		fougapilot
  Joined: 20 Jul 2007 Posts: 89 Location: Flat on my back with minimum airspeed
				 Posted: Wed Mar 12, 2008 5:37 am    Post subject: Vertical roll |
				Folks,
 I remember reading in an very very old copy of "Warbird Flyers" (the predecessor to RedAlert) about someone doing a vertical roll with a CJ.
 Does anyone here ever did one and would like to share their tips/techniques?
 I know, I know the Yak can do it...bla, bla, bla. I don't want to fuel the already heated who's better discussion, just looking for tips on how to fly MY airplane better.
 Dan
		f4ffm2(at)adelphia.net Guest
				 Posted: Wed Mar 12, 2008 6:28 am    Post subject: Vertical roll |
				Hi Dan,
       I think that the CJ should do a very nice vertical roll.   The
 main thing you must do is to be sure the nose is straight down before
 applying aileron.
 Best regards,
 Roger_____________________________________________
 On Mar 12, 2008, at 6:37 AM, fougapilot wrote:
  Folks,
  techniques?
  tips on how to fly MY airplane better. [Laughing]
  Dan
  http://forums.matronics.com/viewtopic.php?p=169218#169218
		jan.mevis(at)informavia.b Guest
				 Posted: Wed Mar 12, 2008 7:09 am    Post subject: Vertical roll |
				Perhaps it might help to trim for 0 G
 In that way,when you go vertical, it's easier to stay on the line.
 Jan
 [quote] --
		brian-1927(at)lloyd.com Guest
				 Posted: Wed Mar 12, 2008 10:59 am    Post subject: Vertical roll |
  Folks,
  CJ.
  techniques?
 How many degrees of roll do you want? I think you would be very hard
 pressed to reach 360 degrees of roll on an up-line before running out
 of airspeed. I have done partial rolls (90 degrees and occasionally
 180 degrees) but one needs to maintain enough airspeed that the rudder
 still works. With the CJ that is pretty tough.
 Brian Lloyd                         3191 Western Drive
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 — Antoine de Saint-Exupéry
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		fougapilot
				 Posted: Wed Mar 12, 2008 11:54 am    Post subject: Re: Vertical roll |
				Ideally, one would like to do a complete 360 on the up line, but one is also realistic about one's airplane's limits.
 I guess the best way to explore this capability would be with adding a 1/4 turn on the down line of a hammer head. Then add 1/2 a turn and finally do the same on the up line. Just wondered if anyone had gone through the process before and could point the traps for me.
 Dan
				 Posted: Wed Mar 12, 2008 1:49 pm    Post subject: Vertical roll |
				Suspect inverted flat spin would be one of them. But, that exists with any
 aircraft the you take into the vertical and run it out of energy while at
 the same time placing a rolling moment on it. Particularly if the torsional
 roll is opposite of the P factor. The F-16 does not like that at all! FWIW.
 Viperdoc
				 Posted: Wed Mar 12, 2008 1:55 pm    Post subject: Vertical roll |
				I'm curious... And this is kind of off the subject line.  I infer from what Brian said that the rudder control on a CJ is not all that powerful.  I do not know this, I have never flown a CJ in my life, so I am not bad mouthing anything.  However, I am curious how many pilots here have worked with the elevator doing humpty-bumps on the vertical line?
 As far as vertical rolls go, the real trick of these is to... Well... To get VERTICAL in the first place.  Step two is to learn how to watch your wingtips and learn how to use your rudder to KEEP the vertical line by comparing wingtip placement compared to the horizon.  A perfect vertical roll is something you kind of feel in your butt when you get it really nailed.  Sadly, doing rolls going down is a totally different experience than doing them going up.  A lot of that has to do with where you end up focusing your eyes.
 Brian mentions maintaining enough airspeed that the rudder still works in a CJ.  Being the nit-picker that I am, in a true hammerhead, you do not have enough airspeed for the rudder to work at all, or the ailerons for that matter.  What gives the rudder control authority at all is the fact that the engine is creating air flow past the rudder giving it enough control authority to commence the hammerhead.  A true hammerhead is a pivot on a point with very little forward aircraft motion, and if done perfectly... About zero forward energy.  If you start a hammerhead too early with forward speed, you will ARC through the turn and not pivot.  Again, knowing nothing about a CJ, I differ to people who have flown it to know what is necessary to do what.  That said, in most aerobatic aircraft that I have flown, I practice zero airspeed recoveries on the vertical line.  Anyone that decides to attempt a vertical roll is probably going to sooner or later run out of airspeed while still in the vertical.  Contrary to some belief, airplanes don't really like to tail slide.  If you get into the vertical and realize you have run out of airspeed and ideas at about the same time, there are many thoughts on how to recover, from letting go of everything, to many other ways.  My personal way is to try and force the hammerhead and leave power on.  However if you really are out of ideas and totally unsure of what to do next, I would pull the power to idle and hold it there.  Neutralize everything and then just hang on for the ride.  In many cases, it is just fun to do that and see what happens anyway.  It is a great confidence builder to know that the airplane will recover itself even after you have run out of great ideas.  It is life preserving to be damn sure your aircraft is within CG limits before doing this by the way.
 On the same topic is a humpty-bump when you go up in a vertical line and use elevator to more or less... Half loop it, right over the top, and then head straight down again.  The interesting thing here is the speed that you can do this, which in many cases is much less than you might imagine.  There is a trick.  You start this maneuver on a vertical up line, and then pull into a half loop ending up going straight down, hold the line, then recover.  On the second attempt, hold the vertical line a little longer... Lose more airspeed, and continue as before.  Do it again, even LESS airspeed.
 Sooner or later you will slow to the point that when you pull back on the stick, you will feel it become loose in your hands... Which at this point you have actually detached the air flow over the surface of the elevator.  Quickly push the stick forward again, and then pull it back again ... Once more you will get some aircraft movement and then it will stop as the stick comes loose in your hands.  Do this, in what looks like a rapid push forward, a pull back, then a rapid push forward again... In a very fast kind of pumping motion.  What you are doing is pulling back to airflow detachment, then pushing it forward to re-attach air flow and then pulling back until it breaks flow again, and then repeating.  This can allow you to pull over the top of a vertical line and regain a downward line at a much slower speed than you would have ever believed possible.  Sergei Boriak taught me this.  It works.
 I usually limit my input to electrical stuff.  I am not a really great aerobatic pilot... But I hang out with some really good ones!
 Mark Bitterlich
 N50YK
				 Posted: Wed Mar 12, 2008 2:25 pm    Post subject: Vertical roll |
				Just for discussion sake Doc, you will never have that happen in the 50
 on the up line if you just remember to pull all power to idle.. And I
 mean REALLY all the way to idle and then just center everything and have
 slight back pressure.  Slight ... Back... Pressure.  It might end up in
 a spin, but never flat, and it has never gone inverted on me.
 Mark
				 Posted: Wed Mar 12, 2008 3:48 pm    Post subject: Vertical roll |
				On Mar 12, 2008, at 12:54 PM, fougapilot wrote:
 Spend some time doing hammerheads. (Well, you can't actually do a
 hammerhead with the CJ6A but you know what I mean.) You are going to
 learn where you run out of rudder. If you wait too long the airplane
 will not pivot around the yaw axis. It will sort of cock off to the
 side and then sit there. At that point you need to get the nose moving
 toward the horizon using pitch as the elevator is still effective.
 Once you are comfortable with knowing where that point is you can roll
 the aircraft until you get there.
 If you find yourself without airspeed and on a vertical up-line, I
 find that it is easier to get the CJ to fall over on its back than to
 go nose down.
 I also discovered that if you wait too long you will discover how the
 CJ does a tail-slide. I know I did. My recovery was to close the
 throttle, neutralize the rudder, suck the stick back into my lap, and
 wait for it to rotate nose-down around the pitch axis. It did a very
 nice tail slide for a bit. No I don't recommend trying this at home.
		jland(at)popeandland.com Guest
				 Posted: Wed Mar 12, 2008 3:51 pm    Post subject: Vertical roll |
				It would be almost impossible to make the CJ flat spin inverted without
 serious skill- It's hard enough to make them spin at all.......
 I don't think Alex has ever gotten a "full" roll on an up line- it would
 certainly require exceeding redline before the pull.
 You can see a 1/4 roll on the upline here- (plus 8 sided loop, roll on the
 top of a loop, 1/2 cubans, hammers, etc....)
 http://www.landaerosports.com/content/view/28/46/
 Check out the CJ video.
 Jay
 [quote] From: "Roger Kemp M.D." <viperdoc(at)mindspring.com>
  Reply-To: <yak-list(at)matronics.com>
  Date: Wed, 12 Mar 2008 16:46:28 -0500
  Subject: RE: Re: Vertical roll
  Viperdoc
				 Posted: Wed Mar 12, 2008 4:01 pm    Post subject: Vertical roll |
				On Mar 12, 2008, at 2:52 PM, Bitterlich, Mark G CIV Det Cherry Point,
 MALS-14 64E wrote:
  Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
  powerful.
 That is correct.
  	  | Quote: | 	 		   Brian mentions maintaining enough airspeed that the rudder still
  pivot.
 Precisely. This is how a "hammerhead" must be flown in the CJ6A in
 order to perform it. I start the turn at about 40 kts indicated
 (actually I just feel the right point) and have to hold forward stick
 and outside aileron to get the aircraft to turn around the inside
 wingtip with any roll.
  	  | Quote: | 	 		   Again, knowing nothing about a CJ, I differ to people who have flown
 And some, like the CJ6A, are not designed for the tail loads that can
 come of it.
  	  | Quote: | 	 		   If you get into the vertical and realize you have run out of
  power on.
 You can't force the hammerhead in the CJ. The only thing that is still
 working is the elevator so you have to force the rotation in pitch.
 Once you get the nose falling through, you can get the power off,
 neutralize the controls, and recover once the nose is well below the
 horizon and airspeed is starting to build again.
  	  | Quote: | 	 		   However if you really are out of ideas and totally unsure of what to
 That is what I recommend too.
  	  | Quote: | 	 		   Neutralize everything and then just hang on for the ride.
 Ah, we found a similar approach in this.
  	  | Quote: | 	 		   In many cases, it is just fun to do that and see what happens anyway.
 This is pretty safe with the CJ6A too. It is a very forgiving airframe.
  	  | Quote: | 	 		   It is a great confidence builder to know that the airplane will
 Ah, that is my last-ditch recovery from a botched hammerhead. And it
 is fun to do. The CJ has elevator authority right to the very end so
 you can always get it to go nose down that way. But if your line is
 not perfectly vertical (alpha not zero), you will have to feel for
 which way it wants to go. Sometimes it isn't obvious and you need to
 reverse the pitch input.
  	  | Quote: | 	 		   Sooner or later you will slow to the point that when you pull back
 Ah, that is precisely what I mean when I say you have to feel for it.
  	  | Quote: | 	 		   I usually limit my input to electrical stuff.  I am not a really
  ones!
 The reasons for doing this are twofold:
 1. to learn where the limits to flight are;
 2. to become unafraid of the airplane.
		david(at)mcgirt.net Guest
				 Posted: Wed Mar 12, 2008 4:17 pm    Post subject: Vertical roll |
				Some more basic CJ-6 Acro...
 http://youtube.com/watch?v=woyRFd0sIw4
  Jay
 > Viperdoc
		drc(at)wscare.com Guest
				 Posted: Wed Mar 12, 2008 5:20 pm    Post subject: Vertical roll |
				Mark,
 Excellent and exactly on !!
 The key to the vertical roll is the perfect zero G line. Not positive
 or negative.  and wingtips even, as the plane slows more left rudder
 is needed and as the plane enters the first 1/4 loop gyroscopic force
 has to be countered.  If the plane hits the perfect vertical line the
 roll is as simple of an aileron roll as possible.  Rolling to the
 right is easier on the up and down line.  The elevator controls load
 and the rudder controls yaw.  If these are on there is no adverse yaw
 due to the roll.
 You can cheat a little to nail the vertical line by pulling with the
 right wing slightly low (right roll) now you correct on the way up
 with the left rudder.  At zero airspeed almost all of the left foot is
 in and when you alternate and stand on the right rudder the pivot is
 amazingly sharp and fast  !!
 The hint about the humpty below 50 knots is perfect - pumping the
 elevator provides enough airflow to complete the rotation at the top
 without a stall.
 To stall inverted the plane must start over on its back, then push the
 stick forward = inverted stall.  If either foot is heavy on a rudder =
 inverted spin.  If the power is on and outspin aileron is entered =
 inverted flat spin.  So it takes some effort to put the Yak into an
 inverted flat spin.  And to recover, power off and neutralize the
 controls - if you have enough altitude it will recover nose down.
 It is my understanding that besides a CG forward of the center of
 lift, minimal fuel load in the wings is critical.  If either upright
 or inverted spin is allowed to fully develop into autorotation and the
 fuel load is such that inertia moves the mass of the plane outboard,
 there may not be enough rudder to recover.
 Fly Safe
 Herb
 On Mar 12, 2008, at 4:52 PM, Bitterlich, Mark G CIV Det Cherry Point,
  vertical line?
  ones!
  Mark Bitterlich
  N50YK
				 Posted: Wed Mar 12, 2008 5:22 pm    Post subject: Vertical roll |
				Will try it.
 Doc
				 Posted: Wed Mar 12, 2008 5:47 pm    Post subject: Vertical roll |
				Gabby is truly an amazingly talented young man.
 Doc
		scott-p(at)texas.net Guest
				 Posted: Wed Mar 12, 2008 6:17 pm    Post subject: Vertical roll |
				The only real trick to a vertical roll (up or down) is BE VERTICAL. Not
 close. VERTICAL. Learn this by having someone on the ground watch you,
 and believe what they tell you even if it looks wrong from the cockpit.
 Oh, and don't play with the rudders--if you started vertical, rudders
 will barrel the roll while most errors in plane of rotation can (and
 should) be fixed with the elevator. Adding rudder to a line that isn't
 vertical will only result in what is essentially a vertical slip and
 rolling in that condition doesn't produce pretty rolls or long lines.
 I agree that the best way to start vertical rolls is as a 1/4 roll on a
 vertical downline (e.g., after a hammer). In this case you are very
 likely to be vertical AND you can use a simple technique to keep the
 roll from being barreled: look straight ahead at the ground. Pick a
 point straight out in front of your eyes on the ground and roll around
 that point. When you've got the 1/4 down, move to 1/2 and then 3/4 and
 full rolls (or points for that matter). Once those are in hand, then
 start with the roll on the vertical up. It sounds weird, but some people
 find it easier to look straight ahead (i.e., up) and roll there too, and
 judge the amount of roll by timing.
 It goes without saying that all this should be done at altitude, with a
 chute, ideally with an experience instructor, and ONLY after you are
 fully comfortable with upright and inverted spins of the normal,
 accelerated and flattened varieties. Botched vertical rolls sometimes
 end up as tumbles, so be prepared for Mr. Toad's wild ride...
 That's it. No magic.
 Hope this helps,
 Scott
 Yak 55M N155YK
 fougapilot wrote:
  Dan
  http://forums.matronics.com/viewtopic.php?p=169347#169347
				 Posted: Thu Mar 13, 2008 12:34 pm    Post subject: Vertical roll |
				Thanks to both Herb and Scott for excellent corrections and additional advice.  Like I said, while I do love Aerobatics, I am no where near as good as most people on this list.
 Mark Bitterlich
				 Posted: Thu Mar 13, 2008 2:03 pm    Post subject: Vertical roll |
				And I'll leave the electrical issues to you guys !!
 On Mar 13, 2008, at 3:31 PM, Bitterlich, Mark G CIV Det Cherry Point,
  Mark Bitterlich
		3bar(at)telus.net Guest
				 Posted: Thu Mar 13, 2008 2:22 pm    Post subject: Vertical Roll |
				Hey Dan,
  Back a few years ago in my first CJ with the 285,  myself and a buddy Peter Herzig, who was a competition acro dude with a Suk  26MX did verts in the CJ. Like a lot of guys said, I don't think we did get a  complete 360 but ended up with about a 270 before running out of steam.  Entered at 180K and 6G's and it works quite well, vertical line is a definite  key, level wings etc. We got supreme reprimand from father Lannon for speed  and stress, but I did keep doing them myself (outa site), then tried a mild  entry and fell off the top out of speed, pulled over backwards and let the heavy  end find its way down. Wasn't pretty at all so I never relaxed that entry again.  Have not yet done any in my M14P, but it should do a lot  better.
  Fly Safe,
  Paul Dumoret
