Lynn Matteson
Posted: Sat Feb 23, 2008 12:23 pm Post subject: Weight Affected by Color of Plane |
If you assume (yeah, yeah, I know) the amount of paint in each can of
color is the same, and IF you assume the weight of each can is the
same, you can at least get a ballpark figure on the comparative
weights of each color. You will be assuming again that each color has
the same amount of evaporative components. But that should be the
same, I don't really know.
Lynn Matteson
flying w/475+ hrs
On Feb 23, 2008, at 2:14 PM, Clint Bazzill wrote:
| Quote: | NO NO NO
That doesn't work. The lightest (weight is) is white. Its pigment
is titanium dioxide and it the lightest. Red (iron oxide is the
very heavy) if you want light, paint white and use trim with
color. You can't weigh the paint in the can and come out with any
accurate results.
Clint
> From: fox5flyer(at)idealwifi.net
> To: kitfox-list(at)matronics.com
> Subject: Re: Weight Affected by Color of Plane
> Date: Sat, 23 Feb 2008 13:24:01 -0500
<fox5flyer(at)idealwifi.net>
> Steve, it would be simple enough to go into any automotive paint
supply with
> your handy dandy scale under your arm, grab a few assorted
gallons of paint
> and weigh them. If you decide to do that, it would be interesting
to hear
> your report.
> Deke Morisse
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Sbennett3(at)aol.com Guest
Posted: Sat Feb 23, 2008 4:32 pm Post subject: Weight Affected by Color of Plane |
Ok fellers... Paint yer plane and go fly it... If you're so worried about weight, buy a more powerful engine... Geesh i'm tired of reading these paint weight posts... Steve Bennett fox 4 912 speedwing... And my plane is white...
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
Float Flyr
Posted: Sat Feb 23, 2008 7:15 pm Post subject: Weight Affected by Color of Plane |
Considering that a full gallon of paint will only have a few CC of actual
pigment the difference would be hard to measure even with analytical scales
and accurate measuring devices. The thickness the paint is applied will
have more effect than the difference in colours.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Sun Feb 24, 2008 8:25 am Post subject: Re: Weight Affected by Color of Plane |
Hey guys,
Sorry I asked. The original question was legit. So, go fly your planes, or at least, talk about doing it.
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel |
