rv10(at)sinkrate.com Guest
Posted: Mon Mar 03, 2008 1:26 pm Post subject: baggage floor access plate for step |
I am pondering adding an access hole/plate on the baggage floor that would allow one to get at the step attach hardware. Has anyone done this? What are some thoughts on it? Pictures?
-Ben
Dave(at)AirCraftersLLC.co Guest
Posted: Mon Mar 03, 2008 1:50 pm Post subject: baggage floor access plate for step |
Ben,
I'd show you a picture of the hole through the baggage floor, but it got covered up by the side panel. Doh.
Next time I'll put a nutplate on the top of the step socket and put the bolt in from the bottom, through the belly.
This is by no means overkill. We've replaced a few RV steps for one reason or another.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Monday, March 03, 2008 1:23 PM
Subject: baggage floor access plate for step
-Ben
planesmith(at)hotmail.com Guest
Posted: Mon Mar 03, 2008 2:16 pm Post subject: baggage floor access plate for step |
Slick idea!
Vern Smith (#324)
| Quote: | From: Dave(at)AirCraftersLLC.com
Subject: RE: baggage floor access plate for step
Date: Mon, 3 Mar 2008 13:49:23 -0800
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;} Ben,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
| Need to know the score, the latest news, or you need your Hotmail®-get your "fix". Check it out. [quote][b]
seipel(at)seznam.cz Guest
Posted: Mon Mar 03, 2008 2:43 pm Post subject: baggage floor access plate for step |
I used the parts for the stall warning horn access panel. I had to
drill the bolt hole in the steps from the side, however, to be able to
get the bolt in because of how I oriented the access panel. If you
rotate it to the right about 30 degrees or so, I believe you can still
put the bolt in per the plans.
PJ Seipel
RV-10 #40032
Ben Westfall wrote:
-Ben
Posted: Mon Mar 03, 2008 2:46 pm Post subject: baggage floor access plate for step |
Sorry, forgot the picture.
PJ Seipel
PJ Seipel wrote:
| Quote: | I used the parts for the stall warning horn access panel. I had to
PJ Seipel
RV-10 #40032
> -Ben
29.39 KB |
634 Time(s) |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
robin1(at)mrmoisture.com Guest
Posted: Mon Mar 03, 2008 4:30 pm Post subject: baggage floor access plate for step |
Ben,
I think it’s an excellent idea especially when working around the plane during construction. Think of it as Shin Insurance because you will whack yourself and it can hurt. Then you will hit your already tender shin in the exact same place and it will hurt even more. We powder coated our steps a smoke chrome and I wanted it to be removable in case the PC didn’t hold up. Additionally mine are removal for the Reno Air Races. Watch out Bearcat!
Robin
Photos Attached
45.98 KB |
642 Time(s) |
36.25 KB |
586 Time(s) |
Posted: Mon Mar 03, 2008 5:31 pm Post subject: baggage floor access plate for step |
That looks pretty good but how are you going to get the bolt out? Is there room if you move the access panel all the way next to the wall panel to lift the bolt up?
-Ben
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Monday, March 03, 2008 4:27 PM
Ben,
Robin
Photos Attached
Posted: Mon Mar 03, 2008 6:53 pm Post subject: baggage floor access plate for step |
You either have to have a big enough hole for the head of the bolt in the bottom skin and put the bolt in from underneath or you have to have the hole in the baggage floor to get it out from there. I don't think you can get the access panel close enough to actually pull the bolt out through it.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 3, 2008, at 8:28 PM, Ben Westfall wrote:
| Quote: | That looks pretty good but how are you going to get the bolt out? Is there room if you move the access panel all the way next to the wall panel to lift the bolt up?
-Ben
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Robin Marks
Ben,
Robin
Photos Attached
| Quote: | http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
orchidman
dlm46007(at)cox.net Guest
Posted: Mon Mar 03, 2008 7:54 pm Post subject: baggage floor access plate for step |
Just a thought but Cessna on occasion drilled a bolt insertion hole directly over the bolt and had an circular access panel below or adjacent to the bolt for hand access to tighten or loosen the bolt. the bolt insertion hole was covered with a chrome cap.
Sent: Monday, March 03, 2008 6:28 PM
-Ben
Ben,
Robin
Photos Attached
Posted: Mon Mar 03, 2008 11:46 pm Post subject: baggage floor access plate for step |
Bingo! Ben.
Lew, sorry I am on the road and have too many moving parts these days to reply quickly.
There is a ½” hole drilled directly above the bolt (no pictured). That hole is normally plugged with a plastic panel plug and then the entire area covered with carpet.
Regarding the door seal we used a seal sold by McMaster Carr not the vans seal. Sorry I don’t have the style number.
(Photo attached)
Regarding the nut installation for the door, it’s not that difficult to remove and I hope the doors will not have to be taken off many more times. At least not till the first flight J
We cleaned up under the hinge a bit but ours do sit pretty flush. The metal is bent a bit down into the recess we made for the cover. There are a number of different ways to do this including living with a small bump at each hinge point.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Monday, March 03, 2008 7:50 PM
-Ben
Ben,
Robin
Photos Attached | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4
27.74 KB |
592 Time(s) |
Posted: Tue Mar 04, 2008 2:09 am Post subject: baggage floor access plate for step |
Or drill the hole in the step horizontally. Then you can get the bolt
in and out no problem.
PJ Seipel
RV-10 #40032
Jesse Saint wrote:
| Quote: | You either have to have a big enough hole for the head of the bolt in
Jesse Saint
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
Cell: 352-427-0285
Fax: 815-377-3694
> -Ben
> *From:* owner-rv10-list-server(at)matronics.com
> <mailto:owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server(at)matronics.com] *On
> Behalf Of *Robin Marks
> *Sent:* Monday, March 03, 2008 4:27 PM
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
> *Subject:* RE: baggage floor access plate for step
> Ben,
> Robin
> Photos Attached
> *http://www.matronics.com/Navigator?RV10-List
Posted: Tue Mar 04, 2008 5:56 am Post subject: baggage floor access plate for step |
I purchased 2 extra of the stall warning access panels rom Vans. I installed these in the floor inboard of the step bolts for hand access. I drilled a hole in the lower skin large enough to just clear the bolt head and stuck in a hole plug.
It works great, but I like the idea of redrilling the hole horizontal and not having the hole in the bottom skin...
-Mike Kraus
RV-4 Flying
RV-10 FWF and wiring
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Mar 04, 2008 8:35 am Post subject: baggage floor access plate for step |
Here is what I did.
http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&category=613&log=14961&row=36
It’s a push to release pin. Got it from McMaster/Carr or Grainger or someone. Also using one on my passenger side stick.
Michael
Sent: Monday, March 03, 2008 9:50 PM
Just a thought but Cessna on occasion drilled a bolt insertion hole directly over the bolt and had an circular access panel below or adjacent to the bolt for hand access to tighten or loosen the bolt. the bolt insertion hole was covered with a chrome cap. [quote] [b]
