EAFerguson(at)aol.com Guest
Posted: Tue Mar 11, 2008 4:00 am Post subject: Engine changes |
In a message dated 3/11/2008 1:00:07 A.M. Eastern Daylight Time, N1BZRich(at)aol.com writes:
Quote: | To add to what Nick said, the 2007 Demo also had the hydraulic lifter engine that was down slightly on horse power and rpm. The engine in the 2008 Demo will have the hydraulic lifter with the new cam profile that should return the lost power and rpm. It should be a speed demon.
Buz
New cam profile??? Is there a change in rated HP?
Earl
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
info(at)flylightning.net Guest
Posted: Tue Mar 11, 2008 5:18 am Post subject: Engine changes |
Earl,
There is no change in rated horsepower. The last of the solid lifter motors were rated (at)120hp but made a bit more than that , the first hydraulic motors made the 120hp rated but not that little extra that the last solid lifters did, so there is a new cam profile that should have that back,,,,the 3300 still makes and always has made the rated 120hp…..
nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of EAFerguson(at)aol.com
Sent: Tuesday, March 11, 2008 6:57 AM
To: lightning-list(at)matronics.com
Subject: Re:Engine changes
Buz
Earl
Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
sales(at)billandruth.net Guest
Posted: Tue Mar 11, 2008 8:52 am Post subject: Engine changes |
Hi Nick and List,
How do you determine if your engine has the latest cam installed?
What is recommended for the cockpit side of the firewall as a firewall blanket for sound deadening and a thermal barrier? Is it worth pursuing?
Bill Applegate, Kit #49, Tucson, AZ.............New canopy frame trimmed to fit cockpit sills, now working up the courage to trim the canopy!
flylightning wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
Earl,
nick
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com)] On Behalf Of EAFerguson(at)aol.com (EAFerguson(at)aol.com)
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
In a message dated 3/11/2008 1:00:07 A.M. Eastern Daylight Time, N1BZRich(at)aol.com (N1BZRich(at)aol.com) writes:
Buz
Earl
1 [b]
mark(at)flylightning.net Guest
Posted: Tue Mar 11, 2008 11:31 am Post subject: Engine changes |
Bill,
Our upholstery shop uses 1/2" automotive dense fiber padding glued to the firewall. Then they glue their interior carpet to that padding.
As for the cam, starting with a certain serial number all new engines have the new cam profile. I don't know what the exact serial number is.
Congratulations on your canopy frame. Actually, trimming the canopy is the easiest part. Place the canopy on the frame and draw a line around the canopy in the middle of the "C" channel. Trim on the line with a Dremel tool or some sort of cut off wheel and then clean up the edge so you don't cut your fingers. You don't have to worry about the fit against the fuselage, the canopy skins will take care of that.
Have a great day!
Mark
[quote] --
Posted: Tue Mar 11, 2008 8:42 pm Post subject: Engine changes |
Hi Mark,
Thanks for the speedy reply. Who would know what the affected engine serial numbers forward are for the updated cam? I'm looking for a contact person, Email or phone number.
Regarding trimming the canopy. I did not communicate very well what my concern was regarding the cutting of the canopy. I was afraid of putting a crack in the acrylic! I had figured out where it needed to be cut and had marked it in the middle of the "C" channel on the canopy frame with masking tape so that it would be visible and less likely to crack.
Great news!!! I was able to trim the canopy to size in just about an hour today. I used a spiral cutout tool that I picked up at Harbor Freight. It cost $19.95 and here is the URL for the item on their web site: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42831
I used the 1/8 inch spiral bit with this tool and it works great and leaves a smooth finish cut that does not leave any sharp edges. It is very easy to use and is much like the Roto Zip tool that sells for a great deal more.
Tomorrow I plan to make holding fixtures to align the canopy frame so I can install the canopy attachment hardware and at the same time set the canopy reveal so that when the finish skins are applied the fuselage and canopy will flow smoothly together. I plan to take some pictures and if anyone is interested I will post them.
I have noticed that there is a bow in each of my flaps of anywhere from .125 to .25 inches. Additionally the trailing edges of these flaps are wavy rather than straight. Is this typical? I assume that this will not be a factor in flight. Is that indeed the case? I suspect it will affect the gap between the wing trailing edge skin and the flap.
This is a non-builder assist build which was started in October of 2007. For those that have not finished their Lightnings as yet I think it would be great to know, by Kit Number and builder name, when the build was started. I believe that this would be very informative for all builders especially for those not using builder assistance.
Bill Applegate, Kit #49, Tucson, AZ working on the canopy and installing the flaps.
Have a great day!
Mark
[quote] --
Posted: Wed Mar 12, 2008 10:43 am Post subject: Engine changes |
Bill,
Our interior shop installs some form of material for sound deading but it is not a thermal barrier. Also as for the horsepower difference, the 3300 still makes and always has the rated 120hp as advertised by jabiru. With the hydraulic cam there was a slight drop but not below the rated 120hp…as for the engine with the different CAM profile those engines were delivered the first of the year, I do know the specific serial #
Nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Sales Email Account
Sent: Tuesday, March 11, 2008 11:51 AM
Subject: Re: Lightning-List: Re:Engine changes
Hi Nick and List,
flylightning wrote:
Earl,
nick
Buz
Earl
Quote: | http://www.matronics.com/contribution | 0123456789 Quote: | http://www.matronics.com/contribution | 0 Quote: | http://www.matronics.com/contribution | 1 Quote: | http://www.matronics.com/contribution | 2 Quote: | http://www.matronics.com/contribution | 3 Quote: | http://www.matronics.com/contribution | 4 Quote: | http://www.matronics.com/contribution | 5 Quote: | http://www.matronics.com/contribution | 6
Colin K.
Posted: Wed Mar 12, 2008 5:16 pm Post subject: Engine changes |
Bill,
Thanks for sharing your experience with the canopy. I have been using a Rotozip especially when cutting small radius curves - it's been easier than using a cutting wheel. However, it's difficult to cut a straight line or a long shallow curve with a spiral bit, like I thought would have been needed on the canopy. Still, I guess this cut does not have to be pretty as it is eventually covered by the canopy frame on the inside and the canopy skins on the outside. I have not come that far yet.
What do you mean by "set the canopy reveal" ?
And yes, I would be interested in your pictures.
I started my kit, at home, mid-January 2008. I am putting as much detail in my Kitlog as I think would be helpful to other builders, but mostly they will be learning from my mistakes!
Colin K.
OK
Lightning # 52 under construction.
http://www.mykitlog.com/cojaken
_________________ Colin K.
OK |
Posted: Wed Mar 12, 2008 9:46 pm Post subject: Engine changes |
Hi Colin,
Regarding setting the canopy reveal, the "skins" that cover the canopy (as attached to the upper canopy flange) and bottom canopy flange are trimmed so that it rests just above the fuselage canopy sills. According to advice I received from Arion's tech support folks the spacing here should be no bigger than the thickness of two business cards stacked together. The reveal I am talking about is the space between the bottom canopy frame flange and the fuselage canopy sills without the skins attached. I am attempting to establish this exact spacing (reveal) required so that when the skins are installed the transition from the fuselage and the canopy will be dead even with each other. Hopefully, my pictures will help in explaining what I'm trying to communicate better than my word description.
Canopy trimming only needs to be approximate and not "pretty." The "skins" will hide all of that trim job for you, so don't even try to make it neat. It's a waste of your valuable time.
Thanks for providing the info I requested. Hope to have pictures by the weekend............Bill.
Colin J. Kennedy wrote: [quote] Message Bill,
Colin K.
OK
[quote] --
Clive J
Posted: Thu Mar 13, 2008 5:26 am Post subject: Engine changes |
This from the UK agent todday:
The Revised cam profile came in October 2007 at 33A1684
Regards, Kevin
Disappointing as I have # 1460 with hydraulic tappets.
I've enquired about the new cam. Given Jabiru's normal approach I don't
expect any sort of exchange deal but you never know......
Maybe Pete can comment on what he knows/offers?
Regards, Clive
N1BZRich(at)aol.com Guest
Posted: Thu Mar 13, 2008 8:37 am Post subject: Engine changes |
In a message dated 3/13/2008 9:28:00 A.M. Eastern Daylight Time, clive.james(at)uk.bp.com writes:
Quote: | The Revised cam profile came in October 2007 at 33A1684
To all on the List,
Thanks to Clive to getting this serial number info out. However, if you happen to have one of these engines do not be concerned. You still have a great engine that produces an honest 120 HP (or even more when broken in) and you don't have to worry about adjusting the valves on a regular basis as many of us do.
I think it was me that initially mentioned this power/rpm issue on the list some time ago after flying the original Lightning Demo on a flight evaluation. After my flight I casually mentioned to Nick that the engine seems to be down slightly on top end rpm (and thus power) when at WOT. He confirmed that he had also noticed this and that the factory was working on a new cam profile to get the last few rpm back to where it was before. The only reason I noticed this is that I have flown enough Lightning airframe, engine, and propeller combinations at WOT while testing different props that I suspected something that Nick confirmed. Now really, how often will you be running your engine at WOT (wide open throttle) so that these last few rpm will be important? I am willing to bet that unless you have done lots of prop testing on Lightnings that you would never have noticed this. It just isn't that big a deal for the way you will be normally operating your airplane. All of the prop testing that Nick and I have done is to come up with the optimum prop set up for various airframe configurations - meaning a Lightning at various weights or the Light Sport compliant model.
Bottom line - equip your Lightning the way you want it, but when deciding how you really want to equip it, strive to keep it light and then build it "straight". As to building it straight, the factory now uses a wing incidence setting tool to insure both wings are the same when they go on the first time. This has been discussed on the list before with a photo of the incidence tool that Nick developed. If you just align the inboard wing profile with the fuselage profile, you may or may not "get it perfect". Only a small amount can make a difference. Once you start flying and you find that you have a "hands off" roll while the stick is centered and the ailerons are neutral, the only way to fix the problem of a "heavy wing" is to lower the flap slightly on the "heavy" side. Of course that adds some drag because you are increasing lift on that side, but it is what you need to do because the other wing has a slightly higher incidence and thus slightly more lift.
Now more lift on both sides means slightly more total drag, and drag is the enemy when you want to cruise fast. Hope this is not confusing.
These two things (keeping it light and building it straight) will have more to do with higher cruise speed than the last few rpm that your can turn when WOT with some specific propeller. So don't sweat it if you have one of these interim engines. And no, Jabiru did not ask me to say this. I just don't want to see folks stressing about something that really won't make much difference on the way they will operate their aircraft.
Blue Skies,
Buz
Clive J
Posted: Fri Mar 14, 2008 1:08 am Post subject: Engine changes |
This is good steer from Buz as usual, just a blow to find out when you
think you have the latest engine that you don't.
The UK dealer has made the same comments as Buz regards the power,
difference small and still over 120 hp, not worth the hassle of a new
cam that will cost quite a few shillings. Cruise speed is king for me
and as long as I get a good range at a good turn of speed then that will
do. My efforts once the plane gets in the air (if ever) will be on
making it as slippery as Buz's.
The paperwork is now with the IVW (Dutch FAA) and I await feedback on
what else they need. Then CAA exemption, PFA assessement blah blah blah
Regards, Clive
The only UK Esqual...and was that a mistake...
selwyn
Posted: Fri Mar 14, 2008 3:46 am Post subject: Re: Engine changes |
Comments ex. Jabiru about a week ago. The power increase with the new cam on the four cylinder is something less than 2 HP. Testing on the 6 cylinder is not complete but, by extrapolation, likely to be 2 to 3 HP.
My take on this is that this whole thing is pretty much a non event, for practical purposes there will be no effect. If in doubt, add 50 revs in the cruise and you will be at least as fast as the bloke with the new cam. Alternatively, clean the bugs off it and give it a polish and ditto.
Cheers, Selwyn
