Hole Flanging
Goto page Previous  1, 2
ashontz
PostPosted: Fri Feb 15, 2008 7:13 am    Post subject: Re: Hole Flanging Reply with quote
As long as it works. I figured it was probably the die pinching something too much.
Ron Lendon wrote:
Andy,
The crowning I got in the rear ribs was all my fault for making the die clearance to small (I made em to close) and coining the parts in a press. It really was faster to just add the L-angles rather than all the hand work. The parts were flat before the flanging operation, and they are also flat now in the completed wing.
psm(at)ATT.NET
PostPosted: Fri Feb 15, 2008 9:06 am    Post subject: Hole Flanging Reply with quote
Hi guys,
The bowing of the ribs when using flanging dies is a characteristic
of metal bending rather than a fault with the dies. It is called
"Spring Back" and happens whenever metal is bent.
The spring back makes the web bow because it happens all the way
around the bent circle. It can easily be removed with a slotted
stick by bending the flange a little bit further than its final
position after going through the flanging die. You don't need to add
"L" reinforcements to straighten the rib webs.
A similar phenomenon happens when bending the flanges around the edge
of the ribs that makes them bow the rib web and have a less than 90
degree angle to the web. This can be fixed with the fore-mentioned
slotted stick or a small "Seaming" tool - a set of pliers with
somewhat fatter jaws. You can also use the pronged fluting tool
provided with Zenith kits for this purpose.
I don't know what the impact of adding "L"s to the ribs might be. It
probably is OK so long as you don't mind the small weight addition.
Have fun,
Paul
XL fuselage
At 07:08 PM 2/12/2008, you wrote:
William, I used the flanging dies made of wood and I experienced the
same problem as you did.
The rib webs were bowed.
ashontz
PostPosted: Fri Feb 15, 2008 9:18 am    Post subject: Re: Hole Flanging Reply with quote
I really haven't seen any bowing on my ribs. Theoretically, the flange part of the hole should get stretched slightly and the skin should get thinner, more so as you move more towards the hole part of the flange. If the skin doesn't get stretched enough to accommodate the larger diamter the flange edge is being pressed into in the die as the flange is formed, the rest of the rib will need to bow to accommodate it's new form. Measuring my rib hole flanges, at the very edge of the flange the skin is only about .021 whereas it started out as .025.
Taking this to the extreme, if the flange was wider, the sheet would get thinner and thinner to stretch around that hole, actually, it would crack first. I've had that happen once and it was due to not deburring the hole good enough before it went in the flange die.
psm(at)ATT.NET wrote:
Hi guys,
Have fun,
Paul
XL fuselage
n4546v(at)mindspring.com
PostPosted: Fri Feb 15, 2008 9:55 am    Post subject: Hole Flanging Reply with quote
Sounds like a good, workmanlike system to flange holes in ribs & short
parts, but you didn't answer my question you yourself quoted below: How
long does it take to stage things to do a hole in the center of a 12' wing
spar web?
Is your vise on a workbench? What supports must you organize to support
wing spar material you are flanging 6' on each side of your vise?
Best Regards,
Randy, Las Vegas
Subject: Re: Hole Flanging
Takes me about 60 seconds. I put one half of the die in the vise, put the
rib in, put the other die on top, put the bolt through with the plate on one
side, put the plate on the other side, put the nut on, tighten the nut by
hand, then use a wrench the rest of the way.
Last time I timed it (because I had to remake one with the form already
finished), it took me about 80 minutes to make a wing center rib from flat
sheet to fully finished rib with flanged holes.
n4546v(at)mindspring.com wrote:
> do not archive
> And, I didn't have to "juggle" any of the parts around. With your "nuts
> bolts & plates" how long does it take to get things positioned for each
> press, especially one in the middle of a 12' wing spar web?
ashontz
PostPosted: Fri Feb 15, 2008 10:16 am    Post subject: Re: Hole Flanging Reply with quote
Oh, spar hole. 5 minutes longer. I think I zipped my toolbox around one side and my table saw on the other side and then propped as needed.
Yes, my vise is on my workbench.
If I had to use the thing freehand for some reason, I don't see that being a problem either.
spar web?
Best Regards,
Randy, Las Vegas
> do not archive
Page 2 of 2
