				 Posted: Thu Mar 06, 2008 3:41 am    Post subject: axle fitting |
				Thanks Larry. I think I do have the thin ones. I also have some bent gear legs that came with the plane-3?- that maybe could be straightened. They are aluminum. Right now, the plane has one bent leg. The other side has a much stiffer leg- the taper starts further down. I have new legs of the lighter type that will be installed. I asked TNK about putting steel legs on, and they advised me to stay original because a hard landing could transmit the shock up to the main frame- maybe causing very expensive problems. Very good advice from TNK, as I am very inexperienced. Like 40 years out of practice. When in doubt, go with the factory advice. Yes, they do want to sell parts- but not unless they have to. I have to check the "A" frame for cracks while I'm in there. There is also a skid plate on the nose, so I think one of the former users was in the habit of rough landings.
                                               Bill Sullivan
                                               old FS
                                              l
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ElleryWeld(at)aol.com Guest
				 Posted: Thu Mar 06, 2008 3:53 am    Post subject: axle fitting |
				My Old Firestar is going to be listed on Barnstormers  today as the guy that has it in MN has a problem with motion sickness and has to  give up his flying
  You can get a good deal on it with trailer and  skis
                                  Ellery in Maine
   In a message dated 3/6/2008 6:41:57 A.M. Eastern Standard Time,  williamtsullivan(at)att.net writes:
   	  | Quote: | 	 		       Thanks Larry. I think I do have the thin ones. I also have some    bent gear legs that came with the plane-3?- that maybe could be straightened.    They are aluminum. Right now, the plane has one bent leg. The other side has a    much stiffer leg- the taper starts further down. I have new legs of the    lighter type that will be installed. I asked TNK about putting steel legs on,    and they advised me to stay original because a hard landing could transmit the    shock up to the main frame- maybe causing very expensive problems. Very good    advice from TNK, as I am very inexperienced. Like 40 years out of practice.    When in doubt, go with the factory advice. Yes, they do want to sell parts-    but not unless they have to. I have to check the "A" frame for cracks while    I'm in there. There is also a skid plate on the nose, so I think one of the    former users was in the habit of rough landings.
                                                   Bill Sullivan
                                                   old FS
                                                 l
 ="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
 .matronics.com/">http://forums.matronics.com
 ://www.matronics.com/contribution">http://www.matronics.com/contribution
 It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
