Koolmat Installation
Goto page Previous  1, 2, 3  Next
rv(at)thelefflers.com
PostPosted: Thu Feb 14, 2008 7:39 pm    Post subject: Koolmat Installation Reply with quote
Les,
Don't fret, I still have my 180......
You're in good company!
bob
Date: 2008/02/14 Thu PM 07:51:18 EST
Subject: Re: Re: Koolmat Installation
Kelly
Now you have outed me. The whole RV world now knows I am a closet Piper driver....
I have been under my Cherokee panel, its not that bad - not great but not bad. But I do take your point.
Cheers
Les
ricksked(at)embarqmail.co
PostPosted: Thu Feb 14, 2008 7:49 pm    Post subject: Koolmat Installation Reply with quote
We built our own aircraft....we are not certificated...WE work on our aircraft because WE like it, NOT paid to do it...not because it its labor intense. We build our aircaft to EXCEED industry practices. I know there are a lot of good A&P's out there...I just wish someone would take away their bubble gum, duct/speed tape and safety wire fixes.
Rick Sked
40185
PostPosted: Thu Feb 14, 2008 8:34 pm    Post subject: Koolmat Installation Reply with quote
OK...
Koolmat is intended as a FIRE BARRIER. It is intended to be installed on the engine side firewall. Ask all the NASCAR drivers who experienced catastropic engine fires last year how it worked, it's standard equipment. If you have a problem with inspecting your firewall, don't use it. I have it on mine, it is held by a perimeter bead of red RTV. I can peel it off without much trouble, I have done it once already. If you want to bat around the inspection of the firewall issue then fine, I can pull my stainless steel heat valves off, loosen my eyeball cable guides, remove my firewall mounted electrial connectors and see my firewall in about an hours worth of work. BUT....if I prang a landing, the last thing I'm worrying about is the firewall. The firewall is really not a structural piece. The weldments and adjoining structural members are the parts that will absorb the impact and show signs of STRUCTURAL failure. Yes the firewall will wrinkle, but get on your back, scoot your ass under the panel and see what is really bent. Most of us elected to use the koolmat to prevent heat buldup in the tunnel. It is a fiberglass mat with a pure silicone finish. It is NOT a insulator...it is intended to keep FLAMES from breaching the firewall. So screw your indifference. Rob has spelled it out..read the spec sheet on the stuff and decide if you want it or not...Look at a tube and frame aircraft, the firewall only is intended to keep flames away from the cockpit...not provide structural integrity. I'm off the soap box...
Risk Sked
40185
Koolmat user
ron.mcgann(at)baesystems.
Looks like Koolmat installation might become the next 'primer war'
<gag>.
I installed Koolmat on the engine side of the firewall about 12 months
ago when 'tunnel heat' was the hot topic (bad pun - sorry). It was my
attempt to reduce any radiant heat affects that drove tunnel temps and I
used red RTV for attachment. I also installed a layer of Koolmat on the
tunnel floor, attached with velcro in answer to Lew's question below. I
have also heard of builders here in Oz using snap fasteners and even s/s
screws to pin the mat in position, but I doubt that velcro would be up
to the mission in the engine compartment. Just another 0.02 worth.
Cheers,
Ron
n212pj(at)gmail.com
Hey! After learning in the Katana, I moved on to the big iron. A Cherokee,
then up to the Arrow. Then finally into a 1979 182. All good aeroplanes.
So, Les, my good man, I'm with you in being a proud Piper / Cessna driver.
Good background for appreciating the experimental / RV world.
John Jessen
Glastar flying
RV-10 building (sort of)
Kellym
PostPosted: Thu Feb 14, 2008 8:35 pm    Post subject: Koolmat Installation Reply with quote
I'm struggling a bit with this concept of radiant heating of the
firewall. It is behind the engine baffling, gets airflow after it passes
through the cylinders, so only the exhaust system is radiating any
direct heat towards the firewall, absent an uncontained fire. Maybe this
product would help on the lower half of the firewall, but surely there
is no significant radiant heating of the upper half of the firewall.
Other than at very low airspeed or taxing, there probably isn't
significant radiant heat on the lower firewall either.
William Curtis wrote:
Kelly,
Based on your concerns below, I think the Koolmat may be a waste of money for you. You may be better served by looking at a product designed specifically for the cabin side of the firewall.
By placing the Koolmat on the cabin side of the firewall, you eliminate one of the principal benefits of the Koolmat, that of reduction of radiant heating of the firewall and everything that is attached to it. The fibers in the Koolmat are impregnated and would be difficult to absorb moisture. Certainly being able to inspect the firewall is valuable, however I think this could be done from the cabin side.
I used red RTV and the engine mount to hold mine in place. The most challenging part was neatly making all the cutouts for the various items passing through the firewall.
William
http://wcurtis.nerv10.com/
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
-- Dr. Suess
Kelly McMullen
KCHD
AV8ORJWC
PostPosted: Thu Feb 14, 2008 8:37 pm    Post subject: Koolmat Installation Reply with quote
The manufacturer "is" the builder, not the various suppliers. The RV-10
is a great example of a lot of experimental products coming together
into a unique final creation by us. At times like these, the words of
Richard come to mind this Christmas as we discussed the 51% Committee
accomplishments and his role as Co-Chair.
"There are no standards in Experimental Built - there are now 29,000
finished experiments flying in the system". In the certified world,
every prudent manufacturer has a firewall that allows for inspection at
each annual. The firewall tells a lot about dissimilar metal corrosion,
wire chafing, and stresses endured during the previous period since last
inspection and other valuable observations. One side tends to show these
better than the other.
Probably Kelly's extensive experience as an IA and his desire for safe
operations clouded his views on the experimental portion of this
pursuit. Maybe the words "on a wing and a prayer" came to his mind.
Periodically, get a trained pair of eyes to look over your shoulder as
you travel down life's highway.
Good luck, Choose Wisely and fly safe.
John Cox
40600
Do not Archive
kearney(at)shaw.ca
PostPosted: Thu Feb 14, 2008 8:45 pm    Post subject: Koolmat Installation Reply with quote
Kelly
Given these politically correct days, I am not sure the CO2 emissions from a
coal fired, steam powered RV would be acceptable.....
Cheers
Les
kearney(at)shaw.ca
PostPosted: Thu Feb 14, 2008 9:00 pm    Post subject: Koolmat Installation Reply with quote
Lew
When I spoke to Patty at Koolmat today she suggested using a product called
"gorilla snot" (I kid you not) to secure the Koolmat. She said it was also
called "3M Yellow" so I think this is it:
http://www.3mestore.com/62214006090.html?WT.mc_id=3M-com-AtoZ-Super-Weathers
trip-Adhesive
She also mentioned that you must use a silicone based adhesive to join
sheets.
Cheers
Les Kearney
#40643
C-GCWZ (reserved)
kearney(at)shaw.ca
PostPosted: Thu Feb 14, 2008 9:11 pm    Post subject: Koolmat Installation Reply with quote
Hmmm
I think that there are two different applications being discussed her.
I for one am only concerned about fire protection. Granted this is a very
low risk, I have read a few stories about engine fires that make me want to
spend a few dineros to mitigate this risk. Do a search on the VansAIrForce
website for some interesting tales...
Interestingly, one of the places where fire can enter the cockpit is via the
floor. It seems that an engine fire will flow under the firewall and melt
the bottom skin. I plan to line the full floor area with Koolmat to mitigate
this risk as well.
The other application being discussed is about insulation. Here I don't care
so much. I fly in places were a -25c days is not uncommon in winter. So if
its heat, bring it on....
Cheers
Les Keaney
#40643
C-GCWZ (reserved)
apilot2(at)gmail.com
PostPosted: Thu Feb 14, 2008 9:16 pm    Post subject: Koolmat Installation Reply with quote
So why not a solar energized steam turbine? Or algae derived biodiesel
fired steam boiler? Where's the real experimental here anyway? Lycs
and auto derived internal combustion is sooooooooo passe, eh?
Perhaps Rick is right...if you can mount the Koolmat on the front side
in a way that it is easily removable for inspections, it just might be
the trick, although in Alberta, you probably need another insulation
on the back side.
On Thu, Feb 14, 2008 at 9:40 PM, Les Kearney <kearney(at)shaw.ca> wrote:
Kelly
Cheers
Les
dougpflyrv(at)aol.com
PostPosted: Fri Feb 15, 2008 5:14 am    Post subject: Koolmat Installation Reply with quote
RON, DO U FEEL IT HELPED REDUCE TUNNEL HEAT?
DOUG PRESTON
N372RV
DO NOT ARCHIVE
dmaib@me.com
PostPosted: Fri Feb 15, 2008 5:24 am    Post subject: Koolmat Installation Reply with quote
Well, I did not intend to start a "Koolmat War" when I asked the
original question! However, as always, the list is priceless for all
of the points of view and sources of information. Thanks to all for
the responses. There was never any question from me about what side
it goes on. It is made for the firewall side. I just wanted some
ideas about how to secure it, and now I have that!
Thanks to all.
David Maib
40559
Engine should be hung next week!
On Feb 14, 2008, at 9:14 PM, Rick Sked wrote:
OK...
firewall will wrinkle, but get on your back, scoot your a!
off the soap box...
Risk Sked
40185
Koolmat user
David Maib
RV-10 #40559
New Smyrna Beach, FL
PostPosted: Fri Feb 15, 2008 6:07 am    Post subject: Koolmat Installation Reply with quote
Actually I didn't man to imply that the firewall was not structural but to inspect the firewall and not the structure behind it might allow one to miss damage to the structure behind the firewall.
Rick Sked
40185
GRANSCOTT(at)aol.com
PostPosted: Fri Feb 15, 2008 6:29 am    Post subject: Koolmat Installation Reply with quote
One of the largest contributors to deaths in aviation is post crash fires often caused by ruptured fuel tanks...has anyone reviewed fuel cell bladders?
The year's hottest artists on the red carpet at the Grammy Awards. AOL Music takes you there.
Kellym
PostPosted: Fri Feb 15, 2008 6:46 am    Post subject: Koolmat Installation Reply with quote
Choices, choices. How do you feel about an extra 35-40 lbs empty weight?
I would presume you would want to do slow build wings if you go that
direction.
cell bladders?
Kelly McMullen
KCHD
nicholscatoauto(at)aol.co
PostPosted: Fri Feb 15, 2008 7:03 am    Post subject: Koolmat Installation Reply with quote
Les
A word of caution when using the 3M yellow. If you use it you will have a very tough time to remove the Koolmat for inspection. It is a contact cement made for installing automotive weather stripping. It will make your installation permanent. Good stuff though for gluing together non similar items. I think for inspection purposes the silicone bead will work much better.
Just a thought
Jeff Nichols
KiloPapa
PostPosted: Fri Feb 15, 2008 6:41 pm    Post subject: Koolmat Installation Reply with quote
Maybe you could place a scrap of Koolmat on your keyboard
before you type....
Kevin
40494
----- Original Message Follows -----
Date: Thu, 14 Feb 2008 22:14:58 -0500 (EST)
<ricksked(at)embarqmail.com>
OK...
back, scoot your a!
soap box...
Risk Sked
40185
Koolmat user
Kevin
40494
PostPosted: Fri Feb 15, 2008 6:52 pm    Post subject: Koolmat Installation Reply with quote
LOL...OK...that's funny...you win.
Rick S.
kearney(at)shaw.ca
PostPosted: Fri Feb 15, 2008 7:56 pm    Post subject: Koolmat Installation Reply with quote
Hi
Thanks for the heads up. I plant to use RTV *sparingly*. I just couldn’t bring myself to use something called “gorilla snot”. My daughter would never let me hear the end of it….
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of nicholscatoauto(at)aol.com
Sent: February-15-08 7:59 AM
Les
Just a thought
Jeff Nichols
Page 2 of 3
