		Guy Buchanan
				 Posted: Thu Jan 31, 2008 9:31 pm    Post subject: Replace Needle? |
				All 582 drivers, past and present,
          I'm doing my 150 hour check and the book says I should
 change the needles and needle jets. Should I? Or does this date back
 to the days before the needle O-rings? Do these wear out from
 vibration? Anything else I should change out at 150 hours?
 Guy Buchanan
 San Diego, CA
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Deceased K-IV 1200
A glider pilot too. |
		Fox5flyer Guest
				 Posted: Fri Feb 01, 2008 4:50 am    Post subject: Replace Needle? |
				Guy, vibration does cause wear to the needles, needle jets, and slides, but
 it takes A LOT more than 150 hours to cause it, IMO.  I would save that sort
 of thing for when you do the major overhaul.
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 355+ TT
 "The aim of an argument or discussion should not be victory, but progress."
 - Joseph Joubert
          I'm doing my 150 hour check and the book says I should change the
  needles and needle jets. Should I? Or does this date back to the days
  before the needle O-rings? Do these wear out from vibration? Anything else
  Guy Buchanan
  San Diego, CA
		chenoweth(at)gwi.net Guest
				 Posted: Fri Feb 01, 2008 5:40 am    Post subject: Replace Needle? |
				Guy,
 On the subject of 582 carburetor maintenance - I bought and installed the
 carb "rebuild" kit at about 200 hours (this past summer).  O-rings and stuff
 and two viton tipped float chamber valves.  Then all hell broke loose.  At
 idle, gas was pouring from the vents and anywhere below 5000 things ran very
 poorly.  There were some suggestions that the engine was vibrating too much
 causing the problem but several local two-stroke people and a video clip to
 Lockwood got me past that explanation.  Over a period of days I eventually
 replaced the new float valves with my old ones - problem solved.  It turned
 out that Bing or Rotax had increased the stiffness of the little springs in
 the valves and that caused them to not seat as well.  From what I've learned
 recently the change was related to a 912 problem not a 582 problem and that
 now they've settled on valves with springs intermediate in stiffness to old
 and new.  Meanwhile I'm sticking with my old ones.
 Bill
 IV-1200
		dave
				 Posted: Fri Feb 01, 2008 5:04 pm    Post subject: Re: Replace Needle? |
				 	  | Quote: | 	 		  All 582 drivers, past and present,
 Guy, I would do nothing but check everything  including  carb sockets and change gear box oil if you have not in the last 150 hours.
 change fuels lines every year or 2.
 My  current 582 is was installed june 2006 and is pushing 400 hours and current spark plugs almost 150 hours , change exhaust gaskets twice and NOTHING ELSE.
 Older engines might need cranks seals  if over 5 years old.
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Guy Buchanan
				 Posted: Fri Feb 01, 2008 9:40 pm    Post subject: Replace Needle? |
				At 05:04 PM 2/1/2008, you wrote:
  	  | Quote: | 	 		  Guy, I would do nothing but check everything  including  carb
 Thanks Dave,
          It looks like I've done all of that and more. I'm surprised
 you can go so long between de-carbs, since I've done it every 50
 hours and each time it seemed like I scraped off a good amount of
 stuff. My plugs also seem to gunk pretty bad. I'm running 100LL,
 Decalin, and Pennzoil in the oil injection. My rear banjo fitting
 leaks so I have a lot of oil in the intake when I start. I wonder how
 much that contributes. Any ideas?
 Guy
Deceased K-IV 1200
		dave
				 Posted: Sat Feb 02, 2008 9:10 am    Post subject: Re: Replace Needle? |
				 	  | Quote: | 	 		  My rear banjo fitting
 If you are getting oil in to your port then replace th Banjo,,,  there is a check valve in there that will allow this to happen when it becomes faulty
 about 27$ for one.
  	  | Quote: | 	 		  I'm surprised
 Decalin, and Pennzoil in the oil injection. |
 I run regular gas and oil injection . AV gas is not a good thing for 582s and I not sure if using Decalin helps stop crud , lead etc from depositing.
 Decarboning at 50 hours would only be advisable if you are running pre mix very rich like 30 to 1 maybe. My oil injection keeps mine  nice.  I don't think Pennzoil or my XPS mineral oil changes it all at but avgas certaily can help add to the gunk.
