Things to order from Vans and others
kearney(at)shaw.ca
PostPosted: Sun Feb 24, 2008 4:49 pm    Post subject: Things to order from Vans and others Reply with quote
Hi
I have been wandering through the Van’s website looking for bits and bobs to order along with a replacement for a piece of aluminium I turned into scrap today.
I noticed that there is an aileron trim kit and was wondering how necessary it is on the -10. Any comments? I seem to remember reading that the aileron trim was not as necessary on the -10 as rudder trim.
I also saw *somewhere* some barrel connectors used to connect wires between the wings & the fuse. Does anyone have a part number for these connectors?
Inquiring minds need to know
Les Kearney
#40643
C-GCWZ (reserved)
jesse(at)saintaviation.co
PostPosted: Sun Feb 24, 2008 6:29 pm    Post subject: Things to order from Vans and others Reply with quote
On the connectors, CPC Series 1 or 2 from www.mouser.com. Stein's molex pin crimp tool is great for the series 1 and the D-sub crimper for series 2 (the Series 2 machined closed barrel pins are the same as the D-sub pins, but are only good up to 20 gauge wire, I think).
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Feb 24, 2008, at 7:40 PM, Les Kearney wrote:
Hi
Les Kearney
#40643
C-GCWZ (reserved)
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
Albert Gardner
PostPosted: Sun Feb 24, 2008 8:19 pm    Post subject: Things to order from Vans and others Reply with quote
Rudder trim is far more of a “nice but not really necessary” option than aileron trim. The trim kit is very easy to install at any point or even after the plane is finished. Put the 5 wire cable in place during construction and plan ahead for space of the IP for a switch and indicator and you would be ready to add trim later. The kit is about $350 ordered as an option. Rudder trim at cruise can be a simple tab or wedge on the rudder as required but many of us would like to have adjustable rudder trim.
Albert Gardner
N991RV
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Tim Olson
PostPosted: Sun Feb 24, 2008 9:12 pm    Post subject: Things to order from Vans and others Reply with quote
I'm not so sure.... If I were to be forced to choose today between
my rudder trim and my aileron trim, it would be a very hard choice.
The rudder trim I would never do without if I ever built another plane.
The spring bias aileron trim though isn't all that fantastic
in how it works. The -10 does have long tanks, so fuel imbalance
can happen pretty easily, so I really don't think I'd build a -10
without aileron trim either, but I don't find that I use it as much
as I use my rudder trim.
To me, they're probably both things that would be very smart to
wire for, because I think most people would really want both once
they've had the time to fly behind them both.
Albert Gardner wrote:
[quote] Rudder trim is far more of a “nice but not really necessary” option than
Albert Gardner
N991RV
Yuma, AZ
kearney(at)shaw.ca
PostPosted: Sun Feb 24, 2008 9:25 pm    Post subject: Things to order from Vans and others Reply with quote
Jesse
Many thanks. This is just what I needed.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: February-24-08 7:25 PM
Subject: Re: Things to order from Vans and others
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Hi
Les Kearney
#40643
C-GCWZ (reserved)
http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
robin1(at)mrmoisture.com
PostPosted: Sun Feb 24, 2008 10:27 pm    Post subject: Things to order from Vans and others Reply with quote
Les,
  One more suggestion… RV-8 QuickBuild?
  Just a suggestion. What, I’m the only smart ass left on the RV-10 list?
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Sunday, February 24, 2008 9:19 PM
Subject: RE: Things to order from Vans and others
Jesse
Cheers
Les
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Hi
Les Kearney
#40643
C-GCWZ (reserved)
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
5
6
7
8
9
