cpops(at)verizon.net Guest
Posted: Mon Mar 10, 2008 6:38 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Noel wrote…
Quote: | Just a question though what happens if the tail spring breaks while you are
towing the plane??? Do you have a back up for that?
That is a very good question, Noel. I have actually had the tailwheel spring break while landing on a sod field, which wasn’t pretty, as the springs went right through the rudder. But, that pales by comparison with what would happen if the spring broke while trailering at highway speed! I hadn’t considered that possibility! Any suggestions??
Pops
Checked by AVG.
3/10/2008 11:07 AM
thesupe(at)hotmail.com Guest
Posted: Mon Mar 10, 2008 8:18 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
I posted this picture last week, but I'll post it again and point something out on it that maybe wasn't noticed.
On the trailer that I got with my B model Avid, if you look just ahead of the tailwheel a bit you see
a steel strap about 3' wide. There are actually two of them, one on each side of the channel that
the tailwheel rolls on. The straps are hinged at the bottom, when you flip them up and lift the plane
about 1', you can run a bolt through the fusaloge and both straps. I think the Kitfoxes had the same
setup, where you could pull the plane backwards with a hitch that hooked onto the sides near the
rear of the fusaloge. There are two tubes welded into the fusaloge that go crossways through it
and the hitch bolted to them. The straps on my trailer hook to the rear hitch attach point. It takes
the weight off the tailwheel and holds the tail in place at the same time. It works for me, although I didn't
build it or take credit for the idea. Jim Chuk Mn
Quote: | Date: Mon, 10 Mar 2008 10:35:35 -0400
Subject: Re: Re: Trailering my KitfoxRe: Trailering my Kitfox
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal{margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';}.ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink{color:blue;text-decoration:underline;}.ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed{color:purple;text-decoration:underline;}.ExternalClass EC_span.EmailStyle17{font-family:Arial;color:windowtext;font-weight:normal;font-style:normal;text-decoration:none none;}(at)page Section1{size:8.5in 11.0in;}.ExternalClass EC_div.Section1{page:Section1;}
Noel wrote…
Pops
Checked by AVG.
3/10/2008 11:07 AM
| Need to know the score, the latest news, or you need your Hotmail®-get your "fix". Check it out.
Description: |
Filesize: |
165.71 KB |
Viewed: |
589 Time(s) |
Float Flyr
Posted: Mon Mar 10, 2008 9:58 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Support the plane under the attach point for the tail wheel while on the trailer. You can also put a lanyard over the fuse. I saw in one post today where someone actually used the rods for the tow bar to support his tail.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Chuck Popenoe
Sent: Monday, March 10, 2008 12:06 PM
Noel wrote…
Pops
Checked by AVG.
3/10/2008 11:07 AM Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
n85ae
Posted: Mon Mar 10, 2008 11:30 am Post subject: Re: Trailering my KitfoxRe: Trailering my Kitfox |
Actually the best thing to add to a trailer, is a remote controlled tail
turret with twin .50 caliber machine guns for tailgaiting "gee, I never
saw an airplane on the road before" gawkers.
Jeff
shinco(at)bright.net Guest
Posted: Mon Mar 10, 2008 12:09 pm Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Jim_and_Lucy Chuk wrote:
Quote: | I posted this picture last week, but I'll post it again and point
my Kitfox
Noel wrote…
while you are
suggestions??
Pops
Checked by AVG.
3/10/2008 11:07 AM
*http://www.matronics.com/Navigator?Kitfox-L--> http://foruef="http://www.matronics.com/contribution" target=_blank>http://www.mat==================== <http://forums.matronics.com/>*
your "fix". <http://forums.matronics.com/>Check it out.
<http://www.msnmobilefix.com/Default.aspx>
Checked by AVG.
This sounds like a good idea to do..Steve Shinabery N554KF KF2
patreilly43(at)hotmail.co Guest
Posted: Mon Mar 10, 2008 1:24 pm Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Jim & Lucy, Thanks for the towbar discription on how to hook it to the plane. I saw the pictures of the bars, but didn't see how you could attach it to the plane. Now I understand and will build one for my plane. The airport is 12 miles away. Thanks again.
Do Not Archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
--> Kitfox-List message posted by: steve shinabery <shinco(at)bright.net>
> From: cpops(at)verizon.net
> my Kitfox
> To: kitfox-list(at)matronics.com
> Noel wrote…
> while you are
> suggestions??
> Pops
> Checked by AVG.
> 3/10/2008 11:07 AM
> Checked by AVG.
flier
Posted: Mon Mar 10, 2008 1:28 pm Post subject: Re: Trailering my KitfoxRe: Trailering my Kitfox |
I have a pair of arms that pivot up with dual gas struts that supports the tail of my IV when on the road. There's a pic at
http://www.foxflier.com/kitfox/Trailer/HPIM0253.jpg
Ted
962TC
Posted: Mon Mar 10, 2008 3:40 pm Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Ted, Thanks for the pics. That is an absolutely beautiful trailering suspension. Do you know what struts you used?
Do Not Archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Tue Mar 11, 2008 6:16 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Ted,
Would also like the details on the Gas Strut tail support.
Vic Baker
S7 912S Warp 95%
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
flier
Posted: Thu Mar 13, 2008 5:04 am Post subject: Re: Trailering my KitfoxRe: Trailering my Kitfox |
Thanks.
I simply went to the auto parts store and got the heaviest pair of gas struts I could find. The struts need to have fittings on the top and bottom that will take bolts or can be modified to be bolted.
The uprights are 4" channel. I cut slots in the top of the uprights corresponding to the stroke of the struts. Took a washer and a 1" or so long chromoly tube bushing (with an ID the same as the OD of the rod that goes through the tow bracket), welded the washer to the bushing then cut a hole in the top of the gas strut fitting that would allow the bushing to slip in. You end up with the bottom of the struts bolted to the uprights and the top able to slide up and down in the slots.
The uprights pivot down horizontal on the trailer. After I load the plane, I pivot the uprights vertical, slid the tow bracket rod through one strut/upright, through the fuselage, then through the other side upright/strut, and secure it with a nut on the end. Works good.
I didn't feel I needed to remove all the weight off the tailspring, but I wanted to take the shock out and have the tail secured just in case something did ever happen to the tailspring.
Those other padded uprights keep the base of the rudder from flexing in the wind...
Ted
N962TC
[quote="patreilly43(at)hotmail.co"]Ted, Thanks for the pics. That is an absolutely beautiful trailering suspension. Do you know what struts you used?
Do Not Archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Posted: Thu Mar 13, 2008 6:06 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Ted, Thanks again for the reply and explaination. It took both, but now I understand exactly what you did. Is that a Maule solid rubber tail wheel? I am replacing the solid aluminum "spring" mount with a 3 leaf spring from Kitfox. I have the solid rubber Maule wheel and am going to replace it with something softer.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Quote: | Subject: Trailering my KitfoxRe: Trailering my Kitfox
Date: Thu, 13 Mar 2008 06:04:58 -0700
--> Kitfox-List message posted by: "flier" <flier(at)sbcglobal.net>
Thanks.
Ted
N962TC
Do Not Archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
> From: flier(at)sbcglobal.net
> Date: Mon, 10 Mar 2008 14:28:01 -0700
> Regards,
> Ted
> 962TC
> http://forums.matronics.com/viewtopic.php?p=168887#168887
> [b]
http://forums.matronics.com/viewtopic.php?p=169540#169540
flier
Posted: Thu Mar 13, 2008 8:10 am Post subject: Re: Trailering my KitfoxRe: Trailering my Kitfox |
No prob Pat. Those photos were taken a couple of yrs ago before I installed the softer homebuilders special tailwheel. I flew the hard Maule for yrs, and it was fine -- just solid -- but I've really liked the homebuilder wheel the last couple of yrs.
Ted
N962TC
patreilly43(at)hotmail.co wrote: | Ted, Thanks again for the reply and explaination. It took both, but?now I understand exactly what you did. Is that a Maule solid?rubber tail wheel? I am replacing the solid aluminum "spring" mount with a 3 leaf spring from Kitfox. I have the solid rubber Maule wheel and am going to replace it with something softer.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Posted: Thu Mar 13, 2008 9:15 am Post subject: Trailering my KitfoxRe: Trailering my Kitfox |
Ted, Thanks. You are the 2nd one to recommend the Homebuilder tail wheel. I guess that is the one I'll use. Price is right and it is reported to be much softer than the Maule.
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Date: Thu, 13 Mar 2008 09:10:49 -0700
Ted
N962TC
> Pat Reilly
> Mod 3 Rebuild
> Rockford, IL
http://forums.matronics.com/viewtopic.php?p=169579#169579
&g==================
