apilot(at)surewest.net Guest
Posted: Wed Feb 20, 2008 9:04 am Post subject: The Kolb drop |
VG's definitely make my Mark III land easier and lighter. I lost around 3 or 4 mph cruise with them. Hopefully, I will find an airspeed that makes good use of the VG effect and increase my range by lowering the rpms required to give a slower and more economical cruise. I would like 60 mph at a fuel burn of 2 gallons per hour. Probably the VG effect will not happen until the airspeed lowers to around 50 mph. Need a wind tunnel.
JetPilot
Posted: Wed Feb 20, 2008 9:21 am Post subject: Re: The Kolb drop |
Seems many are missing the point in this thread, the reasons for the Kolb Drop are well known, and with proper landing techniques, it can be dealt with.
The more important point is that VG"s make the Kolb Drop much less severe. Pilots are human, no one lands perfectly all the time. VG's can make the difference between bent gear, and just a less than perfect landing. I would much rather have plane that is more forgiving on landing, rather than one that probably result in damage the first time I flare a bit high.
It is obvious that the people that are saying VG's don't make landings in a Kolb much more docile are the people that dont have VG's.
Mike Bigelow
Kolb MK-III Xtra, 912-S |
gaman(at)att.net Guest
Posted: Wed Feb 20, 2008 9:23 am Post subject: The Kolb Drop |
Maybe a little refresher course on gravity and airspeed would be helpful if they are having difficulty with the earth jump concept.Someone said the earth sucks when you get that close to it.
Possums
Posted: Wed Feb 20, 2008 3:48 pm Post subject: The Kolb Drop |
At 10:24 AM 2/20/2008, you wrote:
May be Kolb Drop should be redefined as Earth Jump. Earth Jump can be
equally applied to all aircraft with out giving undue credit and it easily
explains away why the earth is not in the correct position when these pilots
flared or were repositioning their aircraft.
Jack B. Hart FF004
Winchester, IN
Basic Flying Rules:
1. Try to stay in the middle of the air.
2. Do not go near the edges of it.
3. The edges of the air can be recognized by the appearance of the ground,
buildings, sea, trees and interstellar space.
It is much more difficult to fly there.
_________________ Possum |
johnjoyes
Posted: Thu Feb 21, 2008 1:40 am Post subject: Re: The Kolb drop |
Those of you arguing about the "Kolb Drop" might like ti hear my completely different experience, when I too bent the legs of my Mk3.
I was storming in, two-up, much faster than usual, a steep descent, almost a dive, with no flap, throttle fully off. When I came to flare, the stick came all the way back to the stop with zero resistance, while the plane carried straight on (into the ground) with no attempt to flare.
My inspector says I would be amazed to know how many aircraft there are out there with some combination of attitide and speed where the tail is caught in a vortex from the main wing, and does nothing.
Because of the speed, this could not be a stall. The remedy is to learn the characteristics of your plane, at a safe altitude. Now I always keep a bit of power on for landing, to ensure airflow over the tail.
I like the idea of VG's and hope to try them out. But in view of my experience, the place to put them first is on the underside of the tailplane just ahead of the elevator.
JJ
Posted: Thu Feb 21, 2008 2:50 am Post subject: The Kolb drop |
arguing about the "Kolb Drop" >>
If we are to continue talking unendingly about this phenomenon, even when
there cannot be a single syllable which has not been repeated ad infinitum,
can we please call it the `Kolb Quit` not the `Kolb Drop`.
Kolb Quit has a nice alliterative feel to it and makes it easier for those
of us who move their lips when they read.
Cheers
Pat
Dana
Posted: Thu Feb 21, 2008 4:29 am Post subject: The Kolb drop |
At 04:41 AM 2/21/2008, johnjoyes wrote:
| Quote: | Because of the speed, this could not be a stall.
Not saying it's what happened, but stall is a function of AOA, not speed.
| Quote: | I like the idea of VG's and hope to try them out. But in view of my
If the tailplane had stalled, that might have helped. But VG's on the
tail won't keep the wing from stalling.
-Dana
Why is it called tourist season if we can't shoot at them?
Posted: Thu Feb 21, 2008 5:44 am Post subject: The Kolb drop |
| Quote: | there cannot be a single syllable which has not been repeated ad
infinitum, can we please call it the `Kolb Quit` not the `Kolb Drop`.
Patrick:
Sorry to correct you but, Kolb aircraft do not suffer from Kolb Quit or Kolb
Drop, only the pilots do.
Personally, I do not like the terms. They tend to implie Kolb aircraft have
a problem, when in reality there is none. Pilots of some Kolbs have a
problem landing. In fact, some Kolb pilots have problems taxiing and flying
them.
Take care,
_________________ John Hauck
Titus, Alabama |
Posted: Thu Feb 21, 2008 7:21 am Post subject: The Kolb drop |
Drop, only the pilots do>>
Absolutely right John, as usual.. If an aircraft loses flying speed 6 ft up
instead of 6 inches it will stop flying however it is spelt
Cheers
Pat.
Posted: Thu Feb 21, 2008 5:09 pm Post subject: The Kolb drop |
Charlie England wrote:
| Quote: | There's a much better option. Just install a message 'filter' so you
never see posts from people you find offensive. It works great; only
fails when someone else responds to the offensive poster (hint, hint).
If you need help setting up the filter, I'm sure there are several
people on this list who would help, including me.
Charlie
N27SB(at)aol.com wrote:
> Only an idiot would not recognize there very real fact. I have
> instructed in the Kolb, and as a CFI in general aviation aircraft.
> That's it, I've had it, time to unplug for a while.
> Steve
> In a message dated 2/19/2008 8:37:52 A.M. Eastern Standard Time,
> orcabonita(at)hotmail.com writes:
> Kolb's have the characteristic of suddenly dropping hard on
> landing if very good technique is not used. Cessna and other
> most other training aircraft are not like this, they are much
> more forgiving on landing and tolerant of the pilot being a
> little off speed, or a little high in the flare. Only an idiot
> would not recognize there very real fact. I have instructed in
> the Kolb, and as a CFI in general aviation aircraft. In General
> aviation aircraft, I can let students get much further off speed,
> or flare a lot higher on landing than in a Kolb, and not bend the
> gear or result in a very hard landing. Hundreds of students
> flare high, land slow, etc etc every day in Cessnas and other
> aircraft and you do not constantly bend the gear, partly due to
> stronger gear, and partly to do much more forgiving aerodynamics.
> The other fact is that on my Kolb MK III, VG's have done a lot to
> correct this bad habit of dropping suddenly and hard upon
> landing. VG's do not solve this problem entirely, but my Kolb MK
> III is not anywhere near as critical in landing as it was, and it
> does not drop nearly as hard if I am a few feet high as it did
> without VG's. I don't care so much about the theory, or what
> some may say about stalls, the FACT is that VG's make landings
> much easier and less critical in my Kolb, and that is a great thing.
> Mike
> http://forums.matronics.com/viewtopic.php?p=164998#164998
Posted: Sat Feb 23, 2008 11:54 am Post subject: The Kolb drop |
Dana Hague wrote:
the tail won't keep the wing from stalling.
-Dana
Actually, loss of elevator effectiveness can be a real problem, either
from blanking in the wing's turbulence or an actual tail stall. If it
happens, the wing doesn't stall; it just continues on its existing path
without increasing its angle of attack. Remember, the elevator is trying
to push the tail down. If that doesn't happen, the wing's angle of
attack won't increase.
A real world example is the Cessna Cardinal. The early ones ran out of
stabilator authority in the landing & couldn't be flared adequately. The
fix was a leading edge slat on the stabilator that's 'upside down' in
the stab. Slightly different technique to achieve the same thing as the
bottom side VG trick: keep the air attached to the low-pressure side of
the control surface.
http://en.wikipedia.org/wiki/Cessna_177
Charlie
Dana
Posted: Sat Feb 23, 2008 5:48 pm Post subject: The Kolb drop |
At 02:51 PM 2/23/2008, Charlie England wrote:
| Quote: | Actually, loss of elevator effectiveness can be a real problem, either
to push the tail down. If that doesn't happen, the wing's angle of attack
won't increase.
If the tailplane stalls, I would expect the aircraft to pitch down, no?
| Quote: | A real world example is the Cessna Cardinal. The early ones ran out of
fix was a leading edge slat on the stabilator that's 'upside down' in the
stab. Slightly different technique to achieve the same thing as the bottom
side VG trick: keep the air attached to the low-pressure side of the
control surface.
DId the Cardinal tailplane actually stall or just "run out of
authority"? If it stalled, I would expect it to pitch down, as I said...
if it simply wasn't effective enough that's different.
-Dana
Balance the budget--declare politicians a game species.
Posted: Sat Feb 23, 2008 7:25 pm Post subject: The Kolb drop |
From my dim memory the hearsay was that the early Cardinal would get
stuck in a position on takeoff
where it would just roar off the end of the runway without climbing
out of ground effect.
Never actually watched it happen.
They did put those slots on the tail though.
BB
On 23, Feb 2008, at 8:42 PM, Dana Hague wrote:
> either from blanking in the wing's turbulence or an actual tail
> stall. If it happens, the wing doesn't stall; it just continues on
> its existing path without increasing its angle of attack.
> Remember, the elevator is trying to push the tail down. If that
> doesn't happen, the wing's angle of attack won't increase.
no?
> out of stabilator authority in the landing & couldn't be flared
> adequately. The fix was a leading edge slat on the stabilator
> that's 'upside down' in the stab. Slightly different technique to
> achieve the same thing as the bottom side VG trick: keep the air
> attached to the low-pressure side of the control surface.
said... if it simply wasn't effective enough that's different.
-Dana
biglar
Posted: Sat Feb 23, 2008 8:09 pm Post subject: The Kolb drop |
Most of it's lost in the hazy mists of antiquity and the Lar's aging
memory, but 8 or 10 years ago I checked out in a '68 (I think) Cardinal
that had been upgraded to the horizontal stabilizer slots and I don't
remember hearing about that one. Biggest thing the instructor worried
about was sudden control movements on final approach. It was very
touchy and easy to get porpoising on short final - a real attention
getter - but, with a gentle, steady touch, it did work. I MUCH prefer
the C-172.
Biggest reason I only rented it 3 or 4 times was the awful lack of
power. Seems (as I recall) like it had the 150 hp engine, and it had
less apparent power than a C-150. With 2 up it took forever to get
airborne, climb was only 300 or 400 fpm and I always felt like it was
borderline on a stall. This one had the original high performance wing,
too. Stalls practiced at 3500 feet AGL were scary - it would suddenly
just quit and drop like a stone. I was told that the later 180 hp
versions with the milder wing were very nice to fly. Wish I could have
tried one. Visibility out of the Cardinal was the best of any GA
aircraft I've flown in. Entry and exiting the plane were very easy,
too. Almost a goodie. Lar. Do not
Archive.
robert bean wrote:
BB
>> its existing path without increasing its angle of attack. Remember,
>> the elevator is trying to push the tail down. If that doesn't
>> adequately. The fix was a leading edge slat on the stabilator that's
>> 'upside down' in the stab. Slightly different technique to achieve
>> the same thing as the bottom side VG trick: keep the air attached to
> -Dana
> do not archive
Larry Bourne
Santa Fe, NM
Building Kolb Mk III
"Vamoose"
www.gogittum.com
www.gogittum.com/blog
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Sun Feb 24, 2008 3:07 am Post subject: The Kolb drop |
the wing doesn't stall; it just continues on its existing path without
increasing its angle of attack. Remember, the elevator is trying to push the
tail down. If that doesn't happen, the wing's angle of attack won't
increase>>
Hi,
It will as the speed drops off. The angle of attack may remain constant in
relation to the ground but NOT in relation to the airflow. As the plane
slows and begins to sink the Apparent wind will come increasingly from below
and the wing will stall.
Cheers
Pat.
Posted: Sun Feb 24, 2008 7:29 am Post subject: The Kolb drop |
pj.ladd wrote:
trying to push the tail down. If that doesn't happen, the wing's
angle of attack won't increase>>
Hi,
constant in relation to the ground but NOT in relation to the airflow.
As the plane slows and begins to sink the Apparent wind will come
increasingly from below and the wing will stall.
Cheers
Pat.
I believe that the original post referred to diving toward the ground &
getting no elevator response when he attempted to flair, & blamed it on
the tail being ineffective because it was in disturbed air. If that
happened, the wing wouldn't have increased its angle of attack. If the
tail never forces a change in the wing's angle of attack, the plane
won't slow down until it hits something. It will just attempt to
maintain trimmed airspeed by pitching down. A high thrust line pusher
would be different since pulling power effectively changes trim, but
didn't the original post say he was descending power off?
Charlie
Posted: Mon Feb 25, 2008 7:37 am Post subject: The Kolb drop |
Hi Charlie
the plane won't slow down until it hits something.>>
That will do ut every time.
Pat
