				 Posted: Mon Feb 04, 2008 2:15 pm    Post subject: G900X Size |
				Does anybody know if the G900X will fit in the standard size Van's -10 panel.  What is the vertical size needed for the G900X screens?
  Jesse Saint
 Saint Aviation, Inc.
 Cell: 352-427-0285
 Fax: 815-377-3694
		robin1(at)mrmoisture.com Guest
				 Posted: Mon Feb 04, 2008 2:49 pm    Post subject: G900X Size |
				Jessie,
                 We had some debate on making the panel 1” taller but I THINK we ended up with the standard height panel (big help). Photo on bottom of page:
 http://www.painttheweb.com/rv-10/avionics.htm
                 Maybe you can eyeball it by looking at the lower left & right cutout “ears” on the bottom of the panel.
 Robin
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
  Sent: Monday, February 04, 2008 2:11 PM
  Subject: G900X Size
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		stein(at)steinair.com Guest
				 Posted: Mon Feb 04, 2008 3:04 pm    Post subject: G900X Size |
				Hi  Jesse,
  It  will indeed.  The easiest way to look at the 900X screens is to take a  sheet of plain ole' office paper (8.5" x 11") and that's about the exact size of  the Garmin Screens.  Drop me a line off list if you need more detailed  info.
  Stein
  [quote]   --
		AV8ORJWC
				 Posted: Mon Feb 04, 2008 3:05 pm    Post subject: G900X Size |
				As I mentioned last week. Stein has done three.  See Robin Marks, Team RV and Dr. Peeler who is yet to surface here.  Pacific Coast is looking to do a fourth.  These are all dual G900’s with the dual Garmin 530A, 16 watts per output.  Columbia (Cessna) drove the decision to do a remote FMS unit which Team RV is showing at http://steinair.com/panels.htm.
 Stein has your dimensions.
  Subject: G900X Size
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
   [quote]   [b]
				 Posted: Mon Feb 04, 2008 3:43 pm    Post subject: G900X Size |
				In the interest of fair reporting we didn't/aren't doing Robins panel,  John Stark did/is.   That being said, Robin's panel is indeed a wee bit taller and in fact  isn't the standard Van's panel.  I helped John out on this CAD for this  panel, and in order to get the Sorcerer above the G900X's and still use the same  type of lower switch strip both the upper and lower panels had to be extended  slightly.  I don't know what the final measurements for Robin's panel were  (we didn't do it), but both the upper and lower pieces have been enlarged.   You'd have to ask John, but I'm pretty sure this panel is in fact a bit larger  than Van's standard.  The standard Van's panel is only 11.96" top to bottm,  and then you remove the area of nutplates and there is even less space to work  with.  The 900X's will fit in the upper piece standard panel, just not with  the Sorcerer above it.  Also, in order to get 2 rows of breakers in the  lower strip it also has to be enlarged as it's only about 1.49" from top to  bottom.  You need at least (or close to) 2.5" on that switch strip to get 2  rows of breakers in there.  An easy giveaway in the pics is the AML rocker  switches which themselves are 1.2" tall and if the lower strip were the same as  original there would be less than .2" above and below, where in Robin's panel  there is at least .5"-.75" above and below.
  Anyway, it an be done with Van's panel...just not easily.  I haven't  seen anyone use the original panel on the 900X's among the people I know  building them (I think we're on G900X RV-10 Panel #6 or 7 right now and we've not used the original panel once).  We don't  always post all pics of all panels we do on the web, because some people just  don't want others to see their N Number, name or panel on the net.  Some of  the guys getting 900X's I doubt we'll hear from on any list or forum....they are  just offline type of people.  I know that Avionics Systems as well as  Aerotronics also each have RV-10 G900X builds in progress as well.  It's a  small community with these 900X's and we were all down at Garmin a few weeks ago  for 900X training again.  We get to know each other quite well, and also  help each other out quite a bit working with these  things.
  I think they are perhaps more popular then  many people would realize, because a lot of the 900X customers aren't actively  involved in this or the VAF community.
  Have a great week and happy  building,
  Stein
  [quote]   --
