		Mark.Summers(at)lwbref.co Guest
				 Posted: Sat Feb 02, 2008 8:07 am    Post subject: propeller slip clutch |
				My terminology is probably not correct, but does anyone use the slip-clutch on their prop on a 582? I have heard it will allow you to idle lower with less vibration. Looking for pro’s and con’s and where you would buy one. Thanks Mark
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dave
				 Posted: Sat Feb 02, 2008 9:15 am    Post subject: Re: propeller slip clutch |
				Slipper clutch, well on floats they would be an asset.
 yes you can idle your engine lower anytime
 BUT  and a BIG BUT   >>  You will gain one  hell of a lot of drag when it is windmilling.
 If you want one, I sell new  ones  I will have to look but I think they about 500$ or so.
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		msm_9949(at)yahoo.com Guest
				 Posted: Sat Feb 02, 2008 11:45 am    Post subject: propeller slip clutch |
				I have the RK400 clutch on my M2 Mark. Got it from LEAF ($470 then). I installed it for the very reason you cite, to reduce that crazy vibration at idle. It's supposed to engage the prop at about 2400 rpm. My problem is that since install, I haven't been able to adjust idle lower than about 2500. I've tried everything short of a carb mod that was suggested by someone on the list (check the archives for that).
   So, at least for me, it hasn't really done much. Also, in the back of my head lurks the concern that if I ever lose power, the drag created by the windmilling prop will greatly reduce my options. No small consideration.
   When I do my 300 hr rebuild, I'll probably pull it out and sell it.
 "Summers, Mark" <Mark.Summers(at)lwbref.com> wrote:
   [quote]              My terminology is probably not correct, but does anyone use the slip-clutch on their prop on a 582? I have heard it will allow you to idle lower with less vibration. Looking for pro’s and con’s and where you would buy one. Thanks Mark<?xml:namespace    [quote][b]
		clint_bazzill(at)hotmail. Guest
				 Posted: Sat Feb 02, 2008 12:31 pm    Post subject: propeller slip clutch |
				I have done tests with my Model IV-1200 using 912ULS with engine at idle and with prop stopped.  Would have to take a lot more care at measurements to see much difference.  Plan on doing that.  Clint
   	  | Quote: | 	 		    Date: Sat, 2 Feb 2008 11:40:20 -0800
 Subject: Re: propeller slip clutch
   	  | Quote: | 	 		    .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}     My terminology is probably not correct, but does anyone use the slip-clutch on their prop on a 582? I have heard it will allow you to idle lower with less vibration. Looking for pro’s and con’s and where you would buy one. Thanks Mark 	  | Quote: |
 arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
 p://forums.matronics.com
		LarryM
				 Posted: Sat Feb 02, 2008 3:24 pm    Post subject: Re: propeller slip clutch |
				Could there be a reason why your 582 is idling rough?  I use a 2 blade Culver 76" prop with a 3:1 C box.  I can idle clear down to 1400 rpm with no bad vibrations.  (in the winter)I've been as low as 1000 running smooth.  Mind you this is not routine, and it happened with a preheated  engine, and an air temp of about 15-20F.  I'm still trying to figure out the "perfect" idle mixture, but form my experience, I think suggested the idle jet is way rich.  I am currently using #45 ( 55 is the "book" figure), and it idles much better in the winter than summer.  I know that the Rotax idle is suppose to be 2000, but I thought that is in consideration of the A or B box, not engine.  (I always set 2000 to let it warm up.)  This summer, if it doesn't idle as nice as it does now, I plan to get a smaller idler jet.
   Hoping to provoke thought.......
 larry
		chenoweth(at)gwi.net Guest
				 Posted: Sat Feb 02, 2008 4:19 pm    Post subject: propeller slip clutch |
				Larry,
 I am using a 45 idle jet also but can't get the engine to idle as smoothly
 as you have.  I've found that there is a big impact of midrange set-up on
 idle.  In order to keep the egts in line in the winter I run fairly rich in
 the mid range and suffer with a fairly poor idle.  In that context I'm
 motivated to ask you what you are using for needle, needle clip position,
 and needle jet.
 Bill
 IV-1200
 Blue head 582
		Guy Buchanan
				 Posted: Sat Feb 02, 2008 6:22 pm    Post subject: propeller slip clutch |
				At 08:04 AM 2/2/2008, you wrote:
   	  | Quote: | 	 		  | My terminology is probably not correct, but does anyone use the slip-clutch on their prop on a 582? I have heard it will allow you to idle lower with less vibration. Looking for pro’s and con’s and where you would buy one. Thanks Mark |
          Love it. All pro and no con so far, though it's a little bit of a hassle if it's blowing hard. Just make sure you use a spinner so you can get out and stop it without killing yourself. Then you can lash it down. Today I had a bit of fun with it. One of our flight of 5, a Cessna 170, had a dead battery so they had to hand prop it in front of the restaurant. Once they got it going I ran up to my Kitfox and gave the prop a mighty heave, (with no one inside, of course,) and it looked like it started. A couple of Bonanza drivers parked next to me nearly soiled their shorts. I got a good laugh out of it.
          I've only got 210 hours so far so I can't speak to the longevity, but so far I wouldn't be without it.
  Guy Buchanan
  San Diego, CA
  K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.    [quote][b]
Deceased K-IV 1200
A glider pilot too. |
		Guy Buchanan
				 Posted: Sat Feb 02, 2008 6:35 pm    Post subject: propeller slip clutch |
				At 11:40 AM 2/2/2008, you wrote:
  	  | Quote: | 	 		  So, at least for me, it hasn't really done much. Also, in the back
          Not sure about the carb problem. That's a stumper, assuming
 you've tried all the obvious. What I've found with the clutch is that
 if I pull to idle during a descent, the clutch stays engaged and the
 prop drives the engine. (Got to watch that EGT!) The only way to get
 the clutch to disengage is to slow down until the engine drops below
 2400. Then the engine will drop to idle, (1500,) and the prop will
 wind up like crazy. I'm not sure what would happen in an engine out,
 but I'm betting the clutch would eventually disengage and I'd get the
 drag. One nice thing about my Kitfox is that the minimum sink occurs
 at a very slow 45-55mph. (The curve is almost flat from stall to
 55mph.) The prop will make less of a difference there.
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
		dave
				 Posted: Sun Feb 03, 2008 5:27 am    Post subject: Re: propeller slip clutch |
				 	  | Quote: | 	 		   One nice thing about my Kitfox is that the minimum sink occurs
 55mph.) The prop will make less of a difference there. |
 Guy,  It would be a good test to try some dead sticking with that prop/clutch combo.  I would best that you will get a faster decent rate with mags off totally dead stock.  once you  kill the mags just pull up nose to about 40 mph or so till the clutch dis-engages or you might have to stall it . I have never tried with a clutch setup but I only guessing .
 One more drawback of the clutch as you stated in previous post is that you cannot handprop.  I handprop alot when cold out as the started needs to spin about 270 rpm to get the ducati ignition to trigger a spark. at 250 rpm it will not fire. With  the 3 to 1 box  it will fire with handprop alot better I find.
		Fox5flyer Guest
				 Posted: Sun Feb 03, 2008 8:05 am    Post subject: propeller slip clutch |
				Larry, at 650' msl my 582 idled rough also.  The factory supplied #55 is
 just too much jet for the idle and when I spoke with Gerry at Greensky
 Adventures, he said it was a common problem and to go with the #45 which
 fixed the problem permanently--year round.  I suspect at higher altitudes an
 even smaller jet would be better.
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 355+ TT
 "The aim of an argument or discussion should not be victory, but progress."
 - Joseph Joubert
		thesupe(at)hotmail.com Guest
				 Posted: Sun Feb 03, 2008 10:56 am    Post subject: propeller slip clutch |
				About the slip clutch,  there was one posted for sale on Barnstormers 2 days ago.  Look under experiments.  Jim Chuk,  Avid MK IV, Jab,  Mn
 [quote] From: fox5flyer(at)idealwifi.net
  Subject: Re: Re: propeller slip clutch
  Date: Sun, 3 Feb 2008 10:58:14 -0500
  --> Kitfox-List message posted by: "fox5flyer" <fox5flyer(at)idealwifi.net>
  Deke Morisse
  Mikado Michigan
  - Joseph Joubert
				 Posted: Sun Feb 03, 2008 11:09 am    Post subject: propeller slip clutch |
				Sorry about the spelling,  look in experimentals
  [quote]  From: thesupe(at)hotmail.com
 Subject: RE: Re: propeller slip clutch
 Date: Sun, 3 Feb 2008 18:51:40 +0000
    .ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;}  About the slip clutch,  there was one posted for sale on Barnstormers 2 days ago.  Look under experiments.  Jim Chuk,  Avid MK IV, Jab,  Mn
  Deke Morisse
  Mikado Michigan
  - Joseph Joubert
		LarryM
				 Posted: Sun Feb 03, 2008 12:26 pm    Post subject: Re: propeller slip clutch |
				I "think" that I am jetted as follows: 165 main, 2.72 mid, 45 idle, clip #4, standard book needle.  850' msl Winter OATs  10F  EGT 1075-1110 at 50-6000 rpm.  Summer same except clip #3.  I say "think" because the clip position would normally be at 4 this time of year, but I didn't write it down.  The other jets are definite.
   I always find the idle mixture difficult to adjust - I can never hear a difference.  I usually just tweak it as the oat  temps warm up.  (robotically) This year I'm going to try just switching to a 40 jet, leaving the mixture screw as they are, as the 45 runs great when real cold.  The digital egt gauge reads with 25F from idle on up.
 larry
		akflyer
				 Posted: Sun Feb 03, 2008 1:09 pm    Post subject: Re: propeller slip clutch |
				I have been flying my brothers KF with the clutch and it is the shiznit.  On floats it is great as it does not try to run away from the dock / beach during warm up. A buddy has a B box on his Avid and it is alot rougher at idle especially when cold.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
				 Posted: Mon Feb 04, 2008 6:21 am    Post subject: propeller slip clutch |
				Larry,
 My jetting is the same as your except for a 2.74 with the needle in the
 fourth slot.  I tried a 40 idle jet and couldn't keep the engine running at
 idle so went back to 45.  My arrangement produces an ok idle at about 2000
 when the temps are in the 20s or lower.  In flight I'm getting about 1100 at
 these OATs.  Since I'm using the cheap analog EGT gauges I really have no
 clear idea what the temps are other than I hope I'm seeing something within
 100 degrees of what really is (the plugs look good).  I'm operating from OWK
 in Maine which is 270 msl.  I end up having to change main, needle clip, and
 needle jet each major season change (not to mention the inevitable prop
 pitch change) and I find it a real pain.  There are some two-stroke people
 here who don't change anything ever and seem to do fine.  So I'm hoping that
 when I install a 912S this summer at least this sort of problem will go away
 (to be replaced with problems as yet unknown, I suppose).
 Bill
 IV-1200
		LarryM
				 Posted: Tue Feb 05, 2008 6:37 am    Post subject: Re: propeller slip clutch |
				Bill.
   I wonder why you need to change so much with the season?  We go from a density altitude of about minus 1500' to plus 3000'.  I only have to change the clip position, and I'm trying for a better summer idle.  I have a fixed pitch prop.  It's funny how they idle better at 20F than at the summer temps.  That leads me to believe that it is too rich in the summer.  Perhaps the #40 is too small and can be adjusted by the mixture screws?
 larry
				 Posted: Tue Feb 05, 2008 11:50 am    Post subject: propeller slip clutch |
				Larry,
 I have wondered the very same thing for the four years I've been using this
 engine.  I've had conversations with just about everyone including Lockwood
 and other experts with no luck.  When I changed from a GSC 3 blade to an IVO
 medium two blade most of my problems with high midrange egts went away which
 left me with just the seasonal stuff.  I strongly suspect that the
 instrumentation (Westach) is not helping.  You may know that the
 temperatures seen on these EGT gauges are based on a temperature of 75
 degrees at the back of the instrument.  This makes for uncertainty given the
 cold winter temps around here coupled with the changing temp behind the
 panel during normal operation.
 Regarding the 40.  During the brief period I tried the 40 I tried to fix the
 too lean idle condition with idle air screw adjustments.  Didn't work very
 well so that's why I went back to 45.
 Bill
		dave
				 Posted: Tue Feb 05, 2008 7:01 pm    Post subject: Re: propeller slip clutch |
				When you say the plugs look good,  What colour are they?
 Running at 1100 F with the needle on bottom clip at 20 F ?  What RPM is that at ?
 What do you get static with the IVO Med and what is your WIDE open Throttle RPM ?
 Dave
  	  | Quote: | 	 		  Larry,
 Bill
 IV-1200
