		Ralph B
  Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
				 Posted: Thu Feb 07, 2008 8:13 am    Post subject: my old muffler |
				After 21 years of flying, I'm going to finally have to replace the single-jointed muffler on the engine. It's been welded twice before and now it's cracked again. I have a new double-jointed muffler and never put it on for two reasons. One, it has two EGT sender ports and I don't want to add another EGT gauge on my panel. Second, the muffler end goes straight out instead of the exhaust pointing up like this one does. I'm afraid the exhaust gases going out could weaken the fiberglass Ivo prop, over time, as the prop is only a few inches from the end of the muffler exhaust (I don't have a prop extension). What I can do, is get the curved part cut out of the old muffler and welded on to the new one. That takes care of that problem (or get a prop extension).
 I thought about tying the EGT senders together. Has anyone else done this? I don't see any problem with this. If one sends out more voltage than the other, it would respond on the single EGT instrument I have, thereby indicting a high EGT if either of the cylinders are too hot.
  _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
		bransom(at)ucdavis.edu Guest
				 Posted: Thu Feb 07, 2008 9:12 am    Post subject: my old muffler |
				Hi Ralph,
 I had the same issue on EGT -- originally one probe at the Y and one
 gauge.  Later determined I much preferred knowing EGT separately, so put
 in a second probe.  My solution to leaving it one gauge was to add a
 small switch.  I mounted it just under the throttle.  Fwd is the fwd EGT
 probe, middle is a neither, Rear is the rear EGT probe.  I made myself
 the habit of leaving that switch in the rear position, other than when
 checking front EGT, to avoid inadvertently switching my ignition switch
 from fwd to rear (OFF) instead.  My ignition sw is bigger and mounted a
 foot in front, but brain farts happen.  Overall the solution has worked
 well, although that is also with the recognition that a digital EIS with
 alarm thresholds woulda been best.
 -Ben
 Ralph B wrote:
  After 21 years of flying, I'm going to finally have to replace the single jointed muffler on the engine. It's been welded twice before and now it's cracked again. I have a new double-jointed muffler and never put it on for two reasons. One, it has two EGT sender ports and I don't want to add another EGT gauge on my panel. Second, the muffler end goes straight out instead of the exhaust pointing up like this one does. I'm afraid the exhaust gases going out could weaken the fiberglass Ivo prop, over time, as the prop is only a few inches from the end of the muffler exhaust (I don't have a prop extension). What I can do, is get the curved part cut out of the old muffler and welded on to the new one. That takes care of that problem (or I could get a prop extension).
  Ralph B
  Original Firestar
  N91493 E-AB
  21 years flying it
  http://forums.matronics.com/viewtopic.php?p=162832#162832
		Ralph B
				 Posted: Thu Feb 07, 2008 9:41 am    Post subject: Re: my old muffler |
				I thought about a switch too, but if the engine gets hot, it will do it when the switch isn't switched. I'm going to try and "Y" the two senders together and use a cig lighter to see what happens. This seems the easiest way to do this without adding another gauge.
Kolb Kolbra 912uls
N20386
550 hours |
		by0ung(at)brigham.net Guest
				 Posted: Thu Feb 07, 2008 11:15 am    Post subject: my old muffler |
  	  | Quote: | 	 		  >>>>>>>>>>>>>>>>>>>
 Put in a small timer with a double pole, double throw  relay,,,  and have it
 go from one to the other every 10 sec or so.  You could have it light a led
 to indicate front or back reading.
 Boyd
		ElleryWeld(at)aol.com Guest
				You could buy a double in one gauge for you EGT that  way you wont have to cut another hole in your panel  Just a thought
  Ellery in Maine
   In a message dated 2/7/2008 11:16:35 A.M. Eastern Standard Time,  ul15rhb(at)juno.com writes:
   	  | Quote: | 	 		  -->    Kolb-List message posted by: "Ralph B" <ul15rhb(at)juno.com>
 Ralph B
 Original Firestar
 N91493 E-AB
 21    years flying it
 Read this topic online    here:
 Who's never won?  Biggest Grammy Award surprises of all time on AOL Music.
		Ralph B
				 Posted: Thu Feb 07, 2008 11:40 am    Post subject: Re: my old muffler |
				 	  | ElleryWeld(at)aol.com wrote: | 	 		  |  You could buy a double in one gauge for you EGT that  way you wont have to cut another hole in your panel  Just a thought  |
 I thought about that too, but I have a dual tach and EGT. If I get a dual EGT, I will have to make a hole for another tach.
Kolb Kolbra 912uls
N20386
550 hours |
		olendorf
  Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
				 Posted: Thu Feb 07, 2008 8:33 pm    Post subject: Re: my old muffler |
				Wouldn't connecting the two wires together show the average of the temps, not the maximum of either?
 I don't think that will work. Just use the one egt hole and plug the other one.
  _________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
				 Posted: Thu Feb 07, 2008 9:55 pm    Post subject: my old muffler |
				If they are in parallel they should show an average.
 BB
		Ralph B
				 Posted: Fri Feb 08, 2008 6:17 am    Post subject: Re: my old muffler |
				On 7, Feb 2008, at 11:33 PM, olendorf wrote:  	  | Quote: | 	 		   Wouldn't connecting the two wires together show the average of the  temps, not the maximum of either? I don't think that will work. Just use the one egt hole and plug the other one.
 Scott Olendorf
 Schenectady, NY
  http://KolbFirestar.googlepages.com
 Thanks Scott and others. You are right, it will show an average. I will drill a single hole and plug the two other EGT ports. This worked for 21 years on the other muffler and will work here too.
Kolb Kolbra 912uls
N20386
550 hours |
