Saddle
naumuk(at)alltel.net
PostPosted: Sat Feb 23, 2008 9:26 am    Post subject: Saddle Reply with quote
All-
Working it out with various listers. Will post a procedure once I come up with something workable. This is another one of those gaps in the manual. To begin with, looks like one should wait until rear top skins are installed.
    do not archive (Yet)
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
chris Sinfield
PostPosted: Sat Feb 23, 2008 1:15 pm    Post subject: Re: Saddle Reply with quote
Q For all those people that were talking about adjusting the Horizontal stab when flight testing.
how much messing about with the saddle was required for each change?
Did you have to buy a new fiberglass saddle each time ?
Could you flight test it without the saddle? get the right angle and then install the saddle?
Chris.
dredmoody(at)cox.net
PostPosted: Sat Feb 23, 2008 2:15 pm    Post subject: Saddle Reply with quote
Definitely Bill. Wait until you hav ethe rear top skin at least clecoed in place so you can work out how the saddle sits on the H-stab and how the saddle's forward edge mates up with the aft edge of the rear top skin. I jumped in a separate piece of .016 to allow me to cut the aft edge of the rear top skin far enough forward so that the H-stab can be placed and removed in a vertical path compatible with the brackets.
 Filesize:  122.75 KB
 Viewed:  457 Time(s)
larry(at)macsmachine.com
PostPosted: Sat Feb 23, 2008 2:26 pm    Post subject: Saddle Reply with quote
Chris,
Don't get side-tracked on stab position and stick with the drawing. Fly
it with the saddle in place and
let it go at that. Few people find the 601s stab a problem after the
build. More likely you'll find a CG problem
that needs to be taken care of before testing. Make sure you get that
right.
Chris.
daveaustin2(at)primus.ca
PostPosted: Sat Feb 23, 2008 7:11 pm    Post subject: Saddle Reply with quote
I adjusted the rear hor. stab. mounts. No need to do anything to the
saddle.
Dave Austin 601HDS - 912, Spitfire Mk VIII
richvetterli(at)yahoo.com
PostPosted: Sat Feb 23, 2008 9:11 pm    Post subject: Saddle Reply with quote
I installed my saddle yesterday and here's what I did.
From the plans, I plotted and drew out the top half
of the HT rib on a piece of cardboard. I cut that out
and used it to transfer the curve to the bottom of the
saddle with a sharpie. Sanded to the line and had a
nearly perfect fit. A little fine tuning and it was
ready to drill and cleco.
Rich Vetterli
Pleasanton, CA
CH601XL under construction
Check out my progress at: www.geocities.com/stixx5a
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
PostPosted: Sat Feb 23, 2008 9:46 pm    Post subject: Saddle Reply with quote
Rich-
Hmm. More than one way to skin a cat. I was going to level the saddle
and duct tape it directly on the stab. Then run a Sharpie line using a
spacer to get an acceptable height.
If nothing else, we're getting a lot of ideas into the archives. When I
looked this morning, there wasn't much to speak of.
bryanmmartin
PostPosted: Sun Feb 24, 2008 8:40 pm    Post subject: Saddle Reply with quote
I didn't have to make any changes to the saddle after re-pitching my
stabilizer. I did have to do some trimming to the rear end of the rear
top skin.
Chris.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
