lik_2_fly(at)hotmail.com Guest
Posted: Wed Feb 06, 2008 5:04 pm Post subject: Linkage from Differential valve to rudder pedals |
Hi All,
Ive noticed im not getting full rudder deflection on a Yak 52 and it appears to be hitting the end of travel on the differential valve before hitting the rudder stops.
Looking at the drawings it appears there is a spring cartridge in the link between the rudder pedals and the differential valve. Im guessing its to allow's for full travel of the rudder. Has anyone had any trouble with this or has more information on its operation.
regards
Chris
Adelaide, Australia
Check our comprehensive Salary Centre Overpaid or Underpaid?
dsavarese(at)elmore.rr.co Guest
Posted: Wed Feb 06, 2008 6:56 pm Post subject: Linkage from Differential valve to rudder pedals |
Chris,
I have seen a similar situation on one other Yak 52. Hopefully what I'm about to describe will be of some benefit. Go to the arm on the front side of the brake differential valve (forward of the main spar). It has the two adjuster bolts going thru it. Put you thumb and index finger on the end of the arm where it connects to the bar going aft through the main spar. Now try moving the arm vertically from this junction. There should be very minimal movement when you attempt to move the arm up and down. If there is vertical movement, there is wear on the arm where it mounts to the differential valve. Here's the point to all this.
If the arm can move up and down at the end, it also moves the bar and spring mechanism up and down as it passes through the elliptical hole in the main spar. Because the arm is able to move up and down it can cause the nut at the adjustment section of the spring mechanism to hit the bottom of the elliptical hole, causing the rudder travel to come to a stop, or effectively jam.
I removed the arm from the brake differential valve (pretty easy to do by removing the pin) and made a shim and drilled a hole in it for the pin from a piece of stainless steel shim stock, maybe about .010 thick, and placed it between the bottom of the bracket holding the arm and the arm itself, thus eliminating the slop. Once I did this, the bar/spring mechanism was able to move freely through the elliptical hole in the spar.
Hope this helps.
Dennis
Posted: Thu Feb 07, 2008 12:15 am Post subject: Linkage from Differential valve to rudder pedals |
Thanks all, found the problem.
Thanks to Dennis i was quickly able to determine that the push rod was working correctly.
The front rudder pedals where installed back to front during original overhaul, when the rudder pedals where adjusted full forward the foward linkage didnt have enough room to clear the rudder pedal mounting tude.
cheers
Chris
| Quote: | From: lik_2_fly(at)hotmail.com
To: yak-list(at)matronics.com
Subject: Yak-List: Linkage from Differential valve to rudder pedals
Date: Thu, 7 Feb 2008 11:25:18 +1030
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Hi All,
regards
Chris
Adelaide, Australia
Check our comprehensive Salary Centre Overpaid or Underpaid? | Quote: |
et=_blank>http://www.matronics.com/Navigator?Yak-List
p://forums.matronics.com
| Listen now! New music from the Rogue Traders. [quote][b]
Posted: Thu Feb 07, 2008 4:43 am Post subject: Linkage from Differential valve to rudder pedals |
Chris,
As suggestion concerning the rudder cable mounting tubes - for safety of flight, particularly during aerobatics; either remove them completely or remove them and cut the end closest to the rudder peddles at a 45 - 60 degree angle. Then reinstall. The reason being - the heal of the shoe or boot can jam against the front edge of the tube when full rudder deflection is applied. This can be dangerous during aerobatic maneuvers where full rudder deflection is needed.
Dennis
f4ffm2(at)adelphia.net Guest
Posted: Thu Feb 07, 2008 8:12 am Post subject: Linkage from Differential valve to rudder pedals |
It is interesting that there are still airplanes out there without this modification. It was a mandatory bulletin in the DOSAAF (like our Airworthiness Directive) to have the tubes modified. People had died because of them. To my mind, they MUST be modified before further flight.
Roger______________________________________________________________________________
On Feb 7, 2008, at 4:37 AM, A. Dennis Savarese wrote:
[quote]Chris,
Dennis
[quote]---
Posted: Thu Feb 07, 2008 8:39 am Post subject: Linkage from Differential valve to rudder pedals |
You are 110% right Roger.
Dennis
jorgen.nielsen(at)mweb.co Guest
Posted: Thu Feb 07, 2008 11:06 am Post subject: Linkage from Differential valve to rudder pedals |
I have seen 2 very pale faces after landing when this occurred, luckily without injury…plane locked into spin.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: 07 February 2008 02:38 PM
Subject: Re: Linkage from Differential valve to rudder pedals
Chris,
Dennis
