chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Tue Feb 19, 2008 3:23 am Post subject: XL WING BOLTS?? |
I am looking at the main wing bolts on 6-W-4 and it states that the main wing is held on by 12X AN5-15A bolts but then
on page 6-S-3 it states Wing attachment bolts are 4 X AN5-16A and 8X AN5-15A.
I guess I should put the right bolts in. What have others used? I have the latest set of plans.
Chris.
Posted: Tue Feb 19, 2008 6:37 am Post subject: XL WING BOLTS?? |
Chris,
The AN5-16A (1/8th longer) bolts are probably to accommodate a thicker
section, or compensate for the inability to get washers, nuts on and
have the minimum
three threads exposed above the nut. It's possible the shorter ones work
as well, but you'll need to look at it first.
chris Sinfield wrote:
Chris.
Posted: Tue Feb 19, 2008 8:06 am Post subject: XL WING BOLTS?? |
The outer four bolts must be longer because they also pass through the four
upright angle brackets (6B13-1).
-- Craig
bryanmmartin
Posted: Tue Feb 19, 2008 9:12 am Post subject: XL WING BOLTS?? |
As I recall, the outermost four bolts pass through more layers of
metal than the other eight. That accounts for the longer length. My
plans called for all the same length, and that's what I used. I think
I just used an extra washer where needed to get the correct thread
engagement of the nuts. I think I have a washer under the bolt head on
most of my bolts but not on the outer four. I don't recall what length
my bolts are though.
AN5-15A.
Chris.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
jmcburney(at)pobox.com Guest
Posted: Wed Feb 20, 2008 7:06 am Post subject: XL WING BOLTS?? |
Hi, Bryan,
Rather than leaving out the washer under the bolt-head, a better way to get
proper thread exposure is to use thin washers, i.e., AN-960-516L. The
washer under the bolt-head serves as a bearing during tightening as well as
a spacer.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
bryanmmartin
Posted: Wed Feb 20, 2008 7:44 am Post subject: XL WING BOLTS?? |
As long as the bolt isn't turned while tightening the nut, a washer
isn't really needed under the bolt head, just under the nut. You need
a washer under a bolt head when tightening a bolt into a threaded hole.
It is a bit simpler to use the same size bolt for all twelve locations
though, especially when you're practically standing on your head in
the cabin and working by feel. I put the bolts in from the back of the
spar with the nuts exposed on the front side for ease of inspection. I
had to drill a couple of access holes through the seat pan to allow
the bolts to be inserted that way.
<jmcburney(at)pobox.com>
Hi, Bryan,
to get
well as
a spacer.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
