nuckolls.bob(at)cox.net Guest
Posted: Sun Mar 16, 2008 6:05 pm Post subject: Ground Start enunciator light (Addendum) |
At 01:53 AM 3/16/2008 +0000, you wrote:
Quote: |
<trigo(at)mail.telepac.pt>
Listers
I installed a Piper-type male socket to my airplane, to have the possibility
of a ground start in case of a low battery cranking difficulty.
As recommended by this List experts, I connected the socket to the battery
through a continuous duty contactor (aka Master Relay or Battery solenoid),
the S701-1 from B&C, controlled by a SPST switch, which grounds the
contactor when thrown to ON.
Now what I want to do is to put a green enunciator light in my panel, which
illuminates when that switch is ON and the contactor is closed to allow the
ground start procedure, to remind me to switch it Off after finishing that
procedure.
I have tried some wiring of the warning light to the switch, but I cannot
make it work properly. Can somebody please enlighten me how to wire it?
Carlos,
A couple of hours after I replied to this it occurred to me that
you probably were not incorporating a press-to-test light fixture
nor did you mention crowbar ov protection. I've updated the
schematics in the article to include "Ground Power Lite" without
OV protection and using a plain vanilla lamp fixture. See the
last page of:
http://www.aeroelectric.com/articles/grndpwr.pdf
Is this more like what you needed?
( -Thomas Paine 1776- )
willslau(at)comcast.net Guest
Posted: Sun Mar 16, 2008 6:49 pm Post subject: Ground Start enunciator light (Addendum) |
On a related note:
The instructions for modifying the receptacle call for a propane torch or
"large soldering iron". How large an iron? I ask because I incinerated the
phenolic insulator when I tried to solder it with my propane torch, and have
just ordered a replacement receptacle to try again. If I preheat the bolt in
the oven, would a Weller 100/140 soldering gun have enough oomph? If not,
William Slaughter
Posted: Mon Mar 17, 2008 2:12 am Post subject: Ground Start enunciator light (Addendum) |
[quote] --
Posted: Mon Mar 17, 2008 9:44 am Post subject: Ground Start enunciator light (Addendum) |
Listers
procedure.
Carlos,
last page of:
Posted: Mon Mar 17, 2008 1:37 pm Post subject: Ground Start enunciator light (Addendum) |
At 09:44 PM 3/16/2008 -0500, you wrote:
Quote: |
<willslau(at)comcast.net>
On a related note:
No. Go to Home Depot or Lowes and see if you can find a
Bernzomatic ST100T micro torch. This is my all time favorite
although I don't find it described on the Bernszomatic website.
It may be discontinued. In any case, you need a micro-torch not
unlike those shown at:
http://www.aeroelectric.com/Pictures/Tools/Soldering/Gas_Tools/
Harbor Freight has some butane micro-torches as do many
hardware stores. I think Walmart stocks one too. Ace Hardware
stores have:
http://tinyurl.com/2tgatp
Also, use 63/37 alloy solder. This stuff melts at 361F and
flows nicely below 400. There's a rubber-bumper on the
end of the receptacle center-pin. Pull this off for soldering
operations and replace it after the pin cools.
