rlowe(at)speedway.ca Guest
Posted: Wed Jan 30, 2008 7:20 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Hi, I've purchased a partially complete Europa a little over a year ago and had to put it storage until my garage/workshop was re-vamped in order to build the kit. It is now to a point to where I can start moving my kit into it and start working on it.
I have question about the different devices used to measure the epoxy and wondering what most builders have done in the past. The cheapest of course is to make the Europa mechanical balance which should be no problem (is it quick and easy to use during a layup?) but I'm leaning towards either a Ohaus / Sartorius digital scale with a resolution of 0.01gm (do I need that much precision or can I get away with a lower cost 0.1gm unit?) OR a ratio pump like a Glenmarc Portionator MBT-JR from A/S which is the most expensive of the all the options (is it worth the cost for ease of use?).
I live in Canada so I will be using Aeropoxy resin (100:27 by weight or 3 to 1 by volume).
I would appreciable any feedback/experience that you have that would help me make up my mind!
Thanks, Roger
Visit - www.EuropaOwners.org
jimpuglise(at)comcast.net Guest
Posted: Wed Jan 30, 2008 8:37 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Roger-
I think you'll find that most people use a scale. I have an Ohaus which read to 1/100 of an ounce. Your mixing needs to be very precise and you will do it often, so an easy to use and accurate scale is important. I throw a sheet of plastic over it to protect it and put the cup on before it is turned on and use bottles like ketchup is served in in restaurants to dispense epoxy and hardener. If I go a bit over, a paper towel can be used to "wick" a little until it is just right. I think the scale is a little over $ 100 but well worth it.
Jim Puglise, Punta Gorda, FL
[quote] --> Europa-List message posted by: "Roger Lowe"
working on it.
digital scale with a resolution of 0.01gm (do I need that much nd muc [quote][b]
Posted: Wed Jan 30, 2008 8:48 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Quote: | The cheapest of course is to make the Europa mechanical balance which
Quote: | (is it quick and easy to use during a layup?)
Roger,
I've used the standard balance design with, I believe, excellent
results. E04 will give you the proper lengths for Aeropoxy proportions.
I excercised some care in building mine to minimize friction. I find it
works like a charm.
I like the fact that I can pour out as much resin as I think I'll need
and easily match it up with the correct amount of hardener...the
balance registers to an accuracy (of say, a couple drops of hardener)
which I find astonishing.
Happy building...welcome to the list,
Fred
believed to be clean.
Posted: Wed Jan 30, 2008 10:38 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Roger...one further thought re: my post.
I've not attempted to reuse resin cups as I found early on that as the
weight of the used but (somewhat) empty cup varied enough to upset the
balance point...rather than futzing w/ the location of the add on
balancing piece (I've used a large flat washer) every time I do a mix,
I zero out the balance w/ clean resin and hardener cups and once done,
it remains balanced.
Fred
Roger,
proportions. I excercised some care in building mine to minimize
friction. I find it works like a charm.
Fred
davedeford(at)comcast.net Guest
Posted: Wed Jan 30, 2008 11:06 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Roger,
You will find people who swear by each of these approaches, so I won't try
to tell you which is best. We used digital scales with 0.1 gram resolution
and found them to be quite satisfactory, though I wouldn't recommend less
resolution. Our original scale (an Ohaus Scout) died after a few years of
excellent service, and we have used a couple of cheaper models since. For a
staggering selection of scales, check out www.americanweigh.com.
Even the cheapest pocket-size scales would probably have good enough
accuracy, but you need a large enough weighing platform to hold your mixing
cups easily. (You will often be in a hurry when weighing epoxy, and spills
are a real pain.) Be sure that the scale stays on for long enough to zero
the cup weight, weigh the resin, and then weigh the hardener (even with some
interruptions) before it turns off to save its battery. Not a problem with
AC power, but some of the small scales with tiny batteries get in a hurry to
shut down.
Keep in mind that absolute accuracy is not needed for mixing applications,
only good linearity. This can be tested precisely even without accurate
calibration weights. Just weigh anything and note the result. Then replace
the first item with something else, and zero out the reading. Adding the
first item to the platform should result in exactly the same reading that
you got when weighing it by itself. The two objects together need only to
remain within the scale's range.
Remember also that you will frequently have to mix Redux/Araldite 420/???
with good precision, and it's ratio will be different from the layup epoxy,
so a mixing pump or fixed 100:27-ratio balance won't do this job. A digital
scale is a bit like the digital level or close-quarters drill that you buy
for one specific job, and then find that you use it for many other things.
Dave DeFord
N135TD
craigb(at)onthenet.com.au Guest
Posted: Thu Jan 31, 2008 3:13 am Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
I have used digital scales with great success also, but ran out of Ampreg
and so switched to West Systems and it came with
ratio pumps that replace the caps on the bottles. Personally I have found
the two separate pumps much faster and easier than
using the scales, but i am past the really big layups and for big lots the
pumps may be a pain, you will need the scales or balance
for the araldite 420, just dont forget the different ratio required.
craig
Posted: Thu Jan 31, 2008 3:56 am Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Hi! Roger.
I exclusively used a Ohaus digital scale.
For me it was easy since I decided how much of combined epoxy I wished
to make at one mix (Not more than say approx. 25gm because of exotherm
likleyhood).
Zero the unit with my mixing cup and mixing stick on the bed. Carefully
pour say 5gm of hardener in, follow by pouring in epoxy to make up to
25gm this way, so long as you know your 5X table, is foolproof. For
subsequent mixes following immediately on I used the same mixer cup and
stick but re-set the scale before starting each mix and be sure to
re-mix any dregs of the original mix with the new mix. So you are using
as clean a new mix every time.
I'm quite sure someone is going to tell me I was incorrect by method but
there you have it.
Have fun
Bob Harrison G-PTAG (Europa Kit 337 originally 3300 Jabiru now with
Rotax 914 and intercooler 600 hours)
rampil
Posted: Thu Jan 31, 2008 6:57 am Post subject: Re: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pum |
Tenth of a gram is more than adequate for mixing resin. Most batches
for layups will be between 30g and 100g, mixed. More than that
may exotherm in the cup. A scale that gives you 0.5% is way better than necessary since 5% is probably just fine. A scale with 0.01 gram resolution
is a fragile lab instrument, not a working shop instrument useful for
production work. It would waver with air breezes.
loboloda(at)execulink.com Guest
Posted: Thu Jan 31, 2008 7:26 am Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Hi Roger,
I'm located in London, Ont, and have a completely refurbished epoxy
pump, that was used by Chris Staines
in his build, I would be happy to sell it for about the same price as
a scale.
I used a scale for my build,and found it to be quick and easy to use.
The cheapest place to find an electronic scale is in a drug
paraphernalia store!
A few years ago I spoke to the Aeropoxy reps at Oshkosh, they were
clearly amused by anyone
bothering to measure to the nearest tenth of a gram - off the record
they indicated that the tolerance
levels for a proper cure are quite high. I tended to end up a little
short of hardener in each batch, their
suggestion was to just short a bit on the hardener, on each mix.
Dave A061
519-666-0480
Thanks, Roger
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Thu Jan 31, 2008 4:31 pm Post subject: Re: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pum |
One thing about "strength" verses mix accuracy is the current Europa design does not have us building many (or any?) strength-critical components.
Fred F.
hagargs(at)earthlink.net Guest
Posted: Thu Jan 31, 2008 6:50 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
I have been using a standard triple beam balance for years. Very
mechanical and reliable, Ohaus makes a nice one with taring capability.
Just like they used in high school science class. Or by the stoners in
the Air Force barracks. This was the 70's
Steve Hagar
A143
Mesa AZ
Quote: | [Original Message]
Date: 1/30/2008 8:24:24 PM
Subject: Epoxy Measuring - Balances vs Digital Scale vs
Ratio Pump
to 1 by volume).
me make up my mind!
Posted: Thu Jan 31, 2008 7:48 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Everyone,
Thanks for the overwhelming response to my query. From the response the majority of you have used or are using a digital scale, so I will most likely go that route. I really appreciate the extra time and effort for the responses you gave as to the use of each apparatus and especially the digital scale. Looks like I don't have to spend as much money as I thought. Very very helpful!
On a final note, I've sort of been lurking in the background in this user group for a while now, trying to learn all I can before I take the first stab at making the "wheel chock", I have to say that I'm always amazed at the wealth of knowledge and experience that exists here. Much better than a text book!
Thanks again.
Roger
A252
