cookwithgas
Posted: Wed Jan 30, 2008 6:16 am Post subject: Phase I Test Flight Testing |
Hi guys:
For those of you who can fly out of your FAA imposed triangle, what did you do after your 25 or 40 hours?
1. Notify the FAA that you are finished and wait for instruction?
2. Do nothing, just grab a passenger and fly south to some place warm?
3. Fill out a form, hire a notary, get it stamped and hang a copy on your wall?
4. Sell your airplane and start building another?
My FAA guy said to notify him when I was getting close to the 40 hours and I'm not sure why. He had me do some other non-standard things also and I'm wondering if this is necessary or if I can just grab a passenger and fly south.
Thanks in advance,
Scott Laughlin
Living in the Great Frozen North
601XL / Corvair Finished & Flying
www.cooknwithgas.com
Aerolitellc(at)aol.com Guest
Posted: Wed Jan 30, 2008 6:25 am Post subject: Phase I Test Flight Testing |
You make a log entry and have fun.
Start the year off right. Easy ways to stay in shape in the new year.
bryanmmartin
Posted: Wed Jan 30, 2008 6:56 am Post subject: Phase I Test Flight Testing |
I just logged the completion of the phase I testing in the aircraft
logbook using the prescribed language then signed and dated it with my
airman certificate number. No notary and no FAA notification.
cookwithgas wrote:
Hi guys:
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
Posted: Wed Jan 30, 2008 10:06 am Post subject: Phase I Test Flight Testing |
Hi Scott,
In your aircraft log, place an entry that says:
I certify that the prescribed flight test hours have been completed and
the
aircraft is controllable throughout its normal range of speeds and
maneuvers to be
executed, has no hazardous characteristics or design features, and is
safe for operation.
This aircraft operating data has been demonstrated during the flight
testing: Speeds Vso =__
Vx = __, Vy = __, and the weight = ____, and CG location = __ in. at
which they were
obtained.
Signed ___________________ Date ______
That's just about it. Then do some serious destination flight planning.
Congratulations Scott,
cookwithgas wrote:
Hi guys:
Thanks in advance,
Scott Laughlin
http://forums.matronics.com/viewtopic.php?p=161347#161347
cookwithgas
Posted: Wed Jan 30, 2008 1:34 pm Post subject: Re: Phase I Test Flight Testing |
Thanks Larry:
Your website and project encouraged me tremendously while I was building.
Thanks for all the help,
Scott Laughlin
601XL / Corvair
Finished & Flying
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Wed Jan 30, 2008 7:30 pm Post subject: Re: Phase I Test Flight Testing |
Scott,
First I wanted to congratulate you. Great job!
As to your question. I guess I'm confused by the responses, and it's probably my misconception. I thought that before you finished your X number of hours of phase 1 testing, the FAA issued a conditional airworthiness certificate, that limited you to flight testing only. And it was only after completion that they issued a normal airworthiness certificate. I assumed the limitations on the conditional certificate would stipulate NO passengers.
I haven't finished building, so I ask, Is that incorrect?
Dan
| cookwithgas wrote: | Hi guys:
Thanks in advance,
Scott Laughlin
www.cooknwithgas.com |
_________________ Scratch building XL with Corvair Engine |
Gig Giacona
Posted: Thu Jan 31, 2008 7:02 am Post subject: Re: Phase I Test Flight Testing |
Not there yet but the AW limitations I have seen were written in a way that created the two phases with one phrase.
| leinad wrote: | Scott,
Dan |
601XL Under Construction
japhillipsga(at)aol.com Guest
Posted: Thu Jan 31, 2008 9:51 am Post subject: Phase I Test Flight Testing |
Scott, I just started flying paxs. Nor was I requested to notify anyone other than my records and log books. Course I had a Great DAR instead of the Federal Government employee/bureaucrat to deal with so it's your call. It maybe he was just concerned and wants a friendly/unofficial update? It could happen. Hope to see you at S n F this April and best regards, Bill of Georgia
Posted: Thu Jan 31, 2008 10:52 am Post subject: Phase I Test Flight Testing |
On my two other homebuilts I was given Phase one and Phase two at the same
time. AFTER completion of Phase one I signed the logs and went into the
second Phase which was a permanent thing.
SW
Posted: Thu Jan 31, 2008 11:36 am Post subject: Phase I Test Flight Testing |
steve,
you are correct, that is the way its done. Some guys are confusing Phase two as some fly off requirement.
Juan
bryanmmartin
Posted: Thu Jan 31, 2008 12:46 pm Post subject: Phase I Test Flight Testing |
After my airworthiness inspection, the DAR gave me the pink copy of the
airworthiness certificate and the operating limitations which authorized
me to start the Phase I testing of my airplane. A few weeks later I
received the permanent airworthiness certificate from the FAA. Later,
when I completed the phase I testing, I signed it off in my aircraft
logbook, as specified by the operating limitations, and transitioned to
Phase II. There was no "conditional" certificate issued. No further
contact with the FAA was necessary.
leinad wrote:
Scott,
Dan
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
leinad
Posted: Thu Jan 31, 2008 7:41 pm Post subject: Re: Phase I Test Flight Testing |
Bryan,
And everyone else that helped explained it. Thanks! I'm glad I got that misconception out of the way.
Dan Dempsey
| bryanmmartin wrote: | After my airworthiness inspection, the DAR gave me the pink copy of the
leinad wrote:
Scott,
Dan
Bryan Martin
Zenith 601XL N61BM
Do Not Archive |
