Recommended Wire Stripping Tool
dvanlanen
PostPosted: Fri Mar 14, 2008 10:00 am    Post subject: Recommended Wire Stripping Tool Reply with quote
I have been reading my new copy of the AeroElectric Connection manual, as well as the website information, and I have not found any specific recommendation for the best wire stripping tool. My understanding is that the most important aspect of a good tool is that it does not nick the underlying wire strands when stripping insulation. Can the list recommend a good tool from personal experience?
Dave Van Lanen
Madison, WI
601XL – Elevator (preparing to wire RA elevator trim servo) [quote][b]
Gig Giacona
PostPosted: Fri Mar 14, 2008 10:39 am    Post subject: Re: Recommended Wire Stripping Tool Reply with quote
I got the most expensive one Radio Shack had on the shelf and it has worked pretty well for me.
http://www.radioshack.com/product/index.jsp?productId=2062787&cp=2032058.2032237.2032319&parentPage=family
I don't use the crimper that is on it.
W.R. "Gig" Giacona
601XL Under Construction
Jaybannist(at)cs.com
PostPosted: Fri Mar 14, 2008 10:39 am    Post subject: Recommended Wire Stripping Tool Reply with quote
Dave,
For AWG16 and larger, I use a stripper from Radio Shack; the kind that grips the wire; has calibrated, sharpened slots at the start of the strip, and pivots to complete the strip.
For anything smaller I use a technique acquired in an Army electronics school. With a diagonal cutter ("dikes") carefully score around the start of the strip. Then, with your hand around the dikes at the pivot point, apply gentle pressure at the strip point and pull. It takes a little practice, but it is easy to get the hang of. Effective, quick and easy.
Jay in Dallas CH 601XL N2630J "Lil Bruiser"
Dave Van Lanen
Madison, WI
601XL - Elevator (preparing to wire RA elevator trim servo)
johnd(at)data-tech.com
PostPosted: Fri Mar 14, 2008 11:07 am    Post subject: Recommended Wire Stripping Tool Reply with quote
Hi Dave,
I've got the Stripmaster from stein air at http://www.steinair.com/tools.htm. Its a bit pricey but does a nice job and certainly doesn't nick the wire.
Dave VanLanen wrote: [quote] Recommended Wire Stripping Tool
Dave Van Lanen
Madison, WI
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
craig(at)craigandjean.com
PostPosted: Fri Mar 14, 2008 11:19 am    Post subject: Recommended Wire Stripping Tool Reply with quote
If you search the Matronics aeroelectric list archives you should find some leads. There are automatic strippers and then there are automatic strippers. The ones like Radio Shack sells are automatic but they still have sharp cutting blades which can nick the wires. The better (and more expensive) ones basically put a dent in the insulation and then pull it apart. The part that puts the dent in the insulation is not a sharp edge. With practice you can do the same operation with a cheap pair of the strippers that are two flat bars joined with a bolt and with a V notch in both bars. Just get a grip on the insulation with the V’s, push away and increase your squeeze until the insulation parts. The metal will never touch the conductor. But it takes practice to develop a feel.
Back in Dec 2005 I bought one of the expensive automatic strippers from a guy named Gary Edwards (gary21sn(at)hotmail.com) on the aeroelectric list. I doubt that he has any more but this is what he wrote at the time:
“More info on the wire strippers from my e-mail from last night.
IDEAL Stripmaster - Model 45-1610-1
Has 16 to 26 gauge aircraft wire strip die
Made in the USA
This tool is the best wire stripper I have ever used. It is truly a "one squeeze" automatic wire stripper. With one squeeze, it grips the wire at the insulation, cleanly pulls the insulation off the wire. Release the spring loaded handle and the tool releases its grip on the wire. No cut wire strands.
The stripping die has separate sized stripping holes for 16, 18, 20, 22, 24, 26 gauge aircraft wire (die part number: 88A081X). So, no tool adjustments are necessary for different size wire. It is ready to work right out of the box.
This wire stripper is the "bench mark" that all others are measured by. This is the one that Bob Knuckolls wrote about and has pictures of in his article in the AeroElectric Connection.
If you are searching around for Ideal Stripmaster wire strippers, make sure you search for the model 45-1610 as it is the specific one for aircraft wire.”
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dave VanLanen
Sent: Friday, March 14, 2008 11:57 AM
Subject: Recommended Wire Stripping Tool
Dave Van Lanen
Madison, WI
n85ae
PostPosted: Fri Mar 14, 2008 12:31 pm    Post subject: Re: Recommended Wire Stripping Tool Reply with quote
The best thing is thermal strippers. You can find them by doing a google
search for "thermal stripper"
They will not nick the wires at all. They will cost a bit, but if you're really
picky they are the best way to go.
Jeff
PostPosted: Fri Mar 14, 2008 1:05 pm    Post subject: Recommended Wire Stripping Tool Reply with quote
Do the thermal strippers work with tefzel?
-- Craig
n85ae
PostPosted: Fri Mar 14, 2008 1:41 pm    Post subject: Re: Recommended Wire Stripping Tool Reply with quote
That's the only thing I have ever used them for to be honest. I think other
wire types might not work so well for thermal stripping. One thing is that
there is smoke produced when you do it, so an open door and a fan are a
good thing.
You adjust the temp first, then basically you just clamp on the wire where
you want to cut the insulation, rotate the tool. Release it. Then you grab
the insulation and tug it off. It does not even disturb the twist of the wires.
I used one exclusively for about three years at a job I had. They are
very nice tools. They are a bit expensive, though. I personally just use
a Klein conventional stripper for my airplane project. The key is clamp
it on rotate it, then pull the insulation off with your fingers. That will avoid
90+ percent of the nicks.
Jeff
Ron Lendon
PostPosted: Fri Mar 14, 2008 7:30 pm    Post subject: Re: Recommended Wire Stripping Tool Reply with quote
The Stripmaster I bought and am using is the one from B & C Speciality Products, Inc. and it's the model 45-097 Ideal Stripmaster.
Used it on Tefzel 16-26 AWG wire, no nicks.
YMMV
Their website location for this tool:
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?9X358218
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
dvanlanen
PostPosted: Mon Mar 17, 2008 1:13 pm    Post subject: Recommended Wire Stripping Tool Reply with quote
I received a number of good tool references from the list (thank you),
however these tools are all limited to a range of about 16 to 26 AWG wire.
What are builders using for larger diameter wire, such as for the engine and
charging system, etc.?
Dave Van Lanen
Madison, WI
601XL - Elevator
Time: 08:34:11 PM PST US
Subject: Re: Recommended Wire Stripping Tool
Products,
YMMV
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder Wink
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.69 KB
 Downloaded:  448 Time(s)
PostPosted: Mon Mar 17, 2008 2:28 pm    Post subject: Recommended Wire Stripping Tool Reply with quote
For the really big cables (4 or 8 gauge) just cut a shallow slit all the way around the insulation with a single edge razor blade being careful not to cut all the way through the installation. Then either pull on the short piece of insulation or flex the cable which will cause the slit to split all the way open down to the conductor. I suspect a tubing cutter could also be used to make the slit in a more controlled fashion but haven’t tried it.
-- Craig
_____________________________________________
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of Dave VanLanen
Sent: Monday, March 17, 2008 3:10 PM
I received a number of good tool references from the list (thank you), however these tools are all limited to a range of about 16 to 26 AWG wire. What are builders using for larger diameter wire, such as for the engine and charging system, etc.?
Dave Van Lanen
Madison, WI
601XL - Elevator
YMMV
http://www.mykitlog.com/rlendon [quote][b]
Ron Lendon
PostPosted: Mon Mar 17, 2008 5:53 pm    Post subject: Re: Recommended Wire Stripping Tool Reply with quote
Dave,
Been thinking about the question and thought this tool from Radio Shak might do the trick. Its part number is 278-248. It is made for coax cable but is has adjustable blades and the orange thing rotates to accommodate different size cable. You could disable one of the cutters and only set the other to cut most of the way through. It won't do everything, once you get it setup you will know it won't nick the wire.
Pictures below
 Filesize:  50.71 KB
 Viewed:  594 Time(s)
 Filesize:  42.09 KB
 Viewed:  625 Time(s)
 Filesize:  43.56 KB
 Viewed:  668 Time(s)
 Filesize:  39.24 KB
 Viewed:  606 Time(s)
Ron Lendon
CH 601 XLB
N601LT - Flying
PostPosted: Tue Mar 18, 2008 4:34 am    Post subject: Recommended Wire Stripping Tool Reply with quote
Dave, I've used that tool very successfully on large cables. Jay in Dallas
"Ron Lendon" <rlendon(at)comcast.net> wrote:
Dave,
Pictures below
http://forums.matronics.com/viewtopic.php?p=170528#170528
http://forums.matronics.com//files/rs_278_248_001_small_264.jpg
bryanmmartin
PostPosted: Tue Mar 18, 2008 11:36 am    Post subject: Recommended Wire Stripping Tool Reply with quote
I use an Ideal Swivel-Blade Cable Stripper for large cables.
See: http://www.hmcelectronics.com/cgi-bin/scripts/product/4440-0068
You set the blade depth with the thumb screw, then just clamp it on the
cable and turn it around the cable once and pull it straight off the
end. You can probably get them at a local electrical contractor supply
house also.
Of course, if you are only going to strip a few cables, careful
application of a sharp knife will be much cheaper. I have a set of these
because I used to work as an electrician. These things save a lot of
time and effort when you're doing it all the time.
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
Bryan Martin
do not archive.
