		lucien
  Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
				 Posted: Fri Jan 25, 2008 4:00 pm    Post subject: Re: Regular Unleaded |
				So Lar, not to change the subject, but what are you going to do with your mark III out at KSAF?
 Dunno if you ever get out to the airport but I try to keep an eye on it, as I'm out at the airport all the time...  I usually stroll by to make sure nothing's hit it or anything's walked off....
 Sure would be great to have another flying light a/c out there, only a couple of us at this point. And that plane would be a sight. The controllers just loved the FS II when I had it....
 LS
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ LS
Titan II SS |
		biglar
				 Posted: Fri Jan 25, 2008 5:13 pm    Post subject: Regular Unleaded |
				It appears that it might start warming up a bit soon, and I'll be out
 there to start cleaning it up and preparing for a new engine.  Anyone
 want to buy 5 acres with a tremendous view in Yucca Valley, CA ??  Price
 is dropping for a quick sale.      When that sells, the new engine
 will soon come along.
 I still need answers to the questions in my original
 post.                Lar.
 lucien wrote:
  LS
  LS
  FS II
  http://forums.matronics.com/viewtopic.php?p=160510#160510
 Larry Bourne
 Santa Fe, NM
 Building Kolb Mk III
 "Vamoose"
 www.gogittum.com
 www.gogittum.com/blog
  _________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
		captainron1(at)cox.net Guest
				 Posted: Fri Jan 25, 2008 9:04 pm    Post subject: Regular Unleaded |
				Folks we had that discussion a couple of years ago. What I've done back then is take a bunch of nitrile o-rings and some other rubber parts including silicon and stuck them in a jar of E-85. There has not been any observed degradation in two years.
 What does it mean, I am not sure but some alcohol does not seem to destroy the regular rubber stuff that we buy in automotive stores. I guess we can start buying viton O-rings during replacements and that would solve the alcohol concerns.
 Ron (Arizona)
 ---- Dana Hague <d-m-hague(at)comcast.net> wrote:
 At 06:57 PM 1/24/2008, Ben Ransom wrote:
  	  | Quote: | 	 		  Do you have specific concerns wrt ethanol in a 2-stroke?
 I've been using 91 octane mogas, sometimes with ethanol.  I've not been
 aware of any problems other than if gas gets older than a couple months
 the engine is hard to start and I don't trust it.  I've assumed gas goes
 stale mostly because of other ingredients, not ethanol.
 There are concerns about ethanol's compatibility with rubber parts such as
 seals, fuel pumps, and carburetor parts.
 Gas goes stale because some of the more volatile components evaporate
 out.  That's one reason I use avgas in my Cuyuna (that and concerns about
 alcohol); avgas is much better controlled as to vapor pressure so it stores
 much better... I believe it's supposed to remain good for 2 years.
 -Dana
   The gene pool has no lifeguard.
 kugelair.com
		aoldman(at)xtra.co.nz Guest
				 Posted: Sat Jan 26, 2008 10:15 pm    Post subject: Regular Unleaded |
				In Newzealand I think we use the RON system. I have always either used 91
 lead free or avgas or a mixture of both . 500 plus hrs on 503s no problems.
 Only difference is that the 503 seems to run cooler on avgas and idle a
 little smoother .No performance difference.
                           Tony
                           MK111 classic
		R. Hankins
  Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
				 Posted: Sun Jan 27, 2008 10:39 am    Post subject: Re: Regular Unleaded |
				I have used both regular and supreme (premium) in my 503.  The regular seems to give me a little lower EGT's (about 40-50deg).  I use regular when I know the fuel will not be sitting in the tank for an extended period.  I use the premium when my schedule is hectic or the weather is iffy and I don't know when I will get to fly next.  I fill up after every flight to keep the tank full to prevent condensation.  I also use Sta-Bil as Larry C. mentioned.  It does a great job; even the left over premix in my empty cans smells fresh after several months.
  _________________ Roger in Oregon
1992 KXP 503 - N1782C |
		Arksey(at)aol.com Guest
				 Posted: Mon Jan 28, 2008 2:51 pm    Post subject: Regular Unleaded |
				In a message dated 1/24/2008 1:19:39 P.M. Eastern Standard Time,  jim(at)tru-cast.com writes:
   	  | Quote: | 	 		  Late    last fall and during a couple short flights this winter I used Regular    unleaded with no problems.  Does anybody else out there use regular    unleaded?  Ever had any problems?
 Jim
 N.    Idaho |
 Hi Jim,
      I have been using 87 octane in my 503 with no  problem...just fly and use it up...if you let it set around along time it will  lose some octane....Just set it on a 2 cycle forum at the sport expo, Phil  Lockwood put it on and he confirmed it...
  Jim swan firestar ll and enjoy flying it.  michigan
 Start the year off right.  Easy ways to stay in shape in the new year.
		Steve Garvelink
				 Posted: Mon Jan 28, 2008 5:11 pm    Post subject: Regular Unleaded |
				You guys need to start looking very closely at your fuel suppliers a lot are
 adding 10% ethanol to there fuel.  Recently all of the pantry kangaroo
 stores  in Tennessee started adding 10% to there stores. I am not sure if
 this is every where they are but they have 1600 stores nation wide.
 Srglink
		jim
				 Posted: Sat Feb 02, 2008 11:28 pm    Post subject: Re: Regular Unleaded |
				Six months ago I called the Distributor for Exxon/Mobil in Coeur d'Alene, Idaho and the owner confirmed they do not add ethanol locally for Exxon/Mobil stations.  He did say thay added 10% to the regular for a local independent gas station and sold it as mid-grade at the same price as their regular.  Adding a minimum of 10% gets them tax breaks and they are able to sell the oxygenated regular as mid-grade for the same price as their regular unleaded.
 He said fuel with 10% ethanol or more is required to be labeled at the pump in Idaho.  He also said nobody in his area (N Idaho) adds <10% ethanol because then they don't get the tax break.
  _________________ Jim
N. Idaho |
