer to be legal for both safety and "Da Man" reasons.
Much as I hate to say it, it's really quite true: many of the R&R' we fly under nowadays came about because someone flew an airplane into the ground. This especially applies to airworthiness; I hate to think of how much of AC 43.13 came about because of crashes and etc.
Good designs like the kolb, titan quicksilver, RV, etc are safe designs because someone got in the things and found the bugs.
A lot of what has been discovered over the years then comes down to us partially in the regs and partially in AC's like 43.13.
Even weight limits have a little sanity to them, the idea behind them being the greater the "commanded kinetic energy" the more qualified the pilot should be.
Finally, while I think R&R's can be a good thing, I don't want to live in a police state either. I'd hate to think that the max punishment for the most minimal infraction will always come about and I'll probably always resist that.
I'll still bend regs as necessary to insure the safety of the flight or even to enhance the quality of my flying experience within what I consider to be reasonable bounds. But that's just me.
As for part 103, that's still being hashed out all these years later and I can see both sides of it.
LS
LS
Titan II SS
JetPilot
PostPosted: Thu Jan 31, 2008 9:14 am    Post subject: Re: Firestar project Reply with quote
Being legal is good, and most of us make every effort to follow the spirit of the law. But good judgment and safety must always your primary concern.
I have never been ramp checked, these guys talk about Ramp checks, and maybe if you are flying into Oshkosh or Sun and Fun, or some other event you might get ramp checked, but chances are very low that it will you will ever get checked at the small airports that most ultralights fly out of.
The other thing you need to take into account is they are probably not going to be weighing planes without cause while doing ramp checks, has anyone ever been weighted in a routine ramp check ??? ( not event related, but standard run of the mill ramp check ) I seriously doubt it... If you have 10 gallons of gas (double the limit), or 2 seats (double the limit), that will stand out like a sore thumb, and is likely to get your a violation on a ramp check, just like driving 110 MPH in a 55 MPH zone will draw attention on the highway (double the limit).... In the case of your single seat statistic, with a 5 gallon tank and a single seat, will not likely generate any any unwanted attention. No one is going to be able to look at you plane and say "its 15 pounds overweight"...
So don't let some self righteous individuals tell you to go to an undue amount of work or make your plane less safe, by degrading the performance due to being 6 % overweight. I'm sure since this thread started, every one of these guys has driven 3 MPH over the speed limit. The problem here is, these guys have taken a position publicly on this list, and they are not about to let a new guy like me or anyone else point out that what they are suggesting is nothing short of stupid.
We are very fortunate that Richard and a couple others here are not in positions of authority. I can see it now, " sir, you were doing 58 in a 55 zone, I am going to give you a ticket " or " Sir, your plastic fuel tank has bulged and now holds 5.25 gallons of gas, which is 6 % over the limit, I am going to have to violate you ".
It does not matter how much they say " the law is the law ", or how how many "reasons" they give, worrying about 3 MPH, or .25 gallons, or even worrying about 15 pounds extra on an ultralight is just plain stupid and anal.
How many of these guys do think actually tell their friends to slow down and start self righteously preaching " the law " when they drive 3 MPH over the speed limit using all the same arguments they have been using here in this thread. I'm sure the response they would get would be something to the effect of "stick it where the sun don't shine" or " get out of my car "...
Mike
Kolb MK-III Xtra, 912-S
rowedenny(at)windstream.n
PostPosted: Thu Jan 31, 2008 10:58 am    Post subject: Firestar project Reply with quote
Please just drop it. As the lists DH, "Designated Hitman", Smile you just
refuse to quit.
You make it sound like others are suggesting we turn our wing struts down in
a lathe in order to make our planes lighter.
Dennis Rowe
PostPosted: Thu Jan 31, 2008 12:17 pm    Post subject: Firestar project Reply with quote
about 15 pounds extra on an ultralight is just plain stupid and anal. >>
Oh Yeah! And how does `Well officer, I only shot him a little bit` sound as
a defence.
Cheers
Pat (away for the next two weeks)
PostPosted: Thu Jan 31, 2008 12:26 pm    Post subject: Firestar project Reply with quote
Thats what happened in the UK. We had a good thing going which the
authorities treated merely as an extension of hang gliding. Then there were
a series of fatalities and Authority swooped. Luckily we had Anne Welch, a
long time gliding enthusiast who had helped fight the CAA to keep the
gliding movements training, safety, licensing etc in its own hands. She
realised that the microlight movement was in a similar position to gliding
in the 30`s and became the Chairman of the fledgeling organisation. She did
to a great extent what she and her husband had done for the Gliding
fraternity and kept us `comparitively` rule free..
Pat
PostPosted: Thu Jan 31, 2008 12:33 pm    Post subject: Firestar project Reply with quote
Good luck Bill,
its nice to be appreciated. .
i have no opinions about holes in spars. There are plenty on the list who are really very expert indeed. You will have to sort out which ones they are. Whatever you do, don`t believe them all. Some are , shall we say, not so clewed up as others.
cheers#
Pat.
Page 4 of 6
