naumuk(at)alltel.net Guest
Posted: Sat Mar 08, 2008 1:27 pm Post subject: Pump+Switch |
All-
Anyone have part numbers and source for wing tank fuel pump and selector switch? I would prefer HD/HDS part specifications, but suppose XL would work.
Thanks.
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
gboothe5(at)comcast.net Guest
Posted: Sat Mar 08, 2008 1:56 pm Post subject: Pump+Switch |
Bill,
The part # for the ONE facet fuel pump that I received is 40105. I received no switches, probably because I only got one pump (no need to switch). If I needed to turn off the pump I could just yank out the wire….
Gary Boothe
Cool, CA
601 HDSTD
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Saturday, March 08, 2008 1:25 PM
To: zenith list
Subject: Pump+Switch
All-
Thanks.
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
Posted: Sat Mar 08, 2008 2:23 pm Post subject: Pump+Switch |
Gary-
At least you got one. I have an e-mail in to Zenith.
Bill
jlatimer1(at)cox.net Guest
Posted: Sat Mar 08, 2008 4:54 pm Post subject: Pump+Switch |
I'm building an HDS with wing locker tanks. Like Gary, I received only one fuel pump (Facet 40105) with my kit and no selector valve. I purchase 2 additional 40105's and have installed them in the center wing section close to the fuel tank outlets. I then ran hoses into the fuselage and tee'd the tanks together. From there I ran a line to the header tank. I know most of you don't like header tanks, but this is my plan.
I have two switches, one for each pump. My plan is to use the locker tanks to fill the header tank when needed. I turn on the right tank first and then the left tank to fill the header. This way I can help to balance tha plane right to left with fuel weight. The Facet's have a check valve on the out, so I should be able to run one and the check valve on the other one whould keep from only pumpling fuel from each locker tank.
Jerry
Chandler AZ
601 HDS 912
installing motor now
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gary Boothe
Sent: Saturday, March 08, 2008 2:54 PM
Subject: RE: Zenith-List: Pump+Switch
Bill,
Gary Boothe
Cool, CA
601 HDSTD
To: zenith list
Subject: Zenith-List: Pump+Switch
All-
Thanks.
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
0 [quote][b]
grs-pms(at)comcast.net Guest
Posted: Sat Mar 08, 2008 5:20 pm Post subject: Pump+Switch |
My (unfinished) HD is plumbed the same way. I have a gauge for each wing tank and indicator lights for each wing tank pump.
George Swinford
cookwithgas
Posted: Sat Mar 08, 2008 6:10 pm Post subject: Re: Pump+Switch |
Bill:
I did mine a little different than most and it works very well. I use two pumps - one near each tank and two gauges with little green lights below them to indicate which pump is pumping. I use an on-on switch so one pump must be on all the time. I use a FAcet Purolator Posi-Flo pump which is an upgrade from what ZAC supplies I believe. Here's some info.
http://www.facet-purolator.com/mcl/media/technology/hd_pdfs/Posi-Flo_sheet.pdf
You can see my sideways switch and two gauges and little green lights just above the red BRS handle in this picture:
http://www.cooknwithgas.com/6_5_06_Panel.JPG
The pumps are pretty quiet when they are pumping fuel but when they run out, they get really loud.
Scott Laughlin
60XL Finished and Flying
I did an hour of flying today in really windy conditions
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Mar 08, 2008 10:20 pm Post subject: Pump+Switch |
Hey Scott
I liked your toggle switch guard on the pump switch. Nice touch. I was
considering the same thing for my pump switch. Are those the ones that
Perihelion Design sells? Do you think they are worthwhile? The pump switch
seems like an appropriate place to use them.
Terry
At 06:10 PM 3/8/2008 -0800, you wrote:
| Quote: | Bill:
Scott Laughlin
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Sun Mar 09, 2008 5:50 am Post subject: Pump+Switch |
Jerry-
You lost me when you said you purchased 2 additional pumps. Does that mean that you're using 3 pumps? I too am using the small 8 gal header tank and that puzzles me. There's an outlet at the bottom but no inlet fittings, and a small tube at the top I assume is a vent. Did you have to mount your own inlet fittings?
Also, there's a huge difference in available selector valves, the generic ACS for about $40 or the name brand for over $200. There's a disclaimer saying the generic valve isn't FAA approved, but I find it hard to believe ACS would sell anything unsafe. Which are you using?
Bill
cookwithgas
Posted: Sun Mar 09, 2008 6:22 am Post subject: Re: Pump+Switch |
Terry:
Yes, they are the space shuttle switch guards from Periheliondesign.com and are really nice. Light weight and well made.
Scott Laughlin
601XL Finished & Flying
Posted: Sun Mar 09, 2008 7:28 am Post subject: Pump+Switch |
Sorry about the confusion.
I am using 3 pumps. One pump that goes from the header tank to the engine. And two pumps in the center wing section. These 2 pumps will be used as transfer pumps. They will be used to transfer fuel from the locker to the header tank. I also have an 8 gallon header tank. My header tank has 2 welded fittings at the top, and two on the bottom. I will use one of the top fittings as an inlet for the transferred fuel. The other one is suppose to be used for the old style Zenith fuel sight glass fuel gauge. The center bottom fitting will go through a shutoff valve, then gasolator, then electric fuel pump, and then to the Rotax mechanical fuel pump. The second bottom fitting is suppose to be used as the second fitting required to make the sight glass fuel gauge. In other words you hook some transparent tubing between one of the top fittings and the bottom side fitting and this becomes the fuel gauge.
Hope this helps
Jerry
Sent: Sunday, March 09, 2008 6:47 AM
Subject: Re: Zenith-List: Pump+Switch
Jerry-
Bill
