Fuel Injector Servo SB
ron.mcgann(at)baesystems.
PostPosted: Thu Mar 13, 2008 2:29 pm    Post subject: Fuel Injector Servo SB Reply with quote
G'day all,
There is a service bulletin on the Precision Airmotive series of Fuel Injectors requiring immediate attention. http://www.precisionairmotive.com/Publications/PEX-1.pdf refers.
I have not checked the part number of the servo delivered with my new Lyco from Vans, but I'm pretty sure it is one of the affected items.
I don't recall seeing any posts on this issue on the list, so I thought I would pass on the details. Apologies in advance if this is not relevant to the fuel injection servos we have on our 540's.
Ron
-187 finishing (was going to install the servo tonight!) [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
PostPosted: Thu Mar 13, 2008 8:20 pm    Post subject: Fuel Injector Servo SB Reply with quote
Checked my injector servo at lunch time (straight out of the box, not yet installed). Although the plug was lockwired it was clearly loose. Since the only heat my engine has been exposed to is the test run conducted at the factory, shrinkage of the seal with heat is not the only problem here. I doubt the plug was properly torqued at the factory before delivery.
check those servos!!
cheers,
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Friday, 14 March 2008 8:55 AM
Subject: Fuel Injector Servo SB
G'day all,
Ron
"Warning:
your computer."
p://www.matronics.com/Navigator?RV10-List
ics.com
.matronics.com/contribution
"Warning:
your computer."
acs(at)acspropeller.com.a
PostPosted: Thu Mar 13, 2008 10:09 pm    Post subject: Fuel Injector Servo SB Reply with quote
This is the FAA AD Ron is referring to in case some of you don’t have the info through the mail yet..
I could say something with regards experimental and some earlier comments but I’ll resist J
John 40315.
Sent: Friday, 14 March 2008 2:17 PM
Subject: RE: Fuel Injector Servo SB
cheers,
Ron
G'day all,
Ron
"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is
5
6
7The information contained in this email and any attached files is
8
9
5
6
7
8
9
5
6
7
8
9
5
6
7
8
9
2008-06-51_Emergency.pdf
 Filename:  2008-06-51_Emergency.pdf
 Filesize:  23.81 KB
 Downloaded:  293 Time(s)
