second power source
pitts_pilot(at)bellsouth.
PostPosted: Thu Mar 20, 2008 11:05 am    Post subject: second power source Reply with quote
Tim Olson wrote:
Sorry Linn, but the EFIS world really changes the paradigm a bit
on what usefulness a 2nd battery can be. Most EFIS systems
won't stay running while you crank an engine, and most EFIS
systems take a little time to come up to provide datalink
weather and other services, and to just do thorough self-tests
and the normal routine boot process.
No apology (was it??) necessary. I see what you mean. As part of my
education ..... never had an efis ...... can you give me the voltage
range and current draw from your efis owners manual??
Does it take longer for the efis to come online than for a GPS??? Is
there a substantial delay before the engine parameters are
available??? Can you give me a guesstimate of the time???
You can shortcut the boot, but it's at the expense of self-tests and
sensor accuracies.
Really wouldn't want to do that ..... inaccurate info is useless!!!
Having a 2nd battery there to get things running
pre-start, so you have a display of all engine parameters,
and everything else, is a great thing. No, it's not a 100%
necessary thing, but it is a whole different situation than
the panels common 5 or more years ago. The electronic ignition
adds one more place to use a 2nd battery...but in my install
I combined the function and just have 2....I didn't go to
3. 2 though, that will be very common with EFIS based installs.
OK, then it appears that a small battery (less weight) might fit the
application??? It might also run the essential buss for a while. Just
musing.
Thanks for the point of view.
Linn
Tim Olson
PostPosted: Thu Mar 20, 2008 11:58 am    Post subject: second power source Reply with quote
On my particular EFIS, the Chelton the requirement is:
8-34VDC / 32 watts
The WSI receiver is:
10-32 Volts DC (at) 0.6 Amp (at) 14VDC
One of the other ARINC components is:
10Vdc – 32Vdc operational (at) .1 Amp maximum at 28 VDC
The OP Tech system is:
10VDC to 32VDC Input current 5.8 Amps at 12 VDC typical
Input power 70 Watts typical
The GRT system is:
Power: 12 VDC to 28 VDC 1.3 amps
The GRT EIS is:
9-18 Vdc, .1 amps
So, out of those particular systems, the Chelton that I
have has actually the lowest input voltage spec and a
lower current requirement than some of the others, and
yet if I cranked my engine with the screens on the main
bus, they definitely will reboot. It takes a couple of
minutes for a satellite datalink for Wx to link up, so
if you were prepping for an IFR departure and wanted to get
the actual weather picture before you fired up the engine,
you'd really be best off having it be able to boot and
stay alive during the time you have to crank the engine...
so you can sit on the ramp with the engine off and get
your Wx together. I also have a non-mandatory, but highly
recommended 2:00 countdown timer after the self-tests are
finished that allow the heaters in the AHRS to bring the
Air data unit to a stable temp and ensure that all the
sensors are ready for optimum performance. All of these
things can be a bit of a pain if you want to have any
of it operational during engine crank, as the voltage
drop gets pretty large on crank with todays high draw
starters.
Nothing is written in stone though, and everyone can do
what they feel they want to, but I just find tons of
utility out of a 2nd battery.
To continue to answer the questions, yeah, some parts of
the system, like the GRT EIS I have, are very quick to
boot, but have less quality of display. But some take
2 or 3 minutes to be fully ready to go. It all depends
on the equipment...and with the Chelton stuff they tend to
favor the extreme of reliability and accuracy, rather
than just a quick and dirty boot. I'm sure there are
some EFIS's that take much less time, but it would
come at the expense of some of the stabilization or
self testing. So it really depends on if you want to
fly IFR, if you want to have full engine gauges during start,
and of course what all the various equipment choices are
that the person has. There isn't really a single best
way to do it, but there will be lots of systems that will
be well served by aux batteries.
Your point about the *small* battery is a good one. To just
keep a couple of minor items from dropping out, it wouldn't
take much of a battery. A small one that is smaller than
a brick would do nicely for that simple task. For me, I
decided that if I was going to go single-alternator, I could
do that very comfortably if I had an aux battery system that
would power my eBus items for a full hour. So, I went
that route....a good sized main battery that I can use
'til it's dead, and a "use during cranking" aux battery
that can also serve to keep all of my eBus items alive
for an hour after I go lights-out on my "disposable"
equipment.
I'll throw one other thing out there just for the hell of it
while I'm at it...since I just ran into someone with the opposite
opinion last weekend...who flies my same type of EFIS.
When it comes to what to put on my eBus, I included my EFIS and
AHRS, along with one NavCom (the integrated one). IMHO, since
I have the juice to drive it for an hour, I look at it this way...
If I have an alternator failure in the clouds, the last thing
I want to do is get rid of my EFIS. Keeping an EFIS like mine
alive is probably the absolutely FASTEST way for me to get
on the ground. An RV-10 can fly a lot of miles and make an
on-airport landing really easily, if you can quickly and
successfully fly an approach.
The other guy's opinion differed....he figured that if he
"lost that stuff" that he may as well go all to backups
and fly the hard way. Well, I had a hard time with that
because losing an alternator shouldn't force you into
losing your EFIS...now you have to go with minimalistic
round gauges and get home...just when you already have a
high stress situation. He didn't have his EFIS on the
eBus. I didn't like that idea....you got the tools,
you may as well use them. My EFIS PFD draws 3A max.
the AHRS much less. If there were ANYTHING I'd want to
keep, it would be those 2 items. I just don't think the guy
thought it though as to what types of failures he expected,
and when he expected to have them. Perhaps in his mind,
the EFIS failure was inevitable if the Alternator died,
or he wasn't separating the 2 events in his mind. Oh well,
we all make our own choices, so I wasn't about to beat
anyone up for it. It's just a philosophy and it's one that
the builder needs to think through.
Sorry to ramble....for the first time in a while I felt
like typing a bit more.
> sensor accuracies.
musing.
Linn
CJohnston(at)popsound.com
PostPosted: Thu Mar 20, 2008 12:51 pm    Post subject: second power source Reply with quote
I totally agree here with what Tim is saying about what you pick to be
on your Ebus for minimal draw. With a comprehensive EFIS like the
chelton or similar, I would throw every electron I had in my battery at
that in the event of an alternator failure, because, as Tim said, you
can keep flying with a relatively low stress level. Plus, if you
regularly fly behind a Chelton, those old-school round gauge IFR skills
are gonna be pretty rusty Smile...
Another data point that I'd like to make here with respect to EFIS
systems rebooting during engine cranking - if you get one that has an
internal battery built in, it won't reboot during cranking.
I got an AF3400 to be an engine monitor, ended up getting the
Engine/EFIS system, because, well why not? And I ordered it with the
internal battery that'll keep it lit for about an hour by itself. Many
other things make it very cool too, but the internal battery is a good
bonus.
Cj
www.perfectlygoodairplane.net
