Mike Whisky
Posted: Sun Mar 09, 2008 10:40 am Post subject: Where did you mount the Lightspeed Plasma III box |
Hi,
soon I'll come to the point where I will mount my Lightspeed Plasma III control box. I saw some pictures where it was mounted inside of the firewall. Where did you mount it?
Best Regards
Michael
_________________ RV-10 builder (flying)
#511 |
coop85(at)cableone.net Guest
Posted: Sun Mar 09, 2008 11:14 am Post subject: Where did you mount the Lightspeed Plasma III box |
Michael,
I mounted mine on the sub panel behind the instrument panel. I had
read somewhere that the heat in the engine compartment might not be a good
thing on the brain box so I wanted it behind the firewall. I could
certainly be off on that thought. Seems to work just fine.
Marcus
40286
carl.froehlich(at)cox.net Guest
Posted: Sun Mar 09, 2008 11:21 am Post subject: Where did you mount the Lightspeed Plasma III box |
I have dual Lightspeed II+ in my 8A. I would not consider mounting the CDI module on the firewall side of the engine if for no reason other than heat. These modules get hot by themselves. You might want to ask Klaus about heat issues with the Plasma III. Here is what his web site says:
The PLASMA CDI module should be mounted in a clean and dry place on the cold side of the firewall. If space limitations require mounting on the engine side of the firewall, a protective metal cover should be used to protect the module from water/engine cleaning materials and heat. In this situation, the module should be oriented such that the connectors are to the sides of the plane. Air must be allowed to flow between the bottom of the module and the mounting surface. On 6-cylinder systems, cooling air should be supplied to the box via the cooling port on the 15-pin connector side of the ignition module. For 6-cyl. systems that do not have a cooling port, contact LSE for this modification. Cooling is not required for 4-cyl. systems.
I would mount the modules in a cool spot and not on the back side of the firewall even if it is insulated. Use standoffs to allow for air to circulate behind the modules. Keep in mind you need to provide a blast tube for cooling. I would assume you could rig up a cooling fan instead if a blast tube was too hard.
BTW - I got a note back from eMag the other day. They are progressing on their 6 cylinder ignition system but I did not get a target date for availability. I am hoping these are on the market as an alternative to Lightspeed when I'm ready for the engine.
Carl Froehlich
RV-8A (400 hrs)
RV-10 (wings)
Tim Olson
Posted: Sun Mar 09, 2008 1:09 pm Post subject: Where did you mount the Lightspeed Plasma III box |
While certainly not a proof of reliability, I had 320 hours of
perfect operation with my Plasma III....with no cooling port on
it. I recently took advantage of the winter downtime and sent
it in for the cooling port and all additional updates that they
could do. I haven't added blast cooling air yet, but plan to as
soon as I care to lay under the panel again.
What I did was mount mine on the firewall, cabin side, upper
area behind the pilots side of the firewall....way up
on that top curved area that is largely wasted space.
I mounted it and had stand-off rubber feet under it to ensure
that it had an air gap between it and the firewall.
Originally I mounted it with just screws and nuts, but
getting to it was a bit of a pain because I had to have
the wife turn the screws while I held the wrench. So, when
it was out for the mods, I put nutplates on the box so that
now I can just put it in place and screw it in. It's
definitely not in the most accessible area for removal,
but then again, it's something that you will rarely (hopefully)
have to remove. Had I bought mine after the cooling port
became standard, I would have not had reason to remove it.
So it's kind of nice to use some of that wasted space.
Plus, being high on the firewall leaves for nice short
and easy to route RG-400 lines for the coil wires.
Not the best way, perhaps, but it's served me very well.
Having had so many hours without cooling ports, the heat
issue thing isn't a major fear for me...but I do think
it's best to go with any manufacturer recommendations
for sure.
Carl Froehlich wrote:
Quote: | I have dual Lightspeed II+ in my 8A. I would not consider mounting the
says:
Carl Froehlich
RV-8A (400 hrs)
RV-10 (wings)
Mike Whisky
Posted: Mon Mar 17, 2008 3:31 am Post subject: Re: Where did you mount the Lightspeed Plasma III box |
Thanks you guys for your help.
Michael
#511 |
