		jeffrey_davidson(at)earth Guest
				 Posted: Sat Feb 23, 2008 1:21 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				All,
 I'm working with the seats now too.  I have found that there really are
 three parts to the seats.  These are the cushions, the seat backs, and the
 upholstery.
 My manual suggests plywood as the seat back material.  The fiberglass
 (reinforced plastic) solution as shown on the CH601.org web site appears to
 be a better solution.  I guess I'll just have to learn to use fiberglass.
 For the cushions, several types of foam are available from common soft foam
 to Confor Foam.  Both Hi-Tech Seats and Oregon Aero have patterns for the
 601 using Confor foam.  Oregon Aero is more than twice the price of Hi-Tech,
 but includes a multi-piece seat with professionally contoured shapes.  Does
 anyone have either installed?
 I checked with a local auto upholstery shop, and getting the cover done
 should be the easiest part.
 I have a couple questions:
 How far above the baggage shelf should the headrest portion of the seatback
 extend to protect our heads?  Most of the pictures I see just have a large
 arc or simple straight edge as the top of the seat back.  Is there a reason
 that there is no head rest?  Should the seats be more like the bucket seats
 in a car with integral head rests?  Is it just personal preference? I just
 measured my plane and came up with 300 mm above the shelf for the top of the
 headrest assuming a 3 inch foam seat over the seat pan.  How do the
 Flightcrafters or Zenith seats compare?
 Thanks ....
 Jeff D.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sat Feb 23, 2008 2:46 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				Hi Jeff,
 The seats are easily done with plywood backs or fiberglass.  Automotive
 foams are cheaper and perhaps
 easier to get hold of at many sewing and fabric outlets.  Density is
 something you want to pay attention to.
 Confor foam is expensive beyond practical concerns, but for flammability
 perhaps. I've a page on
 seat construction that may explain the process.  See link below.
 Seat backs need only go an inch or more above the shelf or to shoulder
 support height.  Easier to get
 belts over your shoulders if you don't go too high. Head rests are for
 the flying public and passengers
 but I wouldn't recommend them because of a need for access to the rear
 shelf during flight.
 http://www.macsmachine.com/html/seatupholstery.htm
 Good luck,
 Jeff wrote:
  All,
  upholstery.
  Thanks ....
  Jeff D.
		Larry Hursh
  Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
				 Posted: Sun Feb 24, 2008 1:19 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				Larry, I have a question about the seats and maybe you can answer it for me.  I was wondering if there's such a thing as replacing the permanently mounted seats with a moveable seat like that in a Cessna?  I'm a pretty short legged pilot and if I mount the seats too close to the pedals, any of my friends that are much taller than I will have a dickens of a time with the seat being too close for them.  I've only started my XL but I've been wondering how others have handled it.  When AMD builds the Alarus (mother to the XL), how do they handle the seating in those??  I'm sure there are a lot of them out here being used for General Aviation.  Any help you could offer here will put my mind at ease some.
   Larry H
 LarryMcFarland <larry(at)macsmachine.com> wrote:
   [quote]--> Zenith-List message posted by: LarryMcFarland
 Hi Jeff,
 Good luck,
 Jeff wrote:
 [quote] --> Zenith-List  message posted by: "Jeff "
  All,
  upholstery.
  I checked with a local auto upholstery shop, and getting the cover       Be a better friend, newshound, and  [quote][b]
  _________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
				 Posted: Sun Feb 24, 2008 5:13 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				Hi Larry,
 I'd recommend you build the seats to fit the 6'-2" person and after
 getting the proportions right for comfort disregarding the length of
 your legs, make the seat back adjustable
 both top and bottom to allow it to be positioned forward a distance that
 you feel best with at the pedals.  There are several spacer types or
 adapters that would position your seat forward an inch or two so you get
 a good fit.  I don't see any benefit in trying a track on the bottom of
 the seat when it's basically making the seat-back do the work.
 The seat bottom is one plane of reference that can be fixed and the seat
 back may more easily be made adjustable. This would be my approach.
 Take note of the bottom channel that holds the bottom of my seat-back
 and imagine two rows of channel and bolt in spacers at the top.  I use
 bungees for the top of my seats going back inside to hold them in place.
 Larry McFarland
 Larry H wrote:
  	  | Quote: | 	 		   Larry, I have a question about the seats and maybe you can answer it
  mind at ease some.
  Larry H
  */LarryMcFarland <larry(at)macsmachine.com>/* wrote:
      Hi Jeff,
      Automotive
      flammability
      shoulder
      for
      rear
      Good luck,
      Jeff wrote:
      > All,
      really are
      backs, and the
      > upholstery.
      appears to
      fiberglass.
      common soft foam
      for the
      of Hi-Tech,
      shapes. Does
		bryanmmartin
				 Posted: Sun Feb 24, 2008 8:10 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				On my plane, I used 5.2 mm plywood for the seat backs. This is the
 stuff used for providing a smooth surface under vinyl flooring. I had
 some scrap pieces of it left over from a home project. It has worked
 out well for me. I made the seat cushions out of the foam from Hi-Tech
 foams. It is expensive but also extremely comfortable. I flew the
 plane from Midland, Michigan to Lakeland Florida for Sun'N'Fun in
 2005. The trip down involved about twelve hours of flight time and the
 only complaint I had was that I wasn't able to streach my legs out
 much in flight. I had no discomfort from the seat cushions at all. The
 thirteen hour return trip I completed in one day and after sitting in
 the seat pretty much all day, my butt and back didn't hurt at all.
 I've suffered more discomfort from two hour trips in Cessna 150s.
 On Feb 23, 2008, at 4:18 PM, Jeff wrote:
  All,
  are
  and the
  upholstery.
  appears to
  fiberglass.
  soft foam
  for the
  Hi-Tech,
  shapes.  Does
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
				 Posted: Mon Feb 25, 2008 3:08 am    Post subject: Seats: seat backs, cushions, and upholstery |
				The biggest reason for headrests is that after a rapid deceleration against a restraint like a seat belt or even a shoulder harness your head will snap back. If there is no cushion/stop to limit the travel hyperextension of the neck and even fracture associated with only the snap back can occur.
 Jeff  <jeffrey_davidson(at)earthlink.net> wrote:[quote] --> Zenith-List message posted by: "Jeff "
 All,
 upholstery.
 measured my plane and came up with 300 mm above the shelf for the top of      [quote][b]
		klaus(at)utdallas.edu Guest
				 Posted: Mon Feb 25, 2008 2:09 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				Hi,
 Another possible choice are the seatbacks used in the RV6. We used that
 in my
 plane. They are lightweight and strong.
 Happy building and flying,
 Klaus
 www.utdallas.edu/~klaus
		ding(at)tbscc.com Guest
				 Posted: Mon Feb 25, 2008 7:01 pm    Post subject: Seats: seat backs, cushions, and upholstery |
				Seat Builders,
                             I used 1/4 " birch plywood from Lowes for seat
 backs, and it worked out well. I punched several large holes in them to keep
 them light, something I'm rather anal about (so I'm told!). They can be
 purchased in 2' x 2' pieces.                               A few miles up
 the road fron me is an upholstery supply place. I bought three grades of
 foam in 1" thicknesses.  An electric kitchen knife, spray glue, and a few
 hours later I had nicely shaped, stylish, light and comfy cushions ready for
 my sister-in-law to upholster. About $70 invested.
                                                     Lynn          Corry, PA
 601 XL / Corvair
		Gig Giacona
				 Posted: Tue Feb 26, 2008 7:08 am    Post subject: Re: Seats: seat backs, cushions, and upholstery |
				So those would be anal holes?
 DO NOT ARCHIVE
  	  | ding(at)tbscc.com wrote: |
 them light, something I'm rather anal about (so I'm told!).  |
601XL Under Construction
		Larry Hursh
				 Posted: Tue Feb 26, 2008 8:17 am    Post subject: Seats: seat backs, cushions, and upholstery |
				And Gig, I would suspect those a a lot different than "lightning holes", correct?  I would certainly HATE to get those two mixed up - or worse yet, mixed together......
 Gig Giacona <wr.giacona(at)suddenlink.net> wrote:
   [quote]--> Zenith-List message posted by: "Gig Giacona"
 DO NOT ARCHIVE
 W.R. "Gig" Giacona
 Read this topic online    [quote][b]
