patreilly43(at)hotmail.co Guest
Posted: Mon Feb 04, 2008 2:57 pm Post subject: RK400 clutch 582 application |
Guy Bucahanan, You stated how much you like your 582 with the clutch. What about durning decent? Someone stated the clutch does't disengage and drives the engine. Can you comment on this and more on any drawbacks of the application. I know the benifits. Thank You
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Guy Buchanan
Posted: Mon Feb 04, 2008 6:03 pm Post subject: RK400 clutch 582 application |
At 02:54 PM 2/4/2008, you wrote:
| Quote: | | Guy Bucahanan, You stated how much you like your 582 with the clutch. What about durning decent? Someone stated the clutch does't disengage and drives the engine. |
That was me. Since I've never had an engine out or practiced by killing the engine I don't really know what will happen when the engine dies. I suppose it depends on whether I seize the engine, or run out of fuel, or loose an ignition module, or foul a plug. Other than the engine-out drag and the fact that it eventually wears out, (I don't know when,) I've found no problems.
Descent is Cessna-normal, unless you slow down so much that the prop disengages. Then the engine will drop to idle, (1500,) and the prop will windmill. The only way to do this is to slow to near stall speed.
I really like having it. Starts are instantaneous and reliable, indeed if I sit for any length of time waiting for clearance I shut down the engine. It engages readily, but you have to be at about 2800 for full engagement. Between 2400 and 2800 it slips. If you want to taxi slow you have to use brakes, or go back and forth between idle and 2800.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
akflyer
Posted: Mon Feb 04, 2008 7:20 pm Post subject: Re: RK400 clutch 582 application |
[quote="patreilly43(at)hotmail.co"]Guy Bucahanan, You stated how much you like your 582 with the clutch. What about durning decent? Someone stated the clutch does't disengage and drives the engine. Can you comment on this and more on any drawbacks of the application. I know the benifits. Thank You
Pat Reilly
Mod 3 Rebuild
Rockford, IL
The clutch will not drive the engine anymore than direct gears. The only draw back, is the fact that you cant stop the prop from wind milling in the case of an engine out, and if you battery is dead you cant prop it. Other than that there are NO drawbacks, only benefits IMO
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
avidfox
Posted: Mon Feb 04, 2008 9:19 pm Post subject: RK400 clutch 582 application |
"...you cant stop the prop from wind milling in the case of an engine out,..."
Leni,
Would it be possible to fabricate something like a simple helicopter style "rotor brake" for just such an occasion?
Has it been done before?
or...Is it a totally stupid idea?
Just thinking out loud here.....
Steve
84KF
akanka(at)kiamichiwb.org Guest
Posted: Tue Feb 05, 2008 5:56 am Post subject: RK400 clutch 582 application |
An opinion: It appears to me that the gearbox with a Sprague (or overrunning) clutch which is found in helicopters, on an engine drivetrain would be MUCH less drag in a dead engine situation than would a direct drive prop. A dead direct drive engine will windmill at normal glide speeds so long as the internal components of the engine are intact (speaking from experience). In order to stop a fixed pitch direct drive prop, the aircraft must be slowed well below best glide speed. A controllable pitch prop, such as found on most multiengine planes, can be set to feather, which will cause it not windmill.
In twin-engine engine out operations, the primary things to do after identifying which side has a dead engine is to maintain airspeed above VMC, apply full throttle to the good engine, clean up drag which is gear, flaps and feather the bad engine prop. Quite a few twin engine airplanes will not climb at maximum gross takeoff weight until the bad engine’s prop is feathered. The drag induced by a windmilling prop from the compression, friction, and load of the accessories impose on a direct drive engine is FAR greater than a freewheeling prop.
As for the “rotor brake” idea, it would work to stop a windmilling, non-feathering prop, but I think the blades would then impose more drag than they would if windmilling. The effect would be similar to sticking a 2” X 4” with the 4” side vertical out either side of the cockpit the distance of the prop blade length. The only advantage I could see is that stopping the prop may help prevent damage to the prop itself in the event of gear failure during landing.
John Hart
Model IV N44CN
Oklahoma
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of 84KF
Sent: Monday, February 04, 2008 11:17 PM
Subject: Re: Re: RK400 clutch 582 application
Leni,
Steve
84KF
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Tue Feb 05, 2008 6:41 am Post subject: Re: RK400 clutch 582 application |
| Quote: | The drag induced by a windmilling prop from the compression, friction, and load of the accessories impose on a direct drive engine is FAR greater than a freewheeling prop.
As for the “rotor brake� idea, it would work to stop a windmilling, non-feathering prop, but I think the blades would then impose more drag than they would if windmilling. |
Actually it is just the opposite. A freewheeling prop produces much more drag than a stopped prop or one windmilling at reduced engine speed.
With the gearbox clutch, if the engine stops and the prop freewheels, your options for landing areas is greatly reduced. It would be good for the pilot to know how much drag the freewheeling prop produces and know what to expect when it happens.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Tue Feb 05, 2008 8:05 am Post subject: RK400 clutch 582 application |
Two possible ways to think about this, John. First, think
about what helicopters do when they auto-rotate. As they pick up
blade speed their vertical descent speed decreases. (You can also see
this by making a paper helicopter. As they spin up they slow down.)
Second, for the engineering types remember that lift is
proportional to lift coefficient (Cl), blade area, density, and the
SQUARE of the velocity. Pushed blades are just lifting in reverse
(bad Cl) so area and density remain constant. Now Cl decreases as the
prop speeds up, (lower angle of attack,) but it's variance is linear,
and is overwhelmed by the squared velocity term. The faster the prop
spins, the greater the lift (drag).
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
JohnA
Posted: Tue Feb 05, 2008 2:23 pm Post subject: RK400 clutch 582 application |
In the case of the RK-400 clutch, the speed of the prop turning has no bearing on the engagement of the clutch. It is the engine speed that determines when the clutch engages/disengages. In a descent with the engine RPM below the engagement threshold of the clutch or in the case of a stopped engine, the prop will freewheel. It is known that a freewheeling prop has higher drag than one that is stationary. The purpose of the RK-400 clutch is to make starting easier and reduce wear on the gearbox and engine during that start. Everyone who has driven a 2-stroke knows how they rattle and gripe below 2500 rpm or so. This is due to the load of the prop. Prop load at start becomes a non-issue with the clutch, so starts are easier and smoother - especially if you have pull start. As for not being able to prop your engine with the clutch, it is most unlikely that one will be able to prop start a 582 with a ducati ignition. The ducati ignition doesn't start to develop a spark until around 800 engine rpm or thereabouts. This translates to about 300 prop rpm. One important note: If you use a clutch, make sure to warm up the engine thoroughly at an engine rpm at which the prop is being driven (3000 is a good number). You need that prop load on the engine so it generates enough heat to become thoroughly heat soaked before piling on the coal for a takeoff. Lastly, if you use the E-box on your engine, you cannot use the RK-400 clutch -- unless you shift to a mag end starter or use the pull start. The RK-400 will decouple the starter on the E-box from the engine. All that will happen is you'll spin your prop but not the engine. With the RK-400 clutch, you are limited to the C-box. John Alexander Woodland, CA On Mon, 4 Feb 2008 16:54:47 -0600, Pat Reilly wrote > Guy Bucahanan, You stated how much you like your 582 with the clutch. What about durning decent? Someone stated the clutch does't disengage and drives the engine. Can you comment on this and more on any drawbacks of the application. I know the benifits. Thank You > > Pat Reilly > Mod 3 Rebuild > Rockford, IL -- Beer is proof that god loves us and wants us to be happy. - Ben Franklin [quote][b]
_________________ John Alexander
Woodland, CA |
Guy Buchanan
Posted: Tue Feb 05, 2008 7:09 pm Post subject: RK400 clutch 582 application |
At 02:20 PM 2/5/2008, you wrote:
| Quote: | In a descent with the engine RPM below the engagement threshold of
Just to clarify. If I pull the throttle and descend, the
engine will remain at some high idle or even higher RPM, being driven
by the prop. If I slow until the engine RPM drops below 2400 it will
immediately drop to 1500. I can then accelerate to any speed and the
engine will remain at 1500, while the prop appears to spin like crazy.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
JohnA
Posted: Tue Feb 05, 2008 7:35 pm Post subject: RK400 clutch 582 application |
This certainly makes sense, since the RK-400 clutch is set to disengage at
about 2500 rpm. I'm guessing that with older ones, the springs that hold the
slipper shoes back at low rpm get tired and so engage and disengage at lower rpm.
But yes, as long as the engine rpm is below the engagement rpm for the clutch,
the prop will go to town - spinning freely.
Please do take note of my aside on warming the engine with the clutch
installed. I repair more than a few cold seizured engines every year. This
is something that is completely avoidable, but becomes something to always
keep in mind when using the RK-400 clutch, since the engine can operate at
very low rpm and load factors. Long, low power descents followed by a
go-around is where you will get bit here.
John Alexander
On Tue, 05 Feb 2008 19:02:32 -0800, Guy Buchanan wrote
driven by the prop. If I slow until the engine RPM drops below 2400
it will immediately drop to 1500. I can then accelerate to any speed
and the engine will remain at 1500, while the prop appears to spin
like crazy.
Guy Buchanan
San Diego, CA
Woodland, CA |
occom
Posted: Wed Feb 06, 2008 3:33 am Post subject: RK400 clutch 582 application |
I wonder how many RPM the prop willl take before being damaged.
Dave Goddard- Mod IV 1050/582
| Quote: | > and the engine will remain at 1500, while the prop appears to spin
> like crazy.
> Guy Buchanan
> San Diego, CA
Guy Buchanan
Posted: Wed Feb 06, 2008 8:12 am Post subject: RK400 clutch 582 application |
At 03:31 AM 2/6/2008, you wrote:
| Quote: | I wonder how many RPM the prop willl take before being damaged.
LOL! I wondered about that when I was testing. Needless to
say I didn't push it. However I don't think there's any worry. The
prop will always spin faster pulling than pushing, since slippage
works against you both ways. (Meaning, it slips when generating
thrust, and slips worse when being thrust because of the lousy airfoil.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Tom Jones
Posted: Wed Feb 06, 2008 9:24 am Post subject: Re: RK400 clutch 582 application |
| Quote: | LOL! I wondered about that when I was testing. Needless to
works against you both ways. |
Maybe you can do the math for RPM, pitch and speed to get an idea of RPMs with the slippage being a safety factor. Pitch = distance traveled through the air in one revolution.
Classic IV
Ellensburg, WA |
msm_9949(at)yahoo.com Guest
Posted: Wed Feb 06, 2008 10:05 am Post subject: RK400 clutch 582 application |
Low-power descents are where Lowell's rad shutters save the day. Adjust the shutters as needed to keep temps above 140 degrees. They work like a charm. They also help get the temps up faster on the ground. An easy, inexpensive mod that I highly recommend, whether or not you have the RK400 installed.
http://highwingllc.com/
John Alexander <alexandj(at)preachain.org> wrote:
[quote]--> Kitfox-List message posted by: "John Alexander"
John Alexander
[quote] --> Kitfox-List message posted by: Guy Buchanan
avidfox
Posted: Wed Feb 06, 2008 10:25 am Post subject: RK400 clutch 582 application |
"Maybe you can do the math for RPM, pitch and speed to get an idea of RPMs with the slippage being a safety factor. Pitch = distance traveled through the air in one revolution"
Or..., just point an optical "checker" out the windshield.
[url=http://store.wagaero.com/product_info.php?products_id 933]http://store.wagaero.com/product_info.php?products_id 933[/url]
Occam's razor
http://en.wikipedia.org/wiki/Occam's_Razor
Steve
84KF
