john(at)roadmapscoaching. Guest
Posted: Wed Mar 05, 2008 6:09 am Post subject: Another lesson with windows |
I finished priming the canopy and windows last week and had a problem (Dupont Colar high build primer). The primer did not stick well to the Plexiglas and I was able to easily scrape it off with a razor blade - not good. Before priming, I prepped my rear windows and windshield by scuffing the plexi real well and taping the edge. I then cleaned with mineral spirits. I believe that I have read that you should not use Acetone or MEK on the windows - causes crazing. So I used mineral spirits - that was the mistake. My painter believes that the oil in mineral spirits caused the problem. Has anyone else had a similar experience?
I really miss the good ole days of riveting!
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Paint prep, interior, and LOTS of little stuff
3/4/2008 9:46 PM
apilot2(at)gmail.com Guest
Posted: Wed Mar 05, 2008 6:26 am Post subject: Another lesson with windows |
Use isopropyl alcohol on plexi. Get the higher purity 91% variety at aviation section of Walgreens or equivalent. Very effective for removing oils, etc.
On Wed, Mar 5, 2008 at 7:06 AM, John Testement <john(at)roadmapscoaching.com (john(at)roadmapscoaching.com)> wrote:
[quote] I finished priming the canopy and windows last week and had a problem (Dupont Colar high build primer). The primer did not stick well to the Plexiglas and I was able to easily scrape it off with a razor blade - not good. Before priming, I prepped my rear windows and windshield by scuffing the plexi real well and taping the edge. I then cleaned with mineral spirits. I believe that I have read that you should not use Acetone or MEK on the windows - causes crazing. So I used mineral spirits - that was the mistake. My painter believes that the oil in mineral spirits caused the problem. Has anyone else had a similar experience?
John Testement
40321
Richmond, VA
3/4/2008 9:46 PM
msausen
Posted: Wed Mar 05, 2008 6:53 am Post subject: Another lesson with windows |
I believe the ISO-Heat variety of fuel dryer is also 91%.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Wednesday, March 05, 2008 8:24 AM
Subject: Re: RV10-List: Another lesson with windows
John Testement
40321
Richmond, VA
3/4/2008 9:46 PM
| Quote: | | _-============================================================_-=Â Â Â Â Â Â Â Â Â - The RV10-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ, | 0123456789012
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Wed Mar 05, 2008 7:24 am Post subject: Re: Another lesson with windows |
Printer (like in printing press) suppliers can supply 95%. You should be able to get a gallon for almost nothing.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
eagerlee
Posted: Thu Mar 06, 2008 1:03 pm Post subject: Another lesson with windows |
I got 99% iso alcohol from Safeway Supermarket pharmacy shelves.
Paul Hahn
