hotwheels
Posted: Tue Jan 29, 2008 8:31 am Post subject: Z Diagram Questions |
Hello,
I'm an RV10 builder with a bunch of questions regarding the Z diagrams. Sidebar: I really appreciate the obvious amount of work required to put these together. I'd hate to think how much time and $$ would be wasted rolling my own electrical system without leveraging this resource.
Jay
* I have in mind using two 17AH batteries to be mounted in the battery mount back behind the baggage compartment. What's connected from here is up for grabs.
* The current plan is to use one electronic ignition and one traditional mag with glass panel (and a few steam gauge backups). Others have done this successfully, so this shouldn't be breaking too much new ground. I believe my choices are pointing to using either Z-14 (Dual Battery/Alternator/Split Bus) or Z-19RB (Dual Battery/Single Alt/Rear Batt).
* Z-14 is obviously way more expensive, has more moving parts and appears to be overkill. However, the Z-19RB (5/4/07) has shows 5 engine/dc power switches as compared to 3 required for Z-14. In addition, Z-19RB appears to use an obsolete/unavailable part (ack!) AEC9005-101 low voltage module. I found another Z-19 cousin while pawing around called FOLDOUT4.DWG. This one uses the LR-3 and appears to be a bit more simple compared to the Z-19RB. Is Z-19RB "dated"?
Q1: Z-14 diagram (rev 5/9/06) strangeness... Both AUX & Main contactors are shown with 4AWG in and out of the primary terminals. Strangely, the Crossfeed contactor has 2AWG out (to Main Batt Contactor) which then uses 4AWG going forward to the Starter contactor. 2AWG is shown from Starter contactor to Starter.
| Quote: | >> It seems like 2AWG should be used consistently (without mixing 4AWG in series) to carry high current loads forward? The REAR Battery contactors are close to batteries, but the Crossfeed contactor is ~15 feet away on the engine side of the firewall close to the Starter contactor. Was Z-14 orginally created assuming forward battery placement?
Q2: General ALT fuse question: What's the rationale behind how to size ANL fuses (maybe max amps - 10 or something)? The fuse protects the wire, right? So are we assuming the purpose of ANL is to protect against possible runaway ALT operation? Under what conditions might this scenario occur? Are ANL slow blow fuses? If so, why would one use those in general? Note 10 didn't go into enough detail for inquiring minds.
Q3: Some Z diagrams show the LR-3 ALT Controller "Volts Warn" light with a push-to-test switch. I would think the lamp would light whenever batt power is applied to the LR-3, but the ALT is not yet running. Is PTT really necessary (it's yet another switch)?
Q4: A number of Z diagrams show an inline current sensing resistor (w/ voltage output). Are builders exposing voltmeters on their panel, plumbing volts to EFIS display or something else? I haven't seen lots of panels with voltmeters hanging off them except in spam cans... Knowing current state is obviously a great indicator of ALT health.
Q5: What's your opinion on solid state (i.e. MOSFET) contactors? Are they ready for prime time? Aircraft Spruce lists one on their website, but no pricing is shown (I smell problems). How long should steam guage contactors last under normal operation? http://www.aircraftspruce.com/catalog/elpages/superSwitch.php
Q6: Why do B&C alternators all use external regulators? Are there safety and/or MTBF factors to consider as opposed to internally regulated units? The external LR-3 really add to the total $$.
nuckolls.bob(at)cox.net Guest
Posted: Tue Jan 29, 2008 7:03 pm Post subject: Z Diagram Questions |
At 08:24 AM 1/29/2008 -0800, you wrote:
| Quote: | Hello,
Jay
up for grabs.
Why two?
| Quote: | * The current plan is to use one electronic ignition and one traditional
First, consider Z-13/8 with one battery and tell us how
it falls short of a perceived requirement. If you're
planning any form of non-traditional aircraft ignition,
consider a p-mag.
| Quote: | Q1: Z-14 diagram (rev 5/9/06) strangeness... Both AUX & Main contactors
Z-14 is not appropriate for 99% of the OBAM projects
under construction . . .
| Quote: | Q2: General ALT fuse question: What's the rationale behind how to size ANL
Fuses protect wires only and have no value in
mitigating a runaway alternator condition. A runaway
alternator is generally incapable of opening the
b-lead protection under any conditions.
| Quote: | Q3: Some Z diagrams show the LR-3 ALT Controller "Volts Warn" light with a
Only if you know how to interpret what it
displays. See chapter on instrumentation.
| Quote: | Q5: What's your opinion on solid state (i.e. MOSFET) contactors? Are they
| Quote: | <http://www.aircraftspruce.com/catalog/elpages/superSwitch.php>http://www.aircraftspruce.com/catalog/elpages/superSwitch.php
Don't know how to answer this. I've ssen them last
20 years with no problems and I have some rental
airplanes that got replacements in less than 5 years.
The best answer is that return on investment for these
devices is good. A failure tolerant architecture
makes contactor failure a cost of ownership issue
and not a flight safety issue. That's what I would
use if I were building.
There are no mosfet contactors suited for both
loading and charging a battery . . . mosfet
devices are decidedly one-way streets.
| Quote: | Q6: Why do B&C alternators all use external regulators? Are there safety
This is discussed at length in the archives, on
the website articles and chapters in the 'Connection.
At present, there is no practical way to make an
internally regulated alternator function in
the same manner as externally regulated machines
have and still to perform in aircraft. I'm working
on it but my 20-hour a week consulting task has
morphed into another career! See:
http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
hotwheels
Posted: Tue Jan 29, 2008 10:11 pm Post subject: Z Diagram Questions |
Why two?
| Quote: | >> Assumming dead alternator... The goal is for battery (or batteries) to provide adequate power to avionics & ignition system to safely complete flight. Hopefully, the total available amp-hour capacity exceeds available fuel supply. The notion is that two batteries provide redundancy if one proves incapable of providing adequate performance. Rotating one out at each annual reduces dud factor.
<snip>
First, consider Z-13/8 with one battery and tell us how it falls short of a perceived requirement. If you're planning any form of non-traditional aircraft ignition, consider a p-mag.
| Quote: | >> Z-13 is an attractive setup. However, my understanding is that p-mag devices aren't available for 6 cylinder (e.g. Lycoming 540) engines. I thought they were only used on 4 cylinder ones. Therefore, I have not considered Z-13 as a viable option. Z19RB still seems to fit.
Z-14 is not appropriate for 99% of the OBAM projects under construction . . .
| Quote: | >> It is overkill. What are the characteristics of the 1% that Z-14 would be good for? Dual electronic ignition w/ EFIS-only avionics seems a likely candidate.
Q2: General ALT fuse question: What's the rationale behind how to size ANL fuses (maybe max amps - 10 or something)? <snip>
Fuses protect wires only and have no value in mitigating a runaway alternator condition. A runaway alternator is generally incapable of opening the b-lead protection under any conditions.
| Quote: | >> Okay, but what size ANL is appropriate for 60A alternator? Something less than 60A ANL? I can't imagine ever pulling anywhere close to 60A total. Dumb question - Does a 60A alternator put out 60A continuously or does its output vary depending upon other factors?
hotwheels
Posted: Wed Jan 30, 2008 5:44 am Post subject: Re: Z Diagram Questions |
Please ignore my previous post regarding ALT output current. I believe the regulator samples voltage and then controls Field lead to make generator (ALT) output current up to the rated capacity of the device.
Jay
Posted: Wed Jan 30, 2008 6:21 pm Post subject: Z Diagram Questions |
At 10:07 PM 1/29/2008 -0800, you wrote:
| Quote: | * I have in mind using two 17AH batteries to be mounted in the battery
up for grabs.
Why two?
If you have a vacuum pump pad open, an 8A
alternator is a whole lot lighter than
a second 17 a.h. battery, has indefinite
service life and unlimited energy for
continued flight.
| Quote: | <snip>
Z-19 is for electrically dependent automotive
conversions that CANNOT have a second alternator.
| Quote: | First, consider Z-13/8 with one battery and tell us how it falls short of
aircraft ignition,
consider a p-mag.
No. Z-13/8 can be used with ANY combination of ignition
systems. For the lightest weight, lowest cost of ownership
and highest reliability, Z-13/8 with one battery is your
best choice.
likely candidate.
No. A Lancair IVP with full up IFR panel both
sides and intended to be used in a manner that
pushes the comfort zone for all weather flight.
Since that drawing was published, I've had only
3 or 4 readers who were building that kind of
airplane with that kind of mission.
Look at the specs for an ANL published at:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
An ANL35 would carry the full output of a 60A alternator
indefinitely. ANL devices are not fuses in the classic
sense. They're designed to protect against hard faults
against batteries (read 1000+ amps). They don't have to
be calibrated with the same precision as the classic fuse.
It's easy to find an 60, use that.
hotwheels
Posted: Thu Jan 31, 2008 2:22 pm Post subject: Re: Z Diagram Questions |
continued flight.
>> I do have one and I will consider this option.
>> That's fairly obvious once you understand what ECU and EFI acronyms mean... However, the diagram nicely showed a rear battery mount just like the RV10 requires (it's nose heavy). I had a lot of confusion until someone pointed out to me that, in general, Z diagrams were written from the view point of airplanes that use front-mounted batteries. It's not always easy to tell which is which as "RB" only appears in the -19 as far as it could see.
best choice.
>> I agree in principle that this would be the best choice. However - I spoke with the P-Mag guys and the 6 cylinder version is -not- a shipping product (or anytime soon either). Since vaporware isn't a good power source, I'll build my electrical system to not preclude this as a future upgrade.
>> Maybe, but I'm willing to bet there are more than a couple of RV10 builders considering this route. Are you guys out there lurking?
>> Thanks. It's a bit overwhelming how many documents are available. I'm not complaining as it's better to know the information must be out there than to simply "guess" and be sorry later!
hotwheels
Posted: Thu Jan 31, 2008 2:36 pm Post subject: Re: Z Diagram Questions |
One more question... The Z-19RB battery location is the same as for the RV-10. Do you see any real advantage of running a #2AWG ground forward to the forest of tab in a metal airplane rather than grounding locally? There's plenty of conduit space space in my fuse, but would rather save the weight as #2 is pretty heavy. I'm planning on running #2AWG forward to the starter...
Jay
Posted: Fri Feb 01, 2008 6:09 am Post subject: Z Diagram Questions |
At 02:36 PM 1/31/2008 -0800, you wrote:
the starter...
Jay
See
http://www.aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
( -Thomas Paine 1776- )
bcondrey
Posted: Fri Feb 01, 2008 6:36 am Post subject: Re: Z Diagram Questions |
Jay,
I'm using a Z-14 in my RV-10. I have dual electronic ignitions and an all electric panel (but with 2.25" ASI and ALT for backup). Given my absolute dependence on having juice flowing, it wasn't that much of a leap from Z-13/20 to Z-14. I have an electronic ignition on each battery bus and the panel "stuff" is split between the buses. When I did the allocations to each bus it was with consideration of what would happen "if". Given that, I can lose one bus in its entirety and still not be sweating even if I'm in the clag. Granted, if that happens I'll get on the ground and figure it out but it will be with the comfort of being able to pick which airport and approach I'll use.
Looking at actual measured panel loads, it would be no big deal to downsize from a 60A main alternator to a 40A and the vacuum pad alternator from 20A to 8A. That would probably more than offset the additional cost/weight of the second battery, 2 contactors and related wire while still retaining huge redundancy.
Bob #40105
Posted: Fri Feb 01, 2008 6:44 am Post subject: Z Diagram Questions |
At 02:22 PM 1/31/2008 -0800, you wrote:
continued flight.
??? What consideration of physics and operational
philosophy prevents you from doing this right
now? How does a second battery become more attractive
than an engine driven power source that is lighter,
performs better (unlimited energy, practically
zero maintenance) and a fraction of the cost of
ownership?
| Quote: | Z-19 is for electrically dependent automotive
as it could see.
You can mount the battery(ies) in the back for ANY
of the Z-figures. If you're selecting Z-19RB just
because of where the battery goes, then it's
not clear that you understand what the z-figures
are intended to illustrate.
| Quote: | Z-13/8 can be used with ANY combination of ignition
best choice.
upgrade.
Don't understand. Conversations with Emagair have
nothing to do with your architecture decision.
ANY electronic ignition including Emags will
operate happily from any source of 12 volts be
it one of the z-figures . . . or a 12-v lantern
battery. If you "agree in principal" which I
presume is an acknowledgement of value for
seeking the elegant solution, then what information
are you working with that makes the less elegant
solution more attractive?
| Quote: | A Lancair IVP with full up IFR panel both
Conversations with other RV10 builders have
What failures do you anticipate and under what
flight conditions that you now believe Z19RB
or even Z14 is a better choice than Z13/8?
This is the discussion that should drive choice of
architecture.
But that illustrates my whole point. There is
a wealth of published data out there to help you
make considered decisions based on understanding
of simple-ideas from which repeatable experiments
(useful inventions) are assembled. I totally agree
that "guessing" is bad policy. But "going with
the flow" may not be much better.
If it's "overwhelming" to exploit these resources
to augment your own understanding, then you're
reduced to decision making by consensus.
Problem is, those in which you place your trust
may be no better informed than you choose to
be. This places you in the position of doing
what feels best. The result could become the
equivalent of using a dump truck to tow your
trash down to the curb or using a back-hoe to
plant petunias. They DO get the job done but
the cost of ownership is much larger than it
needs to be.
Know that a tiny fraction of bad days in the
cockpit resulting in bent airplanes and/or
people have root causes in electrical system
problems. The vast majority of those events
that ARE unhappy could be mitigated if not
eliminated a little preventative maintenance
or improved understanding. Virtually all of
the dark-n-stormy night stories I read and
accidents I've investigated revealed severe
lack of understanding . . . a condition that
is the EASIEST to avoid and MOST likely to
have reduced or even prevented the scenario
from going to it's unpleasant conclusion.
Hundreds of thousands of TC aircraft have been
successfully flown in the conditions you're
anticipating for nearly 100 years. This largely
event free outcome is in spite of being burdened
with crummy batteries, poor preventative
maintenance and generators/alternators that
were not much more robust than the batteries.
If you take a stock 1970 C-172 and do nothing
more than add low volts warning and put in
a PROPERLY MAINTAINED RG battery and top
of with some understanding of system physics,
I suggest that virtually ALL the dark-n-stormy
night stories in which this genre'of electrical
system has center stage would never have been
written.
Now we have alternators that run past TBO
on engines, second alternators that provide
unlimited endurance, and the freedom to craft
architectures that optimize performance while
suffering any failure of a component. As OBAM
aircraft builders, we're encouraged to understand
things about our airplanes that our spam-can-bound
brothers are NOT required to know.
This is an opportunity to take out lots of
weight, cost and $time$ to maintain while boosting
system reliability to numbers the TC guys
will be hard pressed to achieve . . . EVER.
That's what we're all here for. Not a pool of
consensus in which one simply puts a dip-stick.
This List is where one can find assistance in
achieving lowest weight, lowest volume, lowest
parts count, lowest cost of ownership, and
highest system reliability based on an OPTIMAL
combination of simple-ideas and repeatable-
experiments.
Overwhelming? Sure . . . we are ALL there
too at some point in our experiences.
MauleDriver(at)nc.rr.com Guest
Posted: Fri Feb 01, 2008 9:38 am Post subject: Z Diagram Questions |
At 06:36 AM 2/1/2008 -0800, you wrote:
<bob.condrey(at)baesystems.com>
Jay,
Bob #40105
A considered analysis of a repeatable experiment.
Thank you.
