dreel(at)cox.net Guest
Posted: Fri Mar 14, 2008 5:40 am Post subject: Registration Display |
Does my RV-8A need it's FAA registration or other paper work displayed in the cockpit or can I keep it in an envelope inside one of my panel storage boxes? I do have the EXPERIMENTAL and the warning blurb text attached so the passenger can read it from their aft seat & it passed FAA inspection.
Tim flew and I rode passenger yesterday. Exciting. Tim can really land smoothly & keep the nose up for roll out. Unfortunately, I'm now ready to show everything to possible buyers because I got cancer & have to sell a plane in great condition with only 50hr flight time.
Dave Reel
panamared5(at)brier.net Guest
Posted: Fri Mar 14, 2008 6:57 am Post subject: Registration Display |
The Reg says it must be displayed. However, I keep mine in the glove
compartment. When the aircraft was signed off by the FAA, I asked
the inspector this question and did not get a response, more of a
shrug of the shoulders.
But, If an FAA guy is looking for a reason to write up a violation,
then this would be one.
RV6 "Wicked Witch of the West"
At 07:36 AM 3/14/08, you wrote:
| Quote: | Does my RV-8A need it's FAA registration or other paper work
rv(at)thelefflers.com Guest
Posted: Fri Mar 14, 2008 7:41 am Post subject: Registration Display |
We were ramp checked during a Young Eagles event awhile ago. They wanted to
see it someplace visible in the cockpit. Mine was in my flight bag at the
time on the back seat of my Cherokee. But since I wasn't first to get
checked, I had an opportunity to put it back in the plastic pouch.
Ironically, it's by my left ankle, so there is no practical way anyone else
in the aircraft could see it.
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Fri Mar 14, 2008 8:25 am Post subject: Registration Display |
Short answer is that the Airworthiness Certificate (not the Registration) must be displayed. The rest of the ARROW stuff must be carried but doesn't need to be displayed. See following for the long answer from an EAA Question of the Week...
Q & A: Question of the Week
Question for EAA Aviation Information Services:
I have purchased a homebuilt aircraft from the original builder. It was issued a Special Airworthiness Certificate. Am I required to carry this certificate in the aircraft after the initial test phase of flying has been completed?
Answer:
Yes, you are always required to carry (and display) the airworthiness certificate in a US aircraft, regardless of what type of certificate has been issued. This is called out in the following regulations:
14 CFR 91.203, which states in part:
“(a) Except as provided in §91.715, no person may operate a civil aircraft unless it has within it the following:
(1) An appropriate and current airworthiness certificate. Each U.S. airworthiness certificate used to comply with this subparagraph (except a special flight permit**, a copy of the applicable operations specifications issued under § 21.197(c) of this chapter, appropriate sections of the air carrier manual required by parts 121 and 135 of this chapter containing that portion of the operations specifications issued under § 21.197(c), or an authorization under §91.611) must have on it the registration number assigned to the aircraft under part 47 of this chapter. However, the airworthiness certificate need not have on it an assigned special identification number before 10 days after that number is first affixed to the aircraft. A revised airworthiness certificate having on it an assigned special identification number, that has been affixed to an aircraft, may only be obtained upon application to an FAA Flight Standards district office.”
**Information on “Special Flight Permits” issued by the FAA can be reviewed in FAA Order 8300.10, Chapter 89.
Note that the airworthiness certificate be displayed in the aircraft, as required by 91.203(b):
“(b) No person may operate a civil aircraft unless the airworthiness certificate required by paragraph (a) of this section or a special flight authorization issued under §91.715 is displayed at the cabin or cockpit entrance so that it is legible to passengers or crew.”
Also be aware that your aircraft’s special airworthiness certificate was issued with an attached set of operating limitations. These operating limitations are considered to be a part of the airworthiness certificate, and as such must be carried in the aircraft at all times.
Greg Young
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Reel
Sent: Friday, March 14, 2008 8:36 AM
To: rvlist
Subject: Registration Display
Dave Reel
mrobert569(at)hotmail.com Guest
Posted: Sat Mar 15, 2008 7:33 am Post subject: Registration Display |
The special airworthiness certificate is the only doucument that MUST be displayed in the cabin where it can be seen while operating the aircraft. Normally most folks keep the registration with the a/w certificate and the operating limitations in the glove box or pouch. They just need to be kept in a spot that is accessible to the pilot.
Mike Robertson
Das Fed
| Quote: | From: dreel(at)cox.net
To: rv-list(at)matronics.com
Date: Fri, 14 Mar 2008 09:36:20 -0400
Dave Reel
t=_blank>http://www.matronics.com/Navigator?RV-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| Windows Live Hotmail is giving away Zunes. Enter for your chance to win. Enter Now! [quote][b]
