dcsfoto
Posted: Mon Mar 10, 2008 5:00 pm Post subject: Model 7 test flight help |
I am flight testing my model 7, I have an older kit as the elevator
has trim tabs.
I have been adjusting the horz leading edge down to get more nose up trim
but am almost out of adjustment. full aft (nose up ) trim gives me a hands off stick approach speed of 75 mph.
Like to know what others are doing.
David Kitfox 3 and 7
rdmac(at)swbell.net Guest
Posted: Mon Mar 10, 2008 6:25 pm Post subject: Model 7 test flight help |
David,
75 sounds a bit too fast, but then I do not have a neutral stick.
With full flaps and engine at idle, I have between 55 and 60 mph approach.
With full nose up trim and full flaps and engine at idle, you shouldn't be
landing any faster than 65mph max. Hold a little back pressure and slow that
bird down to 60 or less. You're still well above the stall speed.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
Lynn Matteson
Posted: Tue Mar 11, 2008 5:22 am Post subject: Model 7 test flight help |
During the 40 hr test period my test pilot reported the same thing.
We removed the front bolt and lowered the hort. stab to where it
touched the fuselage, then drilled a new hole at that location.
Lynn Matteson
flying w/475+ hrs
On Mar 10, 2008, at 9:00 PM, dcsfoto wrote:
has trim tabs.
up trim
http://forums.matronics.com/viewtopic.php?p=168919#168919
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
