thesumak(at)aol.com Guest
Posted: Sat Mar 15, 2008 8:48 pm Post subject: Sign-on for structural analysis |
I’m building from a regular kit, but I also just finished my first wing (with wing locker) and though I’m just a grunt, I saw nothing that would give me pause. I do however take very seriously the designers warning about airframe stress associated with abrupt or accidental elevator movement but I have faith that Zenith will take a closer look at that. I have no interest in helping to fund an independent analysis.
Bill
rsteele(at)rjsit.com Guest
Posted: Sun Mar 16, 2008 6:47 am Post subject: Sign-on for structural analysis |
I'm out.
I'm wondering just what is the expected result of this analysis.
There are two possibilities, the design is found to be sound, in
which case money has been spent to feel good. Or the design is found
to be deficient. In this case you can't expect he consultant to
redesign the wing, which would be a whole other level of effort and a
lot more money, not to mention liability issues for the engineer.
Regarding the static testing: The purpose of a test is to gather
information. That can best be done in a very controlled environment
and static testing is the most controlled you can get. All sorts of
structures are tested this way from bridge models to sky scrappers.
It's not perfect, but most things in life aren't. Perhaps more
information could have been gained thought testing to destruction,
but it's not really necessary in this case sense he design loads were
met.
I'm with Larry on this, work with ZAC. Build a wing and do the
destructive test yourself in whatever failure mode you are concerned
about.
do no archive.
Ron
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sun Mar 16, 2008 7:01 am Post subject: Sign-on for structural analysis |
On Sun, Mar 16, 2008 at 10:44:47AM -0400, Ronald Steele wrote:
| Quote: | I'm wondering just what is the expected result of this analysis.
Knowing there's a problem - or not, as is entirely possible - is half the
battle. If nothing else, if there is a problem, then we can, hopefully, get
Zenith/Zenair to fix it.
| Quote: | Regarding the static testing: The purpose of a test is to gather
If it's a problem that only appears under certain conditions you can't
achieve in static testing, though, you'll never find it.
Aircraft have more ways to go wrong than bridges or skyscrapers, too.
I'm not saying that there is a problem. I just want to know for sure.
Jay Maynard, K5ZC http://www.conmicro.com
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (getting ready to order)
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
ashontz
Posted: Sun Mar 16, 2008 8:52 am Post subject: Re: Sign-on for structural analysis |
This is my real interest in this. I can accept the inherent dangers in flying, but no chance in taking any more risks than is necessary. If you can double check this on the ground, why not. Be like assuming you have enough fuel on board or the oil level is topped off. That's just stuff you check. If you experienced an odd engine vibration on your last, you probably wouldn't just forget about it and go ut flying the next day. You also check this out if it seems something is amiss. Nothing chicken-hearted here at all.
| jmaynard wrote: | If it's a problem that only appears under certain conditions you can't
AMD Zodiac CH601XLi N55ZC (getting ready to order) |
stshuck2(at)yahoo.com Guest
Posted: Sun Mar 16, 2008 9:45 am Post subject: Sign-on for structural analysis |
Well said the both of you,,,, I'M STILL IN as well..
ashontz <ashontz(at)nbme.org> wrote: [quote]--> Zenith-List message posted by: "ashontz"
jmaynard wrote:
[quote] If it's a problem that only appears under certain conditions you can't
achieve in static [quote][b]
