				 Posted: Tue Feb 05, 2008 7:35 am    Post subject: Duckworks with tip tanks |
				Does anybody who is using HID lights in the leading edge have tip tanks?  Is there any concern about a fuel leak causing problems with electricity in that area?  There is power in the wingtip anyway, and at the heated pitot anyway, and the wings are not sealed anyway, but just wanted to see what opinions there were out there on this issue.
 Does anybody know what Vic had for landing lights?  I know he had the SafeAir tip tanks.
  Jesse Saint
 Saint Aviation, Inc.
 Cell: 352-427-0285
 Fax: 815-377-3694
		Tim Olson
				 Posted: Tue Feb 05, 2008 8:42 am    Post subject: Duckworks with tip tanks |
				Vic has the duckworks kit...
 http://www.myrv10.com/miscphotos/VicsRV10/plane/IMG_4217.html
 Jesse Saint wrote:
  	  | Quote: | 	 		   Does anybody who is using HID lights in the leading edge have tip tanks?
  SafeAir tip tanks.
  Jesse Saint
  jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
  Cell: 352-427-0285
  Fax: 815-377-3694
		patrick.pulis(at)seagas.c Guest
				 Posted: Tue Feb 05, 2008 2:49 pm    Post subject: Duckworks with tip tanks |
		ron.mcgann(at)baesystems. Guest
				 Posted: Tue Feb 05, 2008 4:24 pm    Post subject: Duckworks with tip tanks |
				Patrick is having problems with his IS mafia - their filtering process
 is a little 'aggressive' shall we say.  He asked me to post this:
 Hi there Jesse,
 I'm in the process of installing HID lights into my outboard leading
 edges and I'm also plumbing aluminium fuel line through the leading edge
 ribs to enable connection of the tip tank in each wing to the outboard
 side of the main fuel tank.
 My wing tips will be converted into fuel proofed integral tip tanks
 (giving approximately 28 litres/7.5 USG either side), by Flymore
 (http://www.flymore.com.au/), a local RV and experimental aircraft
 construction and modification company operated by Jon Johanson
 (http://www.vansaircraft.com/public/jj-persn.htm).  They have
 significant experience in modifying RV's and extending their range,
 which was necessitated when Jon  decided do his record breaking around
 the world and Antarctic flights, requiring conversion of his RV-4 into a
 wholly 'wet wing'.
 I will be installing a fuel isolation valve (12V solenoid valve designed
 for fuel applications) adjacent to the connection point to the wing tip
 tank and have installed an access panel (Vans access panels) on the
 under side of the outboard leading edge to enable access to the solenoid
 valve and connections and another access panel inboard to enable access
 to the connection point to the outboard side of the main tank.
 Conversion of the Van's tips into fuel tanks includes a tunnel to enable
 the electrics for the lights in the tip to be run separately from any
 fuel and away from any HID lights in the leading edge.  To date this
 conversion has been highly successful and has been applied to RV's
 ranging from the 4 to the 10 with no reported fuel leaks or operational
 faults.
 If anyone would like some photos of a friends RV-7 which features this
 modification please drop me a line (patrick.pulis(at)seagas.com.au) and
 I'll send them to you separately off-line.  I have discussed the tip
 tank modification (inclusive of strengthening the attach points) with
 some local aeronautical engineers and they have given it the tick of
 approval.  Obviously all up weight must be kept in check and fuel from
 the tips should be used first on longer flights.
 I hope this helps you out.
 Patrick Pulis
 #40299    VH-XPP
 Adelaide, South Australia
				 Posted: Tue Feb 05, 2008 5:57 pm    Post subject: Duckworks with tip tanks |
				Patrick and others,
 This is exactly the type of feedback I was hoping for.  Basically, no
 "Oh my goodness I can't believe you would even consider that a viable
 option" comments.  Thanks.
 do not archive.
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
  Hi there Jesse,
  edge
  into a
  wholly 'wet wing'.
  designed
  tip
  solenoid
  access
  enable
  operational
  faults.
  Patrick Pulis
  #40299    VH-XPP
		dasduck(at)comcast.net Guest
				 Posted: Wed Feb 13, 2008 8:58 am    Post subject: Duckworks with tip tanks |
				Jesse,
  to increase clearance, you could move the lights one bay  inboard from the tip.
  Don
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse  Saint
 Sent: Tuesday, February 05, 2008 7:27 AM
 To:  rv10-list(at)matronics.com
 Subject: Duckworks with tip  tanks
    Jesse Saint
  Cell: 352-427-0285
  Fax: 815-377-3694
		lbgjb10
