Tefzel dielectric strength
shoskins(at)MCHSI.COM
PostPosted: Fri Feb 15, 2008 7:45 am    Post subject: Tefzel dielectric strength Reply with quote
I am installing a strobe system with a 50 watt power supply from Nova.
The system comes with a fairly heavy shielded 3-wire 18AWG cable that
has 300V printed on the jacket. It does not appear to be tefzell
coated. (I think it is mostly used in automotive applications, such
as police and fire vehicles).
Due to space constraints, I am unable the pass this thick cable
through the openings in my wing. However, the shielded 3-wire 22AWG,
from B&C will do the trick.
What is my risk for using the 22AWG vs. the 18 AWG?
Sam Hoskins Quickie Q-200
Murphysboro, IL
rampil
PostPosted: Fri Feb 15, 2008 10:33 am    Post subject: Re: Tefzel dielectric strength Reply with quote
Sam, I would like to try to answer your question, but I am not sure
I understand it. What does dielectric strength have to do it.
Gauge size of wire determines voltage drop across its length
Splicing in a short run of 22g will introduce 6 extra connections to reduce
reliability (but for a strobe, realistically, who cares!)
Is this cable, I presume the hot side of the strobe power, i.e., so the voltage is 500-1000 or so. Most insulation would be just fine. Dielectric
puncture is not only dependent on the material constant be also the thickness
Ira N224XS
nuckolls.bob(at)cox.net
PostPosted: Fri Feb 15, 2008 10:52 am    Post subject: Tefzel dielectric strength Reply with quote
The wire supplied with strobe kits is "Beldfoil" shielded
trio of PVC insulated wires. This is a grand-fathered wire
that was the best we could buy in 1967. Indeed, it's
quite suitable for this task and should not be held a
arm's length just because someone holds their nose over
it.
We did some calculations several years ago about the
potential for reduced light output for having switched
to 22AWG wires. It may have been so long ago that the
discussion was pre-matronics . . . on Compuserve's
AVSIG bulletin board!
The consensus was that it would probably be difficult
to measure the difference and you probably wouldn't "see"
it.
I think several folks tried it and reported satisfactory
performance. It would be REALLY interesting to wire up
a kit of strobes with the heads separated by a distance
of 30 feet or so. Wire the right side with 18AWG and
the other with 22AWG. Stand off about a mile and see
if the observer can perceive any difference in the two
flashes.
If someone would loan me their kit of strobe goodies,
I'll go do the experiment. I'll get a group of observers
unaware of which side is small wire to tell me if they
think one is noticeably different from the other.
( -Thomas Paine 1776- )
Neal.George(at)hurlburt.a
PostPosted: Fri Feb 15, 2008 11:45 am    Post subject: Tefzel dielectric strength Reply with quote
Bob -
You can use mine, if they ever come back from Whelen.
Neal
PostPosted: Fri Feb 15, 2008 12:55 pm    Post subject: Tefzel dielectric strength Reply with quote
At 01:42 PM 2/15/2008 -0600, you wrote:
605TES/TSI" <Neal.George(at)Hurlburt.AF.MIL>
Bob -
Neal
Okay, let's plan on it. It would be a short evening
of fun work to do the experiment. I'm only a few miles
from quiet country roads. No hurry . . .it's not going
to be warm enough to be enjoyable for a few more
weeks.
Bob. . .
PostPosted: Fri Feb 15, 2008 3:24 pm    Post subject: Tefzel dielectric strength Reply with quote
That sounds like logical information. What about the 300V rating on
the wire? Would the tefzel be similar? Here is the wire at B&C:
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?8X358218#s906-3-22
Sam
On Feb 15, 2008 12:49 PM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net> wrote:
it.
it.
flashes.
rampil
PostPosted: Fri Feb 15, 2008 4:50 pm    Post subject: Re: Tefzel dielectric strength Reply with quote
OK Bob,
Just remember that the human optical receiver system uses a log-sensitive
scale, so even a doubling of intensity (double the number of photons)
would be imperceptible. It would probably be easier to just measure the voltage spike on scope with the appropriate probe (admittedly not as much
fun)
Ira N224XS
PostPosted: Fri Feb 15, 2008 7:16 pm    Post subject: Tefzel dielectric strength Reply with quote
At 04:50 PM 2/15/2008 -0800, you wrote:
OK Bob,
fun)
But the 'real' question is not wether some techno-wienie can
measure the differences on a visual attention-getting/warning
system . . . but whether the guy expected to see and react
to it can see a difference. I plan to do both.
PostPosted: Fri Feb 15, 2008 7:33 pm    Post subject: Tefzel dielectric strength Reply with quote
I don't recall any of the tefzel wires being rated at less
than 600v. You can check through the listings for 22759 in
ETFE in the catalog at:
http://www.aeroelectric.com/Mfgr_Data/Wire/Standard_Wire_and_Cable/Std_Wire_Cable.pdf
I suspect B&C's shielded trio is 22759/16 or 22759/34
both of which are 600v insulations.
PostPosted: Sat Feb 16, 2008 5:14 am    Post subject: Tefzel dielectric strength Reply with quote
Sounds great, Bob. Big help! Thanks!
Sam Hoskins
Murphysboro, IL
On Feb 15, 2008 9:29 PM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net> wrote:
ceengland(at)bellsouth.ne
PostPosted: Sat Feb 16, 2008 9:04 am    Post subject: Tefzel dielectric strength Reply with quote
rampil wrote:
OK Bob,
fun)
Ira N224XS
And if you can't see the difference, why not go 'lighter'?
It would be advisable for builders to remember the same thing when they
get all over stimulated by the thought of going from a 50W halogen to a
75W halogen for their landing lights, etc etc etc.
Charlie
Smile
