agustafson(at)chartermi.n Guest
Posted: Fri Feb 08, 2008 4:26 pm Post subject: 503 on MK-3 |
Anyone with 1st hand experience. What are the pros or cons of a Rotax 503 on
a MK-3. Should I consider it or is it too small? I want to know what to shop
for. Plane will only be used for local site seeing and fun , mostly with a
passenger(325# pilot & co-pilot total).
Aaron Gustafson
jlsk1(at)frontiernet.net Guest
Posted: Fri Feb 08, 2008 5:55 pm Post subject: 503 on MK-3 |
Yep, 1st hand experience here. I had a 65 MPH cruise ( indicated), single
pilot, I weigh 200 lbs, took a 250 lb passenger up once. it did it, but I
wouldn`t do it regularly. for local flights solo, it it fine. There was a
post not long ago about this same topic, & I`m sure there are VERY
different opinions. mine was fine, but if you want to go longer distances, &
or regularly flying dual, you may want at least a 582. Jim
herbgh(at)nctc.com Guest
Posted: Fri Feb 08, 2008 6:23 pm Post subject: 503 on MK-3 |
Two friends of mine...Rans S12's ..one with a 503 and the other
582... The 582 delivered better fuel mileage...Herb
single pilot, I weigh 200 lbs, took a 250 lb passenger up once. it
did it, but I wouldn`t do it regularly. for local flights solo, it
it fine. There was a post not long ago about this same topic, & I`m
sure there are VERY different opinions. mine was fine, but if you
want to go longer distances, & or regularly flying dual, you may
Posted: Fri Feb 08, 2008 7:36 pm Post subject: 503 on MK-3 |
Aaron
No question for the cost of a 503 or less put a redrive VW on it. You get
912 performance, 4 stroke reliability and low cost.
I flew in a 503 powered MKIIIC with another guy the total human weight was
375-400. It did surprisingly good but not what you would want if your going
to fly in and out of UP strips like Scott T. strip.
Also, you have the opportunity to make a Kolbra or a MKIIIX. Depending on
you mission either one would be a better choice. The down side of a Kolbra
is that it is two narrow for the VW mount. New Kolb will weld up a MKIIIX
cage with a VW mount. Food for thought.
Rick Neilsen
Redrive VW powered MKIIIC
JetPilot
Posted: Sat Feb 09, 2008 12:57 pm Post subject: Re: 503 on MK-3 |
The question you need to be asking yourself is not IF the plane will fly with a 503, you need to ask yourself if it will be any fun to fly with a 503. Flying an underpowered plane and running the engine full out most of the time is definitely not as fun or rewarding, or as safe as flying a plane with a proper amount of power. Just because it you can do it does not mean you would want to.
It all comes down to money, if you are able, get the 912-S, it is by far the best engine to put on a Kolb MK III. Work overtime, do whatever it takes to put the best engine you can afford on that plane, it will make the difference between having a plane that is fun and enjoyable to fly, and building a plane you never really like.
If you cannot afford the 912-S, I would look for a used one. If not that, I would look at the VW Rick talks about, if not that, I would look at the 582. If you cant afford at least the 582, I would not build the MK III. If I was stuck with nothing but a 503, I would build a firestar-II which is smaller, lighter, and will give acceptable flight performance with a Rotax 503.
Kolb MK-III Xtra, 912-S |
Posted: Sat Feb 09, 2008 1:49 pm Post subject: 503 on MK-3 |
A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a
200lb pilot steep enough, & at plenty of "feet per minute" to get out of a
SHORT strip. I would not call that underpowered.
: ) Jim
lcottrell
Posted: Sat Feb 09, 2008 3:37 pm Post subject: 503 on MK-3 |
a SHORT strip. I would not call that underpowered.
: ) Jim
I really hate to have to reply to this thread, but keep in mind that this
guy is asking a pretty serious question that will affect him for a long
time, good choice or bad one. There was quite a lengthy thread on this same
subject that should be in the archives, so he might go there.
I live at 4000 feet, so that probably colors my opinion on the matter. Sea
level might possibly be enough difference to make a 503 acceptable to a Mark
III. If it is built light enough a 503 would push it around, but it wouldn't
be as exciting a performer as a Mark III with 100 horsepower. I had a Mark
III that had a 582 on it and sold it because to my thinking it was a dog and
not as much fun to fly as my Firestar II. I guess that I have finally gotten
old enough that I am not interested in OK, I want it to be the best that it
can be, the first time. With a 582 the Mark III, will give you about the
same performance as a Firestar with a 503. You are going to burn about 1 to
2 gallons more per hour to go the same speed. A 582 is going to cost you
somewhere around $6000 and up. A 912 is somewhere around $14000 now I think.
Rebuild time for a 582 is listed as 300 hours, compared to a rebuild time
for a 912 is three to four times as long. Fuel burn is less than the 582 as
well. The Mark III with a 912 is a "serious" airplane, any of the other
engine choices leaves you with a "patch" type of airplane that you have
problems going any distance due to the speed and fuel consumption. Not
saying that it isn't possible, I am merely saying that for my self, I
wouldn't do it on the cheap. I think if you pencil it out, over the long run
a 912 would cost less than going with a two cycle engine.
It is not my intention to belittle any ones choice of engine. If it suits
you then that is all that is necessary. Just trying to fuel thought and give
the guy the information to make a choice.
Larry C
Posted: Sat Feb 09, 2008 4:03 pm Post subject: 503 on MK-3 |
Thanks to all who have written. All comments are taken well. I don't want a
dog but neither do I need a cruiser. I have a Zenith 601 for going places
regionally. What I want now is a more around the patch fun flier. So I can
keep an eye on the neighborhood and make sure no one else has more junk than
me. It'll probably hardly ever get more than 50 miles from home. I have
about ruled out the 503 though from the comments I have received thus far.
This was what I wanted to hear. So I thank you for your perspectives and I'd
still like to hear from others.
Aaron
> A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb>
you then that is all that is necessary.>
HShack(at)aol.com Guest
Posted: Sat Feb 09, 2008 7:37 pm Post subject: 503 on MK-3 |
My FS II w/ 503 DCDI cruises at 65 mph; how in heck is a heavier, less- streamlined plane going to cruise at the same speed without running at 6000 rpm all the time?
At least get the 582; 912 better.
Howard Shackleford
FS II
SC
In a message dated 2/9/2008 6:38:27 P.M. Eastern Standard Time, lcottrell(at)fmtcblue.com writes:
| Quote: | A MK-3C with a 503 will cruise at 65MPH, single pilot, & will climb with a
| Quote: | 200lb pilot steep enough, & at plenty of "feet per minute" to get out of
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
Posted: Sat Feb 09, 2008 7:39 pm Post subject: 503 on MK-3 |
Sounds like a FSII would suit you better. A fantastic flyer with a 503.
Howard Shackleford
FS II
SC
In a message dated 2/9/2008 7:04:05 P.M. Eastern Standard Time, agustafson(at)chartermi.net writes:
| Quote: | don't want a
planecrazzzy Guest
Posted: Sun Feb 10, 2008 4:28 am Post subject: Re: 503 on MK-3 |
I was thinking the same thing...
Gotta Fly...
"HShack(at)aol.com"]My FS II w/ 503 DCDI cruises at 65 mph; how in heck is a heavier, less- streamlined plane going to cruise at the same speed without running at 6000 rpm all the time?
Posted: Sun Feb 10, 2008 5:29 am Post subject: 503 on MK-3 |
I just sold my FS2 11 months ago. 440 hours on it all mine. It flies great with a 447. Better than a 503 IMHO.
planecrazzzy Guest
Posted: Sun Feb 10, 2008 5:04 pm Post subject: Re: 503 on MK-3 |
Well, tell us why you think it was better with the 447.....?
Gotta Fly...
[="agustafson(at)chartermi.n"]I just sold my FS2 11 months ago. 440 hours on it all mine. It flies great with a 447. Better than a 503 IMHO.
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Sun Feb 10, 2008 5:05 pm Post subject: Re: 503 on MK-3 |
I found out the other day, from Travis at Kolb, the latest price for a Rotax 912 is $21,000. So much for a reasonable price engine from them. There engines are good but NOT that good.
Rick Lewis
Posted: Sun Feb 10, 2008 5:18 pm Post subject: 503 on MK-3 |
It looks like they anticipated our genius politicians "rebate"
BB
On 10, Feb 2008, at 8:05 PM, Rick Lewis wrote:
from them. There engines are good but NOT that good. [Rolling Eyes]
Rick Lewis
http://forums.matronics.com/viewtopic.php?p=163385#163385
capedavis(at)yahoo.com Guest
Posted: Sun Feb 10, 2008 7:38 pm Post subject: 503 on MK-3 |
A 503 will give you outstanding performance on a Firestar!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Chris
by0ung(at)brigham.net Guest
Posted: Mon Feb 11, 2008 8:07 am Post subject: 503 on MK-3 |
: ) Jim
Maybe at sea level... try it on a warm summer day at 7000 ft... while on a
cross country,,,, you will be wising for a 912 or 912s also if you want
to sell it,,,, which plane would sell better... the 912 cost more but
operates for less, by the time you put on 1200 to 1500 hours,,, they cost
the same to own.
Boyd
Posted: Mon Feb 11, 2008 10:10 am Post subject: 503 on MK-3 |
Boyd
We have heard that claim for a number of years but with the current engine
prices the average person will never recover the cost differences. Even with
current gas prices I would bet that the difference put in savings, would
earn more than the operational $ differences.
The bigger concern is that those 2 stroke engines run real close to self
destruction. There are quite a few people that seem to keep them running
fine but if your not one of them keep a landing site in your flight plan.
Most four stroke engines just have more margin from self destruction.
I flew in a 503 powered MKIIIC and it was clearly having a hard life. I
would personally never leave the pattern or fly in/out of a short strip with
my 200+ lb. butt in one.
Rick Neilsen
