Dave(at)AirCraftersLLC.co Guest
Posted: Tue Feb 12, 2008 11:52 am Post subject: SilPruf Window Installation (Here goes...) |
The rear and door windows in N921AC are installed with an adhesive called
SilPruf. It's very thick (viscous) silicone material from GE.
(http://kbam.geampod.com/KBAM/Reflection/Assets/10412_3.pdf). SilPruf comes
in several colors and is avialable from
The advantages to this method over Weld On are that it leaves a nice looking
trim ring around the exterior of the window, it prevents the cracking along
the edge of the bond, and it would allow for the windows to be removed and
replaced in the future without repainting the area around the window. BUT
it's a bit of work.
We learned this technique from the GlaStar community. It's a little
involved and it takes several curing cycles, but the results are really
nice. AirLInk has a video describing the process:
http://mall.igfarm.com/store/merchant.mv?Screen=PROD&Store_Code=airlinktech&
Product_Code=101-0101-0000
My description is a bit rushed and I may have left part of it out. Please
proofread it and let me know so we have a good record of the process. It's
a logical process and if something is missing I think you'll realize it. I
wish I had some pictures but I hope the video will help. One pointer here:
the video references a completely separate, alternative method using vinyl
ester resin. Vinyl ester will not bond well to the top or doors of the
RV-10. You could just substitute epoxy for vinyl ester if you decide the
SilPruf is too much work.
Please get in touch if I can clarify this. I suspect there will be some
questions.
Here are the steps we followed. I haven't watched the video lately so the
order may be a little different:
1) Mask the outside of the window. No sealant ever touches the outside
surface. Trim the window to the airframe so it has a 1/8" gap between the
window and the OD of the joggle.
2) Mask the inside of the window except for the edge. Leave an
unmasked margin 1/16" wider than the edge of the joggle. Apply another
layer of thin masking tape (we used fine line tape from an autobody store)
to the edge of the margin. This layer will be removed before the material
cures.
3) Prep the unmasked surface lightly with a cloth moistened with
acetone to clean and degrease it.
4) Apply a very thin layer of SilPruf to the unmasked margin. The
purpose of this step is to create the cosmetic "mask" that is seen from the
outside. Remove the fine line tape. Let the mask cure for 24 hours
minimum.
5) While the mask is curing, lay out a bead about 18" long by 1/4"
diameter of SilPruf on some wax paper. It will be used later in the
process. It doesn't have to be particularly uniform-just a line of SilPruf.
6) Trial fit the window into the joggle. Drill #40 cleco holes every
2" into the bottom of the groove between the window and the OD of the
joggle.
7) Make a bunch of wooden spacers out of inch-long of popsicle stick or
similar. Drill a #40 hole in the middle of each spacer. Use the spacers
under a cleco to clamp the window into the joggle. At this point the window
will be "below grade" of the outside skin.
Now cut the bead of SilPruf into thin wafers and shim the window out
so it is at or slightly above grade. Place one wafer approximately at each
cleco under the cosmetic mask. The wood strips will bridge from the fuse to
the window, and the cleco should apply enough pressure to slightly compress
each wafer. You will vary the thickness of each wafer to get the window
flush with the outer skin. Prep the joggle, then glue the wafers to the
joggle with SilPruf and let them cure. They have to be firmly affixed so
that they stay in place during the final installation. If they slip around,
the window will fall below grade and all the sealant will get squeezed out
by the cleco pressure.
9) Mask the inside and outside of the fuselage and apply another fine
line mask to the inside of the window.
10) Apply the SilPruf to the joggle, all around the wafers. Be
careful not to break the wafers off.
11) Put the window back in place and secure it with the clecos and
wood strips. Scoop as much as possible out of the groove between the
window and the joggle. Some material will remain under the wooden spacers.
Those sections will be removed later.
12) Remove the fine line mask from the inside. Let the whole thing
cure for at least 24 hours.
13) Remove all the masking from the inside, and clean up any drips.
If you catch them before they cure, that's even better.
14) Remove the clecos and strips. Remove the SilPruf from the area
under the strips with a pick, knife, chisel, whatever works. There should
be a nice uniform groove between the edge of the window and the airframe.
Kind of a little moat.
15) Fast forward to final painting of the plane. Paint the body color
right up to the edge of the groove, then paint over that with a very thin
line of glossy paint that matches the color of the SilPruf. Ours is black,
about 1/16" to 1/8" outboard of the OD of the joggle.
16) Then mask halfway onto the glossy paint and the entire plastic
outer surface of the window. Apply a bead of SilPruf into the groove to
fill it up. Smooth it up with a squeegee or your favorite technique, then
remove all the masking tape before the SilPruf cures.
That should do it. Fire away.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Tim_Lewis(at)msm.umr.edu Guest
Posted: Tue Feb 12, 2008 3:15 pm Post subject: SilPruf Window Installation (Here goes...) |
Dave,
Have you compared the holding power of SilPruf to that of WeldOn?
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
it's a bit of work.
questions.
cures.
minimum.
joggle.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Posted: Tue Feb 12, 2008 3:59 pm Post subject: SilPruf Window Installation (Here goes...) |
Nope. But I have seen it work very well in many other applications besides
this one. The numbers say it would take a catastrophe to break the
bond--thousands of pounds loading against the window--at which point the
strength of the bond becomes a moot point. So, no, I haven't checked, but I
still I trust the application.
Also, it's a bit of an apples/oranges comparison because the SilPruf
stretches so much further before breaking. That's what makes it nice for
preventing the hairline cracks.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
kearney(at)shaw.ca Guest
Posted: Wed Feb 13, 2008 7:20 am Post subject: SilPruf Window Installation (Here goes...) |
Dave
Many thanks for such a detailed post. Where I live it can go from -40F in
winter to +90F in summer. Thermal expansion of joints around windows etc is
an issue that I have been concerned about.
On the strength of your recommendation, I have ordered the video and hope to
put it to good use.
Les Kearney
#40643
C-GCWZ (Reserved)
patrick.pulis(at)seagas.c Guest
Posted: Thu Feb 14, 2008 5:01 pm Post subject: SilPruf Window Installation (Here goes...) |
Les, once you view the video, could you please post a overview of the
installation process and your thoughts please?
Patrick Pulis
#40299 VH-XPP
Adelaide, South Australia
DO NOT ARCHIVE
Posted: Thu Feb 14, 2008 8:48 pm Post subject: SilPruf Window Installation (Here goes...) |
Patrick
Hi from the northern end of the Commonwealth!
I know next to nothing about composites, but am trying to learn. I'll
certainly pass on comments etc once I have seen the video.
Cheers
Les Kearney
#450643
C-GXWZ (reserved)
