		lbgjb10
				 Posted: Thu Feb 21, 2008 11:35 am    Post subject: inner tubes |
				I want to order 'leak proof' inner tubes for 10.  Vans says nose wheel is 500x5-6.  do i get 500-5 inner tube??? I don't see any 500-6.  main gear is 15x 600-6.  I assume that is different from a standard 600-6??   anyone have experience with the different 'leak' proof brands. michelin quite a bit more expensive.   thanks.  lbb
		gerf(at)gerf.com Guest
				 Posted: Thu Feb 21, 2008 11:58 am    Post subject: inner tubes |
				When it came to replace the tires on my 9 I changed to Michelin Airstop
 tubes at the same time, the originals Vans supplied leaked live sieves.  I'd
 heard good things about Airstop tubes and I haven't been dissapointed -
 after 4 months and many, many landings I recently checked the pressure and
 they had barely lost 1 psi in 28.
 g
		scottmschmidt(at)yahoo.co Guest
				 Posted: Thu Feb 21, 2008 12:21 pm    Post subject: inner tubes |
				I just recently replaced my main tires and tubes with Goodyear Flight Custom III 15/6.00-6 and Leak Guard Tubes 15/6.00-6.  I'm not sure about the difference in size but there is a difference in weight capacity between a 6.00 and a 6.00-6.  So far, so good on the tubes but I have only had them for one month.  The tires are defiantly more beefy.
 I bought everything through Desser and received them very quickly.
 Tires and tubes is one area where I really didn't mind spending extra money.  My old tires went almost 300 hours and they say the compound on the Goodyear tires are 20% more wear resistant and the rubber thickness is quite a bit more.  Here is some data that Dresser posts on their site.
 http://www.desser.com/gy_perform.html
 http://www.desser.com/airtubes.html
 http://shop.desser.com/IW_Products.m4p.pvx?;MULTI_ITEM_SUBMIT
 Good luck.
 Scott Schmidt
 scottmschmidt(at)yahoo.com
		GRANSCOTT(at)aol.com Guest
				 Posted: Thu Feb 21, 2008 12:51 pm    Post subject: inner tubes |
				In a message dated 2/21/2008 2:01:08 PM Central Standard Time,  gerf(at)gerf.com writes:
  changed to airstop's 5 years ago...they are very good...not so with the  Michelin tires...wore out in less than 150 hours...
 Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
