Mil-W-5088L Wire Size Calculator spreadsheet
hotwheels
PostPosted: Sun Feb 03, 2008 12:35 pm    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
PRetty handy wire size calculator spreadsheet is attached. Has anyone used it before? I've been playing around with it some and it looks to be pretty accurate.
There may be a newer version, but I haven't yet been able to locate the author (Scott Dahlgren) to ask...
Jay
wire size.xls
 Filename:  wire size.xls
 Filesize:  83.5 KB
 Downloaded:  788 Time(s)
hotwheels
PostPosted: Wed Feb 06, 2008 12:13 pm    Post subject: Re: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
Weight? Who cares? The point is that one can use the spreadsheet to quickly compute Wire Size given Current (amps) and Length.
Jay
> Life is an estimate. This is one of those things that looks useful up
> front, but it's like counting calories. Naturally, the total weight of
> all your wire before the install will differ greatly after the install.
> The best approach might be to use this at the end. Collect all your
> receipts for wire purchases, subtract the waste and enter the balance.
> Ok, you'll have your estimated wire weight and now you can decide
> whether using that #2 cable for the #19 rear battery install was too
> heavy and then rip it all out Smile
echristley(at)nc.rr.com
PostPosted: Wed Feb 06, 2008 7:57 pm    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
Jay
It's not inconceivable that some builders would want to use the smallest
wire possible, but I would think that it would be to keep large bundles
to a manageable size more than weight concerns. To insure that I didn't
sell myself short, or waste wire, I created the spreadsheet at
http://ernest.isa-geek.org/Delta/Library/WireSelection.ods
You first input your ship's nominal voltage. Then for each device, you
input the round-trip wire run length and the amount of current the
device draws. It displays how much voltage will be available to the
device for each of several wire AWG sizes. The "best" size will drop
between 2% and 4% of the voltage in the wire. These choices are shown
as green. Those choices highlighted in yellow will drop between 4% and
5%. Anything that would drop more than 5% of the voltage in the wire is
likely to overheat, and is shown in red.
http://www.ronpaultimeline.com
tim2542(at)sbcglobal.net
PostPosted: Wed Feb 06, 2008 10:13 pm    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
What file format is that? EXEL won't open it.
Tim Andres
harley(at)AgelessWings.co
PostPosted: Thu Feb 07, 2008 4:41 am    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
Tim...
It's Open Office...you can get the free, open source program here:
www.openoffice.org
You might want to consider having that around as it is quite useful in
reading and writing to a variety of different program formats. But,
unlike Excel, Open Office WILL open it's competitors files!
From the description of Open Office on their website:
"the product is a multi-platform office productivity suite. It includes
the key desktop applications, such as a word processor, spreadsheet,
presentation manager, and drawing program, with a user interface and
feature set similar to other office suites. Sophisticated and flexible,
OpenOffice.org also works transparently with a variety of file formats,
including those of Microsoft Office"
Harley Dixon
Tim Andres
PostPosted: Thu Feb 07, 2008 5:43 am    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
Harley wrote:
Tim...
www.openoffice.org
Close, but not quite. Open Office is just ONE of the packages that
support ODF file formats. Word Perfect, Lotus Smartsuite and several
others also support it. Sun Microsystems also has a plug-in for the
Microsoft programs that will enable ODF.
PostPosted: Thu Feb 07, 2008 5:52 am    Post subject: Mil-W-5088L Wire Size Calculator spreadsheet Reply with quote
Tim Andres
ODF. It is an open format supported by a variety of vendors. Microsoft
has chosen not to support it, because they're afraid of the competition
in an open market, but there are a some plug-ins available that will
allow Excel to read it. Here are a couple:
http://sourceforge.net/projects/odf-converter
http://www.sun.com/aboutsun/pr/2007-02/sunflash.20070207.1.xml
