SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Wed Mar 12, 2008 1:52 pm Post subject: Rotax 912 80HP Idle RPM |
At what RPM do you set your 80 HP Rotax 912 when the throttle is pulled all the way back (and the engine will still run)? I understand Rotax suggests 2,000 to 2,500 RPM at idle, but I'm referring to when the throttle is all the way back and you are about to land, without killing the engine, or when you want to taxi slowly?
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel |
kerrjohna(at)comcast.net Guest
Posted: Wed Mar 12, 2008 2:57 pm Post subject: Rotax 912 80HP Idle RPM |
mine is set at about 1800 rpm for LGU. Should be about the same for Morgan. The key is as slow as possible without excessive shaking and clatter from the impulse washers.
John Kerr
| Quote: | --> Kitfox-List message posted by: "SkySteve"
slowly?
Steve Wilson
Huntsville, UT
Kitfox I-IV 85DD
Convertable Nosewheel & Tailwheel
http://forums.matronics.com/viewtopic.php?p=169388#169388
SkySteve
Posted: Wed Mar 12, 2008 3:16 pm Post subject: Re: Rotax 912 80HP Idle RPM |
Thanks, John. I currently have mine set at 1800 RPM also, but it really taxis fast and would like to be able to slow down without riding the brakes.
Huntsville, UT
Jim Shumaker
Posted: Wed Mar 12, 2008 6:14 pm Post subject: Rotax 912 80HP Idle RPM |
My idle is set to be able to get as low as 1500. This is only used for landing. The minimum rpm while landing will still be about 2000 rpm until touchdown. Then the engine will slow down to 1500 if I don't bring in a little throttle. Sure helps on short landings. The latest from Rotax is that the minimum rpm should be set for the needs of the aircraft and the mission which can vary from 1400 to 2000 rpm. I always taxi between 1800 and 2000 because that is smoother. But do have to ride the brakes a bit.
Jim Shumaker
_________________ Jim Shumaker |
SkySteve
Posted: Wed Mar 12, 2008 6:50 pm Post subject: Re: Rotax 912 80HP Idle RPM |
Thanks, Jim. I think I'll back mine down a bit and try it.
Huntsville, UT
Sbennett3(at)aol.com Guest
Posted: Wed Mar 12, 2008 6:54 pm Post subject: Rotax 912 80HP Idle RPM |
I can pull my throttle on a short final where the prop will keep the engine idling. If I don't add throttle after my wheels touch the engine will die. I feel THAT is perfect control. Steve Bennett
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Posted: Thu Mar 13, 2008 6:24 am Post subject: Rotax 912 80HP Idle RPM |
Steve, I keep just a little brake on but in checking this week, there is still a lot of pad left after 775 hours. mostly just polishing the rotors. coming to logan sometime?
ures N [quote][b]
SkySteve
Posted: Thu Mar 13, 2008 8:09 am Post subject: Re: Rotax 912 80HP Idle RPM |
John,
Yes on the coming to LGU. Johnny O and I have discussed it several times. Thinking of coming to one of your Saturday morning breakfasts in the near future. It's snowing here today and looks like it will be thru the weekend. Understand you and I are in the same business (which sucks right now). Would love to meet you. In fact, maybe you, John and I should meet for breakfast or lunch at OGD soon (or even somewhere in BMC).
Huntsville, UT
pulsair(at)mindspring.com Guest
Posted: Thu Mar 13, 2008 1:53 pm Post subject: Rotax 912 80HP Idle RPM |
Steve,
When my throttle is against the stops on short final I'm at 2,000 RPM. Once
I touch down and tap the brakes I keep it at 2,000 RPM. Anything less then
that I hear the dog ears/legs (whatever) slapping in the gear box. Jeff
Classic IV
Posted: Thu Mar 13, 2008 2:09 pm Post subject: Rotax 912 80HP Idle RPM |
our monthly breakfasts are 8-10 on the second Saturday of each month. come on down
J
[quote] --> Kitfox-List message posted by: "SkySteve"
John,
Steve Wilson
Huntsville, UT
Kitfox I-IV 85DD
> ; Read gt; _-
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Mon Mar 17, 2008 7:29 pm Post subject: Re: Rotax 912 80HP Idle RPM |
I have found that If I have the prop set..(taper tip warp) at a good cruise pitch, and the wide open rpms in flight will just touch redline, that at Rotaxs Recommended min idle speed I have a heck of a time getting the Plane to land...makes it a tremendous floater. I either have to take some pitch out of the prop to get good landings, or reduce the idle speed to 1500, at which It begins to get rough.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
Catz631(at)aol.com Guest
Posted: Tue Mar 18, 2008 4:54 am Post subject: Rotax 912 80HP Idle RPM |
Don, Don't feel like the 'Lone Ranger" I too have been having fits landing my Kitfox like a normal taildragger.In fact when I first bought the plane the engine quit on me three times on final (3 different flights) and the airplane landed very nicely. Well, like a dummy I adjusted the idle back up so it wouldn't happen again and like you, it wouldn't land cause you can't get the power back far enough! So now I have it adjusted as it was and make the rpm part of my landing scan. As the former owner said it's called "slip and plop" Nature of the beast I guess. (with a Rotax 912 anyway-weird engine)
Dick Maddux
Fox4-1200
Rotax 912UL
kmamjones(at)comcast.net Guest
Posted: Tue Mar 18, 2008 8:34 am Post subject: Rotax 912 80HP Idle RPM |
I'm confused about this subject. I'm a Series 7 builder. I have a 912S not yet installed. I thought I was building a STOL aircraft that could land short. I knew the engine idle speed was high, but I thought the gear box reduced the prop speed so that it was not providing thrust at idle speed. These messages suggest that is not correct. Do I have to change to another engine to get STOL landings?
Ken Jones
Waynesboro, PA
Series 7 builder
Don G
Posted: Tue Mar 18, 2008 10:03 am Post subject: Re: Rotax 912 80HP Idle RPM |
Ken,
I dont think so...
Now, I am a long way from an "expert"...so take this as just one fellas experience, and not necessarily the norm..and I have never riddin in a series 7...only the 4's and older.
Airplanes flight characteristic's are equal to the sum of a list of compromises.
ON this particular subject...some of the things I can think of on the list are:
Cruise speed...vs Landing speed
IN other words...set the prop for maximum cruise potential,(max pitch) and even with the gearbox slowing it down when it is at Rotaxs recommended Idle speed of 2000 rpms or thereabout...it still it putting out a fair amount of thrust...so Landing short requires alot of pilot technique.
This was Dick was referring to in the previous post with the "slip and plop" description...I liked that alot...he means crab/slip it in with a high drag attitude to help slow it down quickly and then plop it in..
or...lower the min throttle setting to less than Rotax's min recommendation, and get familiar with the chattering of the gearbox that this high idle speed is supposed to prevent. This way you can keep one hand on the throttle and when you bring it in...bring the rpms down real low....just so you loose that residual thrust from the prop....and when you get the airplane on the ground...ride the brakes and push the throttle back up to get out of your engines particular "gearbox chatter" rpm range
or.. compromise on the fast cruise and lessen the pitch of the prop so that there is no thrust or very little at 1900 or 2000 rpms,,,and land it without the either of the extra techniques referred to above required.
OR...since you are building...install an airbrake like a F-86 or a tomcat and use it on landing....(this actually might be more viable than comical after considering)
After streamlining the struts...really tweaking the rigging and getting the wings set "just right"...running the prop pitch up to where the engine wont redline until after about a minute of so at wide open throttle...my Speedster flys so dang fast I cant hardly tell people about it because they just don't believe it...Not that this near sonic speed matters to me that much, but I do like the super economical cruise ...with the engine down around 4700 or so, 3.5 to 3.7gph on the fuel flow.. and the airspeed over 100
I personally think you have made a good choice..but when you think about it....making the best Short landings in ANY aircraft is all about pilot technique.
And remember this...I could be wrong.....
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A
clint_bazzill(at)hotmail. Guest
Posted: Tue Mar 18, 2008 10:04 am Post subject: Rotax 912 80HP Idle RPM |
The kitfox is STOL because of light wing loading and lots of power to weight. Its not like an airplane with big wing flaps that allows you to put you self behind the power curve and adjust your glide by power. The Kitfox glides very well, kind of like landing a C 150 with no flaps. A completely different approach (No Pun) to the technique to landing, doing a lot of slipping. I have had the engine stop on landing a couple times, trying to get the airplane to slow down. Practice landings with a kitfox over a 50 foot obstacle and this will help a lot. My 2 cents worth. Clint
Subject: Re: Rotax 912 80HP Idle RPM
Date: Tue, 18 Mar 2008 12:27:28 -0400
[quote] I'm confused about this subject. I'm a Series 7 builder. I have a 912S not yet installed. I thought I was building a STOL aircraft that could land short. I knew the engine idle speed was high, but I thought the gear box reduced the prop speed so that it was not providing thrust at idle speed. These messages suggest that is not correct. Do I have to change to another engine to get STOL landings?
Ken Jones
Waynesboro, PA
Series 7 builder
Fox5flyer Guest
Posted: Tue Mar 18, 2008 10:51 am Post subject: Rotax 912 80HP Idle RPM |
Ken, as was previously posted, the recommended idle speed is around 2000rpm, the same for my Subaru setup. The only reason for the high idle rpm is to smooth out the tortional vibration pulses from the prop and keep the gearbox from hammering for long periods. However, landing rpms are much different and can be easily backed off to 1500 or less (about 500 prop rpm depending on ratio) to get a slow prop speed for short final and landing only. One poster said his engine kept dying at the lower rpms, but I believe that he might be dealing with a mixture problem, probably too rich that is causing the engine to die at the lower rpm. The Kitfox, whether a model 1 or 7 is a good short field airplane, but prop speed is important so that excessive float isn't encountered. I idle mine about 2200rpm, but the idle stop is set for 1400 for landing. The 912 shouldn't be very much different and I'm sure others will chime in soon with their setups.
The 912S is a good package, and probably the best choice out there for the Kitfox. What probably keeps most people from going with it is only the price.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Fox5flyer Guest
Posted: Tue Mar 18, 2008 10:56 am Post subject: Rotax 912 80HP Idle RPM |
I like Jeff's idea about using the F4 drag chute...
| Quote: | OR...since you are building...install an airbrake like a F-86 or a tomcat
after considering)
Don G.
Guy Buchanan
Posted: Tue Mar 18, 2008 11:04 am Post subject: Rotax 912 80HP Idle RPM |
At 09:27 AM 3/18/2008, you wrote:
| Quote: | I thought I was building a STOL aircraft that could land short. . .
First, there is no problem with the 912. Most Kitfoxes have
them and some of the ones that do can land reliably in less than
100'. That said, my Kitfox IV with a 582 is a very difficult plane to
land short. Minimum sink is at 50 mph indicated. (This from my gross
weight flight test data.) At that weight my stall is 40-45 mph
indicated. Thus, unlike a full-flaps Cessna the only way to really
increase sink is to point it down hill and go fast, (lots of drag,)
or to slip like mad. Unfortunately, in either case you end up fast in
the flare and you float. (I haven't the courage to slip close to
stall speed near the ground.) So how do these guys land short?
First they drag it in as low and slow as they dare. (Speed
is based on gust factor, etc.) When I say low, I mean 2-3 feet over
the terrain. When they get near the threshold they pull power and
simultaneously rotate. Ideally the mains touch the ground with little
vertical velocity just as the wings stall. When the mains touch they
push a little and brake hard. Then begins the game of braking as hard
as you can without nosing over while using elevator to control
attitude. Initially you push forward on the stick to plant the tires
(reduce AoA) to get traction. Then as you mash the brakes you pull
the stick back, maintaining attitude. You apply as much brake as the
elevator will stand. As the plane slows and before the elevator
looses effectiveness you reduce the braking just enough to get the
tail to drop. This moves the CG back and puts more down-force on the
tires. (Don't do it too soon or the wing's lift will offset your
gains.) Ideally the tailwheel kisses the ground just as you stop. All
of this happens in about 3-5 seconds.
Compare this with the trike 152. Full flaps, 5mph over
stall, (I think about 50,) and the plane's sinking like a rock. Just
before touchdown you rotate to buffet. (You do this to mitigate the
impact a little, but mostly to keep the nose wheel from hitting too
hard.) The impact is incredible, but the spring gear soaks it up.
Upon impact pull full back stick and full brakes. (No skidding.)
Doing this you can land a 150 incredibly short. (I don't remember the
numbers, but it was impressive, something like 100'.) More
importantly just about anybody can do it. I learned during PPL
training. Compare this to a couple hundred hours in the Kitfox and I
still can't land short EVERY TIME.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
wingnut
Posted: Tue Mar 18, 2008 11:51 am Post subject: Re: Rotax 912 80HP Idle RPM |
| Quote: | | So how do these guys land short? First they drag it in as low and slow as they dare. (Speed is based on gust factor, etc.) When I say low, I mean 2-3 feet over the terrain. When they get near the threshold they pull power and simultaneously rotate. |
This seems to me like a great example of why I think you have to be real careful about making generalizations based on personal experience. From this description, my model IV is a completely different animal. Like most of the people on this thread, I had to tweak my idle setting to get it low enough to limit excessive float on flare. But, now that I have it dialed in, it’s not an issue at all. Not to say that I land short reliably but I blame that on my piloting skills. I say this because I have managed to land quite short on occasion with nothing more than setting up the approach well and managing my air speed properly.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Tue Mar 18, 2008 4:22 pm Post subject: Rotax 912 80HP Idle RPM |
Thanks for your input guys. The conclusion I've reached, as Dick Maddux said, the 912 is a weird engine. I find it hard to understand that the engineers would design an aircraft engine that cannot idle on a landing approach with no added thrust. If I remember right all the Lycomings I used to fly would idle so slow the props would actually create a little drag. I'm really annoyed with myself that I didn't think to research this subject more before I made the engine purchase decision. Yet we all know there are a lot of new light sport aircraft on the market using the Rotax 912 engines. So I wonder if I'm being overly concerned. Is this really an important issue? Do all the new light sport's have this problem? I've been planning on taking a biannual flight review next month. I think I'll make sure to do it on a light sport using the Rotax 912 to see for myself.
In any case the conclusion seems to be that the only way to achieve low approach speeds with a Rotax 912 is to slip hard or accept gearbox chatter at low idle settings during the approach.
Ken Jones
Series 7 builder
