Posted: Thu Mar 13, 2008 1:01 pm Post subject: Andair/FI Fitting |
Does anyone have an Andair valve and has installed the fuel system which Van's sells. I am trying to figure out why I need to install this special AN fitting in the system. Where does it go and why is it needed?
Seems like the exit port on the fuel system setup which is normally plugged back into the standard Van's fuel selector valve could simple be put right into the Andair valve return port. What am I missing?
John G
Deems Davis
Posted: Thu Mar 13, 2008 3:08 pm Post subject: Andair/FI Fitting |
John, it's been a while since I did this, but I used the Andair valve
and the standard Van's supplied fuel pump/filter kit. I don't recall a
special fitting. (It may have something to do with which Andair valve
you have/ordered as they are available with several different fitting
configurations) here's a link to the photo album of that portion.
http://deemsrv10.com/album/Sec%2037%20Fuel%20System/slides/DSC02794.html
there's several additional photos, just follow the controls on the page.
Deems Davis # 406
'Its all done....Its just not put together'
John Gonzalez wrote:
| Quote: | Does anyone have an Andair valve and has installed the fuel system
needed?
John G
Jim Berry
Posted: Thu Mar 13, 2008 3:36 pm Post subject: Re: Andair/FI Fitting |
If by "special AN fitting" you mean the swivel tee, it will make your line connections much easier.
Jim Berry
40482
Posted: Fri Mar 14, 2008 6:44 am Post subject: Andair/FI Fitting |
JIm,
I do mean the Tee swivel. So if it makes connection easier, where does it make connection easier? WHere does it go?
JOhn
Jim Berry
Posted: Fri Mar 14, 2008 8:08 am Post subject: Re: Andair/FI Fitting |
John,
I believe most people are using the Andair valve with the built in 90 degree ports, because it makes plumbing the fuel lines easier. I used the swivel tee on the center(or outflow) port because there is not enough room for a standard tee to clear the other 2 ports during installation. If you spend some time trying to get all 3 lines installed to the Andair in the confined space of the tunnel I think you will find the extra cost of the swivel tee to be worth it.
Jim Berry
40482
N15JB(reserved)
Posted: Sat Mar 15, 2008 11:17 am Post subject: Andair/FI Fitting |
Jim,
I presume what you mean is with the tee fitting, I wouldn't have to run return lines to each tank, and that the way you have it installed means that the overflow fuel that is created when the pump is on just goes back to the supply line coming off the Andair valve.
In my case I was originally going to install a different type of engine which required fuel pumps running continiously, so I in fact have return lines already installed running back to the tank so as I understand it, I will not need this tee fitting. I will just run my overflow line to the upper return port on my Andair valve and return the fuel to the tank it was pulled from.
Is this correct?
JOhn G. 409 redesigning the Door fitting, perfect timing with the emails.
| Quote: | Subject: Re: Andair/FI Fitting
Date: Fri, 14 Mar 2008 09:08:30 -0700
--> RV10-List message posted by: "jim berry" <jimberry(at)qwest.net>
John,
Jim Berry
40482
N15JB(reserved)
http://forums.matronics.com/viewtopic.php?p=169822#169822
Jim Berry
Posted: Sat Mar 15, 2008 2:54 pm Post subject: Re: Andair/FI Fitting |
John,
I think we may be talking about different things. See page 37-4, step 7. My comments assume one is using the Andair fuel valve with the built in 90 degree fittings. I believe most people are using this valve, as it provides easier routing of the fuel lines than the valve with 45 degree fittings shown in Van's drawings. The problem with using a standard AN826 tee on the center port is that the middle leg of the tee will not clear the right and left ports during installation. The swivel tee allows you to keep the middle leg in a fixed position while you tighten the female leg on to the center port of the Andair Valve.
I also have a return(purge) line for my Airflow Performance injector, so I actually used 2 swivel tees on the center and right ports to make future maintenance easier.
Jim Berry
40482
N15JB(reserved)
Posted: Mon Mar 17, 2008 8:34 am Post subject: Andair/FI Fitting |
Hi Jim,
I am sorry, I am really having trouble understanding why I need this. My andair valve has six ports. I have plumbed all the lines coming from the fuel tanks and going back to the fuel tanks. I originally needed to return fuel to the tanks because I was going to be running electrical fuel pumps all the time. I am still going to run overflow fuel to the tqanks if I am using the boast pump.
I also am using a six inch extension to place the valve lower down in the tunnel. I have no problem with space with the port that will be going to the fuel filter(Outflow). So why can I not just run the 3/8" return line from the pump package relief valve to the return port on the Andair valve?
JOhn
John,
Jim Berry
40482
N15JB(reserved)
&g==================
Tim Olson
Posted: Mon Mar 17, 2008 8:53 am Post subject: Andair/FI Fitting |
John,
Don't sweat it so much if you think it'll work. You're just
the first person who has had the more expensive dual valve
required for the subie and the continental install who's then
decided to go to a standard IO-540 install. If you want to
pump it back to the same tank it came from, I'm guessing it
should work fine. You're pioneering this one though, so
you're the one who'll have the best feedback....in a couple
years.
| Quote: | Hi Jim,
Andair valve?
JOhn
> From: jimberry(at)qwest.net
> To: rv10-list(at)matronics.com
> John,
> Jim Berry
> 40482
> N15JB(reserved)
Posted: Mon Mar 17, 2008 9:47 am Post subject: Andair/FI Fitting |
On the communication end, I figured something like that was occurring. It just wasn't making sense.
Thanks for bridging the gap.
| Quote: | Date: Mon, 17 Mar 2008 11:50:55 -0500
Subject: Re: RV10-List: Re: Andair/FI Fitting
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
John,
you're the one who'll have the best feedback...in a couple
years.
> Hi Jim,
> Andair valve?
> JOhn
> > John,
> > Jim Berry
> > 40482
> > N15JB(reserved)
> > Read this topic online here:
