Lynn Matteson
Posted: Wed Mar 12, 2008 4:38 am Post subject: Sprung Tailwheel |
It's soft rubber, Jim. And you might be right about the bearings,
although when armed with the dimensions that I had, the local bearing
distributor could only supply ones with a 5/8" inner diameter. It
seems like others have found bearing that worked without the sleeve.
Just for the record, that bearing distributor that I visited has gone
belly up, but that's not surprising in Michigan.
Lynn Matteson
flying w/475+ hrs
On Mar 12, 2008, at 12:06 AM, Jim_and_Lucy Chuk wrote:
| Quote: | Lynn, Is that tailwheel soft rubber or actually a pneumatic
wheel? As far as the bearings go, I would bet that it wouldn't be
to hard to find bearings that fit the wheel and have a 1/2" center
so it would fit the Maule axle. Thanks, Jim Chuk Avids MN
> From: lynnmatt(at)jps.net
> Subject: Re: Sprung Tailwheel
> Date: Tue, 11 Mar 2008 22:54:21 -0400
> To: kitfox-list(at)matronics.com
> That's the one. Yes, get the longlife bearings from them or from a
> local bearing dealer, as the one's shipped with the wheel are poor
> quality...A word of warning....the description says "bearings" but
> that means one bearing, and you will need to order two, unless
> they've changed their tune since I ordered mine. You'll have to make
> a sleeve for the bearings to fit the Maule axle. I used a length of
> 4130 tubing, Spruce part number 03-03900, which will have to be
> polished a few thousandths (mine did anyway) to fit the bearings.
I'm
> pretty sure that the bore of this tubing fit the axle just right.
> You'll have to forgive Spruce for their lack of full explanations of
> each of their products...they try hard (I'm being kind here...), but
> they miss the mark a lot. : )
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> flying w/475+ hrs
> On Mar 11, 2008, at 6:35 PM, patrick reilly wrote:
> > Lynn, I see p/n 06-03600 Homebuilders 6" replacement wheel $29.90
> > page 247 Aircraft spruce. Is that the one? Is it for a 1/2" axle.
> > It lists "longlife" bearings for $4.65 and states that they are
> > superior to the standard bearings. It doesn't state solid or
> > pneumatic, which is odd?
> > Pat Reilly
> > Mod 3 Rebuild
> > Rockford,IL
> > > Date: Tue, 11 Mar 2008 12:57:20 -0400
<lynnmatt(at)jps.net>
> > > I had already changed over from the solid Maule tailwheel to
the 6"
> > > "Homebuilders Special Tailwheel" as Spruce calls them. It is
a much
> > > softer tire than the Maule, weighs less, and has less contact
area
> > > with the ground than the Maule. The bearings that come with the
> > > Spruce wheel are terrible though.
> > > By the way, I like the looks of your pneumatic job, Jim.
> > > Lynn Matteson
> > > flying w/475+ hrs
> > > On Mar 11, 2008, at 10:20 AM, Jim_and_Lucy Chuk wrote:
> > > > I'm just wondering if those that have had the tailwheel spring
> > > > break were all running the solid rubber Maule tailwheel. I had
> > > > that wheel on my Avid MK IV, and you can sure feel every
little
> > > > bump through the fusaloge. I would guess that those sharp
jolts
> > > > fatigue the spring. Last summer I replaced the wheel with a
cheep
> > > > 6' pneumatic castor wheel and it was much smoother, the tire
> > really
> > > > soaks up lots of the sharp jolts. I got some better sealed
> > > > bearings and put them in the wheel. It would have been nice if
> > > > Maule made a replacement 6' pneumatic tire but they don't.
This
> > > > worked for me. Jim======
> > http://www.matronics.com/Navigator?Kitfox-List_-
> > =================================== _-
> > forums.matronics.com_-
> > contribution_-
&g=======================
Helping your favorite cause is as easysenger/IM/Home/?
source=text_hotmail_join' target='_new'>Learn more._-
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Wed Mar 12, 2008 6:41 am Post subject: Sprung Tailwheel |
Lynn, I ordered the 3 leaf spring from John Mcbean yesterday. I have the Maule 6" solid tail wheel. If the Aircraft Spruce is also solid rubber, I might as well stick with the wheel I have. I thought a pnuematic tire might be a little lighter and give me a little more cushion.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
[quote] From: thesupe(at)hotmail.com
Subject: RE: Sprung Tailwheel
Date: Wed, 12 Mar 2008 04:06:06 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Lynn, Is that tailwheel soft rubber or actually a pneumatic wheel? As far as the bearings go, I would bet that it wouldn't be to hard to find bearings that fit the wheel and have a 1/2" center so it would fit the Maule axle. Thanks, Jim Chuk Avids MN
| Quote: | From: lynnmatt(at)jps.net
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
polished a few thousandths (mine did anyway) to fit the bearings. I'm
Lynn Matteson
flying w/475+ hrs
> Pat Reilly
> Mod 3 Rebuild
> Rockford,IL
> > I had already changed over from the solid Maule tailwheel to the 6"
> > "Homebuilders Special Tailwheel" as Spruce calls them. It is a much
> > softer tire than the Maule, weighs less, and has less contact area
> > Lynn Matteson
> > flying w/475+ hrs
> > > that wheel on my Avid MK IV, and you can sure feel every little
> > > bump through the fusaloge. I would guess that those sharp jolts
> > > fatigue the spring. Last summer I replaced the wheel with a cheep
> really
> > > Maule made a replacement 6' pneumatic tire but they don't. This
> contribution_-
Helping your favorite cause is as easysenger/IM/Home/?source=text_hotmail_join' target='_new'>Learn more. | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
| [b]
Michel
Posted: Wed Mar 12, 2008 8:25 am Post subject: Sprung Tailwheel |
| Quote: | From: patrick reilly [patreilly43(at)hotmail.com]
I had the Maule and changed to the Aircraft Spruce Homebuilders and it's a much softer ride on my model 3, Patrick.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
buddcr(at)yahoo.com Guest
Posted: Wed Mar 12, 2008 9:38 am Post subject: Sprung Tailwheel |
Hi all,
I know a lot of guys out there have broken there tailwheel springs with the one and two leaf steel springs that came with some of the older kits. My question is. Has there been known failures of the Grove aluminum tailwheel spring? I know Grove doesn't make them anymore. However, this doesn't mean they had failure problems. They just might not have sold as well as the steel and therefore discontinued them? There are a bunch of the aluminum springs out there including the one I have on my aircraft. I agree the aluminum spring doesn't flex/give as much as the steel ones do. Therefore giving you a rougher ride. However, I can live with this if that is the only problem. If there have been known failures of the aluminum springs, then I'm going to replace mine out for a 3 leaf steel setup.
Chris Budd
Kitfox IV Speedster w/VW 2180
Flying 220+ hrs
Be a better friend, newshound, and [quote][b]
Lynn Matteson
Posted: Wed Mar 12, 2008 10:16 am Post subject: Sprung Tailwheel |
The Spruce tailwheel is pretty soft, and gives a much more gentle
ride, I and others have found. Yes it is solid, but it is softer.
I've thought about taking the helper spring out of my 3-leaf pack,
thinking it may soften the ride, and sent an email to John McBean
questioning that move, but didn't get an answer.
I don't think that removing the helper spring would hurt the safety
of the 3-leaf'er, but I could be wrong. If it was taken out, the two
main leafs would still give the redundancy that is important, I believe.
Lynn Matteson
flying w/480+ hrs
On Mar 12, 2008, at 10:38 AM, patrick reilly wrote:
| Quote: | Lynn, I ordered the 3 leaf spring from John Mcbean yesterday. I
Pat Reilly
Mod 3 Rebuild
Rockford,IL
N369LM |
Fox5flyer Guest
Posted: Wed Mar 12, 2008 10:23 am Post subject: Sprung Tailwheel |
Chris, I've been on this list since long before Grove started producing the spring. I can only recall one failure here. There was much discussion why it failed and as I recall, the owner felt that it was due to the way it was mounted. Others have since fabricated saddle type mounts so that the spring can't move around. Personally, I feel that he just happened to get a bad one. Then again, you never know how people are going to treat their airplanes, some are very rough on them and others are not.
With the Grove, I know of no trends that tend to make me believe that the spring itself is at fault. One common complaint though was that it is very stiff, and better suited for the heavier models. Also, a pneumatic tire, as others have stated, helps whatever spring you are using.
I don't know why Grove stopped producing them. Probably was from lack of sales.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Posted: Wed Mar 12, 2008 11:50 am Post subject: Sprung Tailwheel |
Mike, Thanks for the advice. Do not archieve.
Pat Reilly
| Quote: | Date: Wed, 12 Mar 2008 17:23:18 +0100
Cheers,
Michel Verheughe
Norway
<pre><b><font size=2 color="#000000" face="courier new,courier">> _-========================.com/contribution">http://www.matronics.com/contribution</a>
&g============
</b></font></pre></body></html>
clint_bazzill(at)hotmail. Guest
Posted: Wed Mar 12, 2008 11:58 am Post subject: Sprung Tailwheel |
What breakage reports. Have not heard of one using the aluminum spring. Clint
[quote] From: Catz631(at)aol.com
Date: Wed, 12 Mar 2008 08:14:55 -0400
I too had the aluminum tailspring but found it too rough for my grass runway (and all the breakage reports) so I sold it on EBAY and installed the 3 leaf spring ,removed the Maule tailwheel, and installed a Matco tailwheel.The weight difference for the combination was less than 1/2 pound. I now have a flexable tailwheel that rides much better on grass and pavement!
Dick Maddux
Fox 4-1200
Pensacola,Fl
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
| [b]
Catz631(at)aol.com Guest
Posted: Thu Mar 13, 2008 4:03 am Post subject: Sprung Tailwheel |
Check out Sportflight you will see a picture of a broken alum spring there.
Dick Maddux
Fox 4-1200
Fox5flyer Guest
Lynn Matteson
Posted: Thu Mar 13, 2008 6:06 am Post subject: Sprung Tailwheel |
My tailwheel spring...the original steel 2-leaf...broke right where
the helper/booster leaf contacted the ONE main leaf. I'm thinking
that maybe the radius of the end of that helper/booster leaf might be
made a bit larger to spread the contact area of that leaf.
I know this has nothing to do with the alum spring, other than the
picture clearly shows the break occurs at the last point of contact
with something that doesn't give.
Lynn Matteson
flying w/480+ hrs
On Mar 13, 2008, at 8:25 AM, fox5flyer wrote:
[quote] That's the one I was talking about. Thanks for hunting it down.
Deke
http://www.sportflight.com/cgi-bin/uploader.pl?
action=view&epoch=1061820002
N369LM |
l.morris(at)tx.rr.com Guest
Posted: Thu Mar 13, 2008 9:06 am Post subject: Sprung Tailwheel |
With all the talk of tail wheel springs and solid tailwheels is everyone trying to say that the springs and tailwheels supplied with the kits will not hold up with average use and that they may be defective and should be relpaced before we fly the airplane for the first time? ---Leon Morris/Classic 4/60%/Flower Mound,TX
Lynn Matteson
flying w/480+ hrs
> Deke
Lynn Matteson
Posted: Thu Mar 13, 2008 1:45 pm Post subject: Sprung Tailwheel |
Well, maybe not the FIRST time....I'm kidding....but the reason I
switched to the softer tailwheel was several people told me that it
gave a softer/smoother ride. I went one step further in
reasoning...it weighs less, and I knew that I was going to be
installing a lighter engine, and that less weight back there would be
a good thing. Lets face it, the Maule tailwheel was first intended
for a heavier plane, so maybe it was overkill for the Kitfox in the
first place. Why did Skystar/Denney use it initially? If I might
surmise, they were trying to offer a kit airplane at a reasonable
cost, and probably ordered steerable tailwheels from the lowest
bidder...I'm guessing, remember....and Maule came in low...no pun
intended. As far as the springs are concerned, mine lasted 487 rough,
69-year-old-rookie, learning-to-fly, turf landings before it let go.
From what I've gathered, that's a lifetime of landings for a lot of
pilots, most of whom land on smooth paved runways. I don't know how
it stacks up against other aircraft. And remember, someone here said
that they probably didn't heat treat the first springs all that well.
Lynn Matteson
flying w/480+ hrs
> Lynn Matteson
> flying w/480+ hrs
>> Deke
N369LM |
Guy Buchanan
Posted: Thu Mar 13, 2008 8:06 pm Post subject: Sprung Tailwheel |
At 02:42 PM 3/13/2008, you wrote:
| Quote: | From what I've gathered, that's a lifetime of landings for a lot of
I don't know Lynn. When you drop it in from six feet like I
do, you probably get some good cushioning out of the turf runway.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
dave
